Why Does Light Bend Away From the Sun?
6 replies · 2K views · last reply
Carnivroar
I am reading God's Equation by Amir Aczel and he talks a lot about the early observations of eclipses which showed a displacement of the starlight around the sun, because space is curved around massive objects.
But why does light bend away from the sun? If it's being affected by gravity, wouldn't it be pulled towards it?
Ok, I see your confusion. The light is bent toward the sun. However, if you are comparing the observed direction of a star with the expected direction, it is away from the sun. If you connect the ends of a chord with a straight line, imagine the straight line is the expected direction. Now, the tangent to an end of the chord points further away from the center of curvature (where the sun is).
Ah so the arrows are pointing to the expected position, whereas the dots are the actual position under the displacement? Makes sense, but I don't know why they would do it that way. There's no caption in the image, either.
I don't think so.
As PAllen has said, bending light towards the Sun produces images that are displaced away from the Sun. See the diagram towards the bottom of
http://www4.ncsu.edu/unity/lockers/users/f/felder/public/kenny/papers/gr1.html.
