Why does Hall voltage reverse when current or field reverses?
  • Thread starter Thread starter Schniz2
    Hall effect
2 replies · 6K views · last reply
Schniz2
Show that the Hall voltage reverses sign if either the current or magnetic field direction is reversed, but the voltage offset reverses sign only if the current direction is reversed. Use the information to confirm the validity of equation see eq1 image
see eq 2 image
Tried lots of algebra but got nowhere? I am thinking maybe there is an intuitive explanation? been tring the right hand rule all night and can't work it out!
Cheers!
It is easy to show that the Hall voltage reverses sign if either the current or magnetic field change direction using the right hand rule. You could also even show it using Equation 2 you listed.
But I am not sure what the voltage offset is, so I can't help you there.
Actually, i thought about it more and i think i finally kind of understand it... too messy to put into words but it sort of makes sense
nickjer - the voltage offset eliminates the error due to misaligned voltage measurement probes.. you take one hall voltage measurement, reverse the magnetic field and then take another, you then use the equation Vh=0.5*(Vh1-Vh2).
thanks.
