Why does light and gravity travel at the same speed?
57 replies · 13K views · last reply
ynot1 said:
This reference applies to a pre-existing black hole but the question is creation of a black hole from a massive star, not collapse of a shell onto a pre-existing black hole.
It seems like it should apply as soon as an event horizon forms---i.e. as soon as you pass critical density.
The gravitational field of the black hole is the sum of the individual contributions from each particle in the black hole. If I understand Hawking radiation it annihilates particles in the black hole, and so the contribution of their gravitational field to that of the black hole will be lost, reducing the gravitational field of the black hole itself and reducing the curvature of spacetime.
This seems preposterous...but then, again, some things are so!
For example, there are few if any 'particles' within a black hole.
Except for recent infalls, all are destroyed at the singularity.
Hawking radiation is formed outside the horizon; Perhaps you mean infalling particles with negative energy combine with recent particles of positive energy...even that doesn't seem
likely ...how would one catch up with the other, or slow down, to affect annihilation...?
Have you any references that describe black holes as you posted??
But, from a observer far away from it (like us, for example), as closer the radius of the star gets to the Schwarzschild radius, slower the shrinking gets, so from a observer far away, it takes an infinite time to a star became a black hole
I think that that is correct. An observer will never see an infalling shell cross an event horizon.
This has been discussed before and I am not positive, but what I concluded from conflicting posts is that such an 'infinite' time is an 'ideal' perspective from infinity in flat spacetime...in our real universe, such a frame does not exist...so dilation IS extended but not infinite.
If it were, how could we observe ANY black hole??
ok I found the source which I have on the preceding issue:
From Kip Thorne in BLACK HOLES AND TIME WARPS
when the star forms a black hole:
...Finkelstein's reference frame was large enough to describe the star's implosion ...simultaneously from the viewpoint of far away static observers and from the viewpoint of observers who ride inward with the imploding star. The resulting description reconciled...the freezing of the implosion as observed from far away with (in contrast to) the continued implosion as observed from the stars surface...an imploding star really does shrink through the critical circumference without hesitation...That it appears to freeze as seen from far away is an illusion...General relativity insists that the star's matter will be crunched out of existence in the singularity at the center of the black...
I think the guy who 'accidently' discovered this is David Finkelstein...
I just checked Wikipedia...looks like THIS is what he discovered with Misner:
The simplest kink exhibited an easily understood event horizon that led him to recognize the one in the Schwarzschild metric and eliminate its coordinate singularity. This work influenced the decisions of Roger Penrose and John Archibald Wheeler to accept the physical existence of event horizons and black holes.
But what does it mean??
At the same time, however, infalling material becomes increasingly redshifted (quite rapidly), and thus an observer will stop 'seeing' any of that outside material. I guess the infalling matter would appear to dim/fade as it asymptotically approaches the event horizon (which also grows as additional matter falls in).
See: http://adsabs.harvard.edu/abs/2012PhLB..707..233P
The critical density has already been passed for pre-existing black holes.
Really? Check out http://www.theregister.co.uk/2010/11/29/lhc_lead_results/
Incoming particles would collide with the quark-gluon plasma.
The simplest kink exhibited an easily understood event horizon that led him to recognize the one in the Schwarzschild metric and...
Delete.
That answer would probably be speculative.
Tanelorn said:
Originally Posted by JonDE
Maybe my confusion is because I think of it as a wave or particle (graviton), and I don't see how a graviton can escape when other particles cannot.
Radiation escapes black holes and gravitons radiate.
I think I already commented on this post.
Really? Check out http://www.theregister.co.uk/2010/11..._lead_results/
Where does that reference say ANYTHING about plasmas within black holes?
Please provide a peer reviewed source that discusses plasnmas within a black hole.
ynot
So you consider Finkelstein's work and subsequent years of acceptance by physicsts
'speculative'?...Can you provide a peer reviewed source
drawing such a radical conclusion.
ynot
Originally Posted by Drakkith
Universe21, spacetime most certainly exists everywhere in the universe. And we don't know that gravity DOESN'T have a force carrier, we simply haven't been able to find one yet.
looks like whatever force carrier gravity has would be the same as that for light if they both propagate at the same speed.
Looks like WHAT? You mean that the quanta of the gravitational force and electromagnetic force are identical?
Are you implying that all massless particles are identical??
If so, please provide a peer reviewed source. (PS: there is none)
Naty1 said:
ynot
Looks like WHAT? You mean that the quanta of the gravitational force and electromagnetic force are identical?)
I'd say there is a difference. Gravitons would have infinite wavelength.
No, there are 4 gauge bosons. Since gravitons and photons both travel at the speed of light, I'd say a graviton would be a special form of a photon.
Seems silly if there is none.
The same would be true for an observer a finite distance away from the event horizon (i.e. not in an 'ideal' position).
As I mentioned before, an observer would see material rapidly fading as it approaches the event horizon. It would never be observed to cross, and you can never see anything from inside the EH anyway. There is no inconsistency in being able to observe a BH.
Gravitons would not have infinite wavelength; and they are not a special form of photon (for example, photons are spin 1, where-as gravitons would need-be spin 2). Avoid overly speculative posts in accordance with the PF guidelines.
Naty1 said:
ynot
I notice you included your question inside of your quote. I was referring to the meaning, not the work. Sorry for the misunderstanding.
WHat an awesome question. This subject fascinates me but hurts my brain at the same time. It is really a lot to process.
So would a graviton have a wavelength? Or would that just be speculation.
I'm assuming you are referring to the fact that a photon is an EM wave and has a particular wavelength, and comparing a graviton to it? I am unsure about whether or not a graviton is a gravitational wave like how a photon is an EM wave.
I don't think a graviton has a finite wavelength, I was referring to the quote about gravitons would not have an infinite wavelenth. So I I'm wondering how you might go about finding the wavelength of a graviton, if there is such a thing. I'd think if there was a way we would have found one by now.
We haven't even found evidence of a graviton yet, so I have my doubts. But I don't know the math, so maybe someone else here knows.
So I'm wondering how you might go about finding the wavelength of a graviton, if there is such a thing. I'd think if there was a way we would have found one by now.
From
http://en.wikipedia.org/wiki/Graviton#Experimental_observation
Unambiguous detection of individual gravitons, though not prohibited by any fundamental law, is impossible with any physically reasonable detector.[12] The reason is the extremely low cross section for the interaction of gravitons with matter. ...
However, experiments to detect gravitational waves, which may be viewed as coherent states of many gravitons, are underway (e.g., LIGO and VIRGO). Although these experiments cannot detect individual gravitons, they might provide information about certain properties of the graviton...
No results that I have seen; some discussions here in the forums.
I think that's a really tough one to answer...some clues...
There are some basic issues which are unresolved:
One thing we think we know is that gravity and EM have some [mathematical] differences: This is because the source of gravitation is the Einstein stress-energy tensor, a second-rank tensor, the source of electromagnetism is the four-current, a first-rank tensor.
Can gravitons be polarized like photons? is dependent on helicity...
Isn't the photon it's own antiparticle; how about the graviton?
How much more do we know about the mass of a photon than graviton? [We know the photon is massless down to some tiny,tiny figure; we haven't even found a graviton yet.]
As I understand things, there is not even wide agreement among QM people about exactly how a photon derives from or creates EM waves...apparently the latter is current thinking...
edit: found this in PHOTONarticle:
", the photon is not a point-like particle whose trajectory is shaped probabilistically by the electromagnetic field, as conceived by Einstein and others; that hypothesis was also refuted ... According to our present understanding, the electromagnetic field itself is produced by photons, which in turn result from a local gauge symmetry and the laws of quantum field theory..."
Here is one description of uncertainties (unknowns):
Gravitons and renormalization
When describing graviton interactions, the classical theory (i.e., the tree diagrams) and semiclassical corrections (one-loop diagrams) behave normally, but Feynman diagrams with two (or more) loops lead to ultraviolet divergences; that is, infinite results that cannot be removed because the quantized general relativity is not renormalizable, unlike quantum electrodynamics. That is, the usual ways physicists calculate the probability that a particle will emit or absorb a graviton give nonsensical answers and the theory loses its predictive power. These problems, together with some conceptual puzzles, led many physicists to believe that a theory more complete than just general relativity must regulate the behavior near the Planck scale.
Anyway,if interested, check Wikipedia here for a LOT on photons:
http://en.wikipedia.org/wiki/Photon
Presumably a graviton would have a wavelength just like a photon does. It would be more appropriate to talk about the wavelength of the gravitational wave, and the energy of the graviton.
There was another thread that discussed these issues...I can't find it... I did copy one post that I thought interesting...draw your own conclusions:
Phyzguy:
We really use the word photon to describe two things. On the one hand, we refer to a photon as being an elementary excitation of the EM field, which has a definite: energy, wavelength, and frequency. These photons are the eigenstates of the EM field, and extend to +/- infinity.
On the other hand, we also use the word photon to refer to the wave packet emitted by an atom when it drops from one energy level to another. But this latter photon is not an energy eigenstate. It does not have a definite frequency, because the atom is not in the upper and lower energy states for an infinite time, so there is a time uncertainty which leads to an energy uncertainty. So the wave packet contains a range of frequencies, and multiple measurements of its energy would lead to a distribution of probable values. Because there is a range of frequencies and wavelengths, the wave packet is also bounded in space and time. The "size" of the wave packet (let's say the duration in time) depends on how long the atom is undisturbed. If the atom is in a very undisturbed environment, with a long time between collisions, then the wave packet is very sharp, with a long duration (Delta-t), and a small distribution of energies (Delta-E). If the atom is in an environment where collisions are frequent, then the wave packet is more spread out, with a short duration (Delta-t), and a broad distribution of energies (Delta-E).
Any interpretations of the above comparison would be appreciated.
I just noticed:
Sorry page not found. Try http://www.physorg.com/news/2010-11-...lasma-lab.html
Once again, that source says NOTHING about plasmas within black holes.
What the described experiments are doing is reproducing the high energies [used to create plasmas] OUTSIDE black holes as matter is accelerated towards the horizon of a black hole.
[Any jets of matter and radiation 'emitted' from a black hole are accelerated out from the external accretion disk, not the interior of the black hole.]
Naty1 said:
What the described experiments are doing is reproducing the high energies [used to create plasmas] OUTSIDE black holes as matter is accelerated towards the horizon of a black hole.]
Interesting. So plasmas are created outside the event horizon.
So black holes would never evaporate. I see.
I recall something about the frequency of the gravitational radiation from a binary star would be twice its rotational frequency. So I guess we could go from there to calculate its wavelength.
ynot1 said:
Except for Hawing radiation I don't believe gravity does escape from a black hole. Note if too much gravity escapes the black hole it seems it wouldn't be a black hole anymore.
A minor point, but isn't Hawking Radiation (which Hawking was originally against, original proposed by Jacob Bekenstein when his discussed black holes having a well defined entropy in 1972) just merely emitted near the Event Horizon? It is not necessarily "escaping" anything, it is a quantum-level effect that can become a macroscopic event, theoretically.
ynot1 said:
Interesting. So plasmas are created outside the event horizon.So black holes would never evaporate. I see.
Particles are created outside of the event horizon. Not necessarily plasmas---which do often exist outside black-holes.
Black holes still evaporate, as the particles created extract energy from the black hole (according to theory).
That is exactly correct.
As none of the current topics/discussions/points have anything to do with the original post; I suggest this thread be left. Any ongoing subjects should be brought up in new threads.
