Why Does Higgs Production Cross Section Calculation Differ from Expected Values?
  • Context: Graduate
  • Thread starter Thread starter Safinaz
    Higgs Higgs boson Pdf
6 replies · 3K views
Safinaz
Hi all,
I try to calculate the Higgs production cross section by Mathematica using
for example the formula in [arXiv:hep-ph/0503172].
The problem comes when I calculate " σ_0 " it's of order 10^-10 pb at mh = 125 GeV ( 3.57), then when I convolute with the parton distribution function to get the pp -> H production according to equ.( 3.58) it gives me of order 10^-7 pb ! while in the plot (3.18) pp -> H is around 50 pb.
I don't know what is the problem I have, any help please.Safinaz
It is hard to impossible to tell what is wrong if you do not show your calculations.
10-7 pb is too small.
for σ0:
σ0[mh_] : = ( ( c^2)/ (256 *Pi)) *(1/2)^2* ( ((Yht)/(mT))* At [mh])^2
where
c = 0.117, Yht= mt/v, v= 174 and At is the fermion loop function.
This gives 10^-10 pb .
For σ(pp -> h) I used:
LogPlot[ {σ0[mh]*(q)* NIntegrate[(1/x)* pdf[iset, iparton, x, 14000] * pdf[iset, iparton, (q/x), 14000], {x, q, 1}], {mh, 100, 200}]
With
iset = 1; (* CTEQ5M*)
iparton = 0;
q := mh^2/14000^2;
Safinaz said:
I try to calculate the Higgs production cross section by Mathematica...
This is way too small also.
What you gave doesn't correspond very well to the equation Eq (3.57) But after all, finding a missing factor of so many orders of magnitude should not require the use of Mathematica!
If you take a look at the equation as given, the Fermi coupling constant Gμ from Eq (1.76) is 10-5 GeV-2, the strong coupling constant from Eq (1.78) is αs = 0.1, and there is a numerical factor of about 1000 in the denominator. The form factor A is order of magnitude 1.
Apparently a dimensionful factor has been suppressed. To get something with the right dimensions, i.e. a cross-section, we need to reintroduce (ħc)2 where ħc = 200 MeV-f. So we have
10-5 GeV-2 (200 MeV-f)2 (0.1)2/1000 ≈ 10-10 f2 = 10-36 cm2 = 10-12 b = 1 pb
Thanks for your reply,
So the problem is only the dimensions. Now σ0[125] of order 10^-5 pb .. but what about
σ(pp -> h) , at page 115 it's mentioned that ## \int L dt = 100 pb^{-1} ## so that should
we multiply by some factor here because I still have σ(pp -> h) [100] = 0.006.
s.
I don't see how the integrated luminosity at hadron colliders would be relevant for the cross-section. If you care about the total number of Higgs bosons produced, multiply the cross-section with the integrated luminosity. With 1pb (see post 4) and 100/pb this gives 1pb*100/pb = 100 Higgs bosons.
So what about equ.(3.58) in [arXiv:hep-ph/0503172], they gave the total cross section by multiplying
##\sigma0## by ## \tau_h ( dL/d\tau_h)## I don't understand this expression.
They define ## dL/d\tau_h## as the parton distribution function and this is what I used in my calculation
to get(pp->h) as in post 3 after getting ##\sigma0## (pb).
S
