Why Does Gamma Apply to All Object Components?
Gamma applies to all object components in special relativity due to the transformation from time derivatives to proper time derivatives along a world line, introducing a gamma factor. This factor affects 4-velocity and related quantities, such as 4-momentum. Consequently, energy, being the time component of 4-momentum, is also influenced by gamma. While the application of gamma is consistent for a large class of objects, it does not universally apply to all components. Understanding these mathematical relationships is crucial for grasping the implications of special relativity.
bolognie1
So it seems straightforward to me that if time dilated, then so would size, mass and energy, but I don't know how to prove that mathematically. I understand the concepts of special relativity and the lorentz transform, and why it is applied to time, but I can't recall or figure out why Einstein would decide to apply it to all properties of an object.
Thanks guys.
One way it arises, for a large class (but not all) of objects, is going from time derivatives to derivatives by proper time along a world line. Any change from time derivative to proper time derivative introduces a factor gamma. As a result, all 4-velocity (the world line tangent vector with derivative by proper time) and anything based on it get this factor. That includes 4-momentum. From the latter, it applies to energy which is the time component of 4-momentum (in standard coordinates).
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 16 ·
  • · Replies 27 ·
  • · Replies 16 ·
  • · Replies 53 ·
  • · Replies 30 ·
  • · Replies 24 ·
