Why does integrating p = kV give wrong work for linear pV process?
  • Level: Undergrad
  • Thread starter Thread starter perplexabot
    Gas Work
12 replies · 3K views
perplexabot
Hi all. Trying to find work done for a gas... Here is the question:
A quantity of air is taken from state a to state b along a path that is a straight line in the pv-diagram (figure is attached). If Va = 0.07, Vb = .11, Pa = 100,000 , Pb = 140,000. What is the work W done by the gas in this process? Assume that the gas may be treated as ideal.
Ok i know the area under the graph is work. But instead of doing it that way can i use this way?:
W = (integral of) p dV
and since p is changing linearly: p = mV + b where b = 0 and m = (Pb - Pa)/(Vb - Va) = k
so p = k* V
substituting that back into the Work equation i get:
W = (integral of) k * V dV
=> W = k * (integral of ) V dV
=> W = k/2 (Vb2 - Va2)
ok so after all this i end up with 3600 J which is wrong (actual answer is 4800). Can any1 tell me what I'm doing wrong? or why this technique doesn't work?
once again i know u can just find the area of the graph, but i want to know why this way is wrong..
Thanks all.
Where has "So p = k.V" come from? It implies that the line goes through the origin, which it doesn't. I think something has gone wrong with your algebra, though this started correctly.
p = k * V where k is just m or the slope ( (Pb - Pa)/(Vb - Va) ).
and if the figure is scaled correctly, if you continue the line, it will pass through the origin.
could it be that i didn't take into account the integrating constant?
I don't think the line does go through the origin. PA/VA doesn't equal PB/VB.
With a definite integral there isn't and "integrating constant" is there? The difference between values at the limits will cancel it out.
Are you sure that the "actual answer" is correct? I can't be bothered to do the substitution sums but your algebra looks fine. If you have put the right numbers into the result of your algebra / integration, then your answer should be right, I think.
I think your way of working out the area is using the 'wrong' trapesium. If you use the one with the p along the base, you get the same answer as your integration method. (i.e. swap your axes)
I must say, I started off thinking Boyle's Law and got totally confused until I re-read the OP!
To reiterate: the linear relationship between P and V cannot be written as P = kV, for the reason I've given. This needs sorting out before proceeding to the integration.
hey... alright so your saying p =mV + b where b is NOT equal to zero because the line does NOT pass though the origin...
pa = m*Va + b
pa = 100,000
Va = .07
m = (pb - pa) / (Vb - Va) = (140,000 - 100,000)/(.11 - .07)
= 40,000/.04 = 1 *106
b = pa - m*Va = 100,000 - (106 * .07) = 30,000
so p = kV + b
=> p = 106V + 30,000
using the above equation for p, I subbed it back into the Work equation and solved... I got exactly 4800 (which is the correct answer). So as you said Philip, the line does NOT pass through the origin.. Thanks for your help...
Well done for your persistence! I expect, though, that having satisfied yourself that the integration method works, you'll use the simple 'area of trapezium' method if you meet straight lines again in the p, V context!
ok thanks for clearing that out. i didn't know that only indefinite integrals had integrating constants. that actually helps a lot. thanks
yes, i will be using the area method from now on. i just wanted to see if i can do it otherwise.. thanks for the help...
I think that you, as I did at first, have missed the point and not read the question fully. You can make p proportional to v if you like over a limited range. Boyle's Law (pv=a constant) only holds for constant temperature. You can ' insist' on any relationship as long as you are prepared to add or take away the appropriate amount of internal energy.
That graph could not ever go to the origin - it wouldn't hold to a straight line without ridiculous / impossible imposed conditions.
Yes but you need to choose the right area;one that integrates p dv and not v dp. In the same way that Work done = distance moved times force and not force change times distance.
I think that who missed the point and who didn't is clear from the sequence of responses.
