Why does equilibrium constant K<<1 mean the backward reaction dominates?
6 replies · 12K views
WWCY
For a reaction defined as such,
$$A\rightleftharpoons B$$
the equilibrium constant ##K## is defined by ##K = p_B / p_A##, with ##p## denoting the partial pressure (edit: at equilibrium). However, if ##K<<1##, which implies ##p_A >> p_B##, it is said that the backwards reaction dominates and that the container will be filled mainly with ##A##. ##K>>1## then implies the opposite, and the container will be filled mainly with ##B##.
Why is this the case? For example, if I had a container filled only with ##A##, which means ##K = 0 < 1##, how does any backward reaction dominate? Shouldn't the "A converts to B" reaction dominate?
Thanks in advance!
##K## is a constant that is set independently from the partial pressures. It is calculated by considering the change in Gibbs free energy for the reaction.
If ##p_B = 0##, then the system is necessarily out of equilibrium and the reaction will proceed from left to right until ##p_B / p_A = K##.
Does this also mean that if K >> 1, the reaction will proceed such that the container at equilibrium will have ##p_B >> p_A##?
Thanks!
Thanks!
Yes. ##K>1## will lead to an excess of B over A, while ##K<1## will lead to an excess of A over B.
I should add that the values of ##K## (or ##\Delta G##) apply to the reaction as written, proceeding from left to write. If you write the equation the other way around, ##B \rightleftharpoons A##, then ##K \rightarrow 1/K## and ##\Delta G \rightarrow -\Delta G##.
If P is the total pressure, and you start out with all A, then at equilibrium, the partial pressure of A will drop to ##p_A## and the partial pressure of B will rise to ##p_B=(P-p_A)##. So you would have: $$\frac{p_B}{p_A}=\frac{(P-p_A)}{p_A}=K$$This means that, at equilibrium, $$p_A=\frac{P}{(1+K)}$$and $$p_B=\frac{PK}{(1+K)}$$
