Why does EM wave phase shift by 180° when reflecting from a denser medium?
sheld
Why phase difference of EM wave is changed 180 degrees reflected from denser medium?
I will be glad if u give me the actual reason [emoji4]
Thanks for ur help to provide this link... though I have little bit confusion, I will figure it out..
The 'reason' can be explained in terms of a change of impedance and the requirement for continuity at the boundary. At the interface, there has to be continuity of E and H fields - as a wave crosses, if the ratio of E/H changes (different phase velocity) then there must be a reflected wave because all the energy can't pass through. One or other of the Electric or Magnetic fields in the reflected wave will be in anti phase so that there is no change in field across the boundary. Which one changes sign, depends on whether the impedance of the second is greater or less than the impedance of the first medium.
This link may help or, maybe this one.
An electromagnetic wave undergoes a phase change of 180° upon reflection from a medium that has a higher index of refraction than the one in which the wave is traveling.
The OP wants a reason / explanation, though. Why would you expect the reflection from a lower index of refraction boundary to be in phase?
