Why does light diffract into only seven colours?
  • Level: High School
  • Thread starter Thread starter louis_slicka
    Light
81 replies · 11K views · last reply
Anachronist said:
It also makes more sense to break down the color categories into six groups, corresponding to each color receptor type in our eyes (red, green, blue) and the colors in between them (yellow=red+green, cyan=green+blue, magenta=blue+red).
When trying to 'regularise' colour, it's easy to paint oneself into a corner. Of your six colours, one (magenta) is not a spectral colour and you don't get it by choosing one section of the spectrum. The only 'magic number' involved is the three analysis curves that (so the tristimulus colour theory says) are used to give the gamut of colours we perceive. But there are no hard boundaries and those analysis curves all cover pretty much the whole of the visible spectrum. It's wide band analysis that allows three 'signals' to be obtained for all those colours in the CIE chromaticity chart.
I have no idea what is so attractive about choosing to quantify the colours - except to allow kids to learn, by rote, some names for the colours of the rainbow. Nothing that we perceive is quantised to why to quantise colour?
Because red berries are poisonous and we needed to communicate or die.
For a while there, we also needed to read resistor colour codes.
Berries come in a whole continuum of 'reds' which we have always needed to distinguish between. Also, the colour of another human's face can extends over a whole range of reds, pinks, light and dark browns and will be used to assess the other guy's health and emotional state. Look in your garden and you will see leaves with yellows, greens and blues (and browns).
If the millions of colours used by colour TV were not necessary, we would use single bit chrominance values.
JeffJo said:
I showed you the picture of it. It came from here, one of the leading references on rainbows:
Thanks. A few comments about the physics.
Any spectrometer will have an overlap between wavelengths because of the finite width entrance slit. For a rainbow this "slit" is the half-degree angle subtended by the sun projected by the internal reflection and the curved refractive surfaces. But the raindrop is still just a (slightly bizarre focussing) prism. I like the characterization of the resulting cusp anomalies as bright edge discs however.
As to effect on color perception one needs to always remember that the eye is very logarithmic in response
:confused:
OK. Here's a million dollars to paint my 100 storey skyscraper DaveC Blue(C).
Millions of consumers all over the world recognize my brand and trademarked colours, so get it right.
Annnnd go!
What? You want a sample of DaveC Blue(C) to be sure you've got it right? OK, here you go:
  • Haha
. . . and that the colours we see in a rainbow are highly desaturated.
Hence PANTONE came into being. Not cheap but it's a standard that gives a pretty good match between identical colours on different materials and surface textures.
No, it isn't; at least, not how it gets depicted. And rainbows aren't a prism-like effect. Nor did Newton characterize them.
On a sunny day, when sunlight shines though a window onto the opposite wall:
  1. Close the shade, and poke a pinhole in it large enough for a beam of light to hit the wall, making a white dot.
  2. Hold a triangular prism in the beam with its axis vertical, and at an angle where a spectrum (the visiblespectrum, if you need to be that pedantic) is projected to the side of where the white dot was.
    1. It is a horizontal line of varying colors, the same width as the dot. Red is closest to the spot where the white dot was, and violet is farthest.
    2. The ray of white light is separated into individual rays of colored light.
  3. Widen the pinhole into a vertical slit.
    1. The line stretches vertically into a rectangle, with the colors varying horizontally but not vertically. You can think of it as having mant lines, like in 2.1, stacked vertically.
    2. Or you can think of it as a knife-blade of white light being separated into knife-blades of colored light.
  4. Rotate the prism so that its axis is horizontal.
    1. The spectrum lines from 2.1 are now vertical. But instead of being stacked next to each other, they are overlaid on top of each other, offset vertically.
    2. The exact result depends on many things. But in general, it will be red at one end, fading through pinks to white in the center. And violet at the other end, fading through lavenders to reach the center.
    3. Each ray of light in the slit does still undergo separation, but on the wall each re-combines with rays of other colors, that hit the prism at a different place.
  5. Open the shade.
    1. Now the prism makes a smear of mostly-white light from the light deflected by the prism.
The line in 2.1 is essentially is Newton's famous prism experiment. The almost universal depiction of that experiment is a single ray separating into colors.
The smear in 5.1 is not Newton's famous experiment. But it is much closer to what causes a rainbow. The effect is not the result of a ray of white light separating into colors. It is the result of how many such rays recombine after separating individually.
They really needed a narrower beam to make the result "pop" here. But the white part of this reflection is the equivalent of the smear in 5.1. The brighter (well, they would be, with a narrower beam) edges are caused by the light being concentrated at the "rainbow angle." The separation of color bands is not caused by color separation, like you think of happening to a single ray in the prism experiment. It is caused by the reflection having different widths for different colors. The light in each band even comes from light that hits the drop at different places, making most of the diagrams you have seen wrong.
What most people were taught, as the cause of a rainbow, is grossly inaccurate at best. And negligently incorrect at worst. Any diagram that shows a single ray separating into colors is wrong. Not wrong as in "that doesn't happen," but wrong because one should ask "what about the ray that hits the drop just below that one?"
And any explanation that mentions Total Internal Reflection is blindly repeating what was taught to them. First year geometry students can show why TIR is impossible.
A better model - although it may be a bit abstract for some high schoolers - is to compare the incoming sunlight to a water wave hitting a floating beach ball. Upon exiting the drop after one reflection inside it, line of the wave will be bent into a shape that resembles a used staple. It will be brighter at the edge, where your eye is looking along the line of the bent shape instead of perpendicular to it.
All of the rays, not just one. The rays drawn in red are close to parallel when they exit:
The staple:
(From https://www.usna.edu/Users/oceano/raylee/RainbowBridge/Chapter_8.html). This effect was one of the first to confirm the wave nature of light. If all of the drops are the same size, we can observe fifferent patterns of constructive and destructive interference, for different colors, in the area that is usually white.
Wow, @JeffJo, that's quite a digression/diatribe ##-## what is (simply put, please) your reason for asserting that a raindrop isn't a (spheroid) prism?
I didn't say it wasn't a light-deflecting device. I said the way the effect is formed is not due to what people think of as the prism effect.
In response to this remark:
Your opening sentence was:
@hutchphd did not say that a raindrop was a "light deflecting device"; he said that it was a "(slightly bizarre focussing)" prism.
If you don't think that a raindrop is a (spheroid) prism, please, in simple terms, say why not. If you think that it is a (spheroid) prism, but "not how it's depicted", then please explain, not why some other depiction is to be preferred, but what characteristics of the commonly used depictions of it as a (spheroid) prism (including plain photographs as well as accurate diagrams) are not consistent with correctly showing it to be a (spheroid) prism.
Also please explain, in simple terms, how the multicolored visual effect is "not due to what people think of as the prism effect". Isn't the multicolored visual effect produced by refraction? And isn't it refraction that produces what people think of as the prism effect?
It needs dispersion to produce a spectrum i.e. differential refraction.
Refraction / dispersion takes place at entry and exit. I seem to remember school experiments with glass prisms which showed that the greatest dispersion occurred with a symmetrical path through the prism ( iin = rout and iout = rin), on account of Snell's Law; or is that just rosy tinted prisms / specs?
The internal reflection is just an added complication which sends the light back towards an observer with their back to the Sun.
Thanks to @sophiecentaur and @sysprog for elucidating. The dispersion of color is caused by differential refraction of the frequencies of light at interfaces. For the raindrop the surfaces are curved and there can be several reflections internally, so the result is more complicated. But the physics is not fundamentally different.
Of course rainbows have more serendipity.
Ah, but in my example, I neither had - nor gave you - a PANTONE chip.
An even if I had, you'd still have to recreate it perfectly consistently in your 10,000 gallons of paint.
Granted, PANTONE is one way of doing it. But they couldn't have done it without first quantifying their own colours.
Which is actually quite doable, apparently, since part of each of the Pantone colors is a specification for the appropriate ink mix. That's the only way that magazines can reliably and consistently reproduce specific Pantone colors. Without that capability the Pantone colors would be useless and they make a lot of money because they aren't useless.
Their testing facility (for batch consistency) is very impressive.
I can't remember whether Pantone colors actually apply to paint (I think they are not). They were designed for printers ink used in magazines.
From Wolfram's Mathworld: "A general prism is a polyhedron possessing two congruent polygonal faces and with all remaining faces parallelograms (Kern and Bland 1948, p. 28; left figure)."
  • I don't want to be as pedantic as some of these responses. This was about color, and why you should say "spectrum" and not "rainbow," but I keep being asked to explain what a rainbow is when a demonstration of "not a spectrum" should have been enough.
  • I agree that you can get your meaning across by calling it a prism, but only when that shares the important properties. Here, the important property is not that it deflects light of different colors, but how it deflects them differently. A sphere does it differently that the prism as Wolfram defines it.
So, a sphere is not a prism. A prism has flat faces that deflect all of the (parallel) light of a single color the same way. That way you can reduce the effect to one dimension; a single point of entry, or entry along a line where all the light deflects the same way. A curved surface produces deflections that vary across the surface in a way that has to be accounted for. In a prism, you need first-year geometry to see where the light goes. In a raindrop, you either have to plot it or use calculus.
Pick your favorite explanation of rainbows. Most are based on a diagram like these:
And compare it to:
In most rainbow explanations, it is clearly implied - and sometime stated - that the rainbow is caused by light from a single white ray separating into colors like what happens in that prism. Or that each color emerges with a single angle of deflection. Since both statementgs about rainbows are wrong, they never explain why they think red light comes out only that one angle. As I keep repeating, that is not the case, and how these angles differ explains why a rainbow is not a spectrum.
All that light coming out at the same angle is what I called "the prism effect." See the diagrams above.
I tried to explain this "prism effect" is what happens in Newton's experiment, the one he used to characterize colors, and is supposed to be the subject of this discussion. But a rainbow is not caused by all of the light of a single color emerging at the same angle. As I have said several times. That's why a rainbow is different than a spectrum.
<Sigh.> Dispersion is not synonymous with refraction, or separation. It is caused by refraction, and may or may not involve separation. Depending on what you think is separating.
Dispersion means that the path traveled by light, which was once independent of wavelength, must be treated as a function of wavelength. And no, I don't have a reference that uses that exact definition. Ignore that I said it if you don't like it, as it really isn't that important to why a rainbow is different than a spectrum. I only mention it because it when we treat similar, but different, concepts as equivalent that issues like spectrum-or-rainbow arise.
The internal reflection is what creates the minimum deflection that makes rainbows. (Not to be confused with the "maximum deviation" sometimes used with prisms as you vary the angle of incidence.)
  • Skeptical
I didn't ask you to explain what a rainbow is. I did ask you to, if you don't think that a raindrop is a (spheroid) prism, please, in simple terms, say why not. Your answer was essentially that it's not a prism because it's not geometrically a polyhedral prism. That difference was acknowledged parenthetically, so your answer that merely elaborates on that already acknowledged difference is unresponsive.
JeffJo said:
[*]I agree that you can get your meaning across by calling it a prism, but only when that shares the important properties.
Then the term 'spheroidal prism' is adequate to get the meaning across, and to acknowledge differences in properties.
The difference between a spherical or spheroid prism, and a polyhedral 'proper' prism, is acknowledged by the use of the modifying adjective.
The term 'spherical prism' or 'spheroid prism' means a spherical or spheroidal object which produces a prismatic optical effect. It's clearly not referential specifically to a polyhedral prism. It's easy enough to understand that.
The term 'rainbow' designates the physical phenomenon by which spectral colors are displayed; it's not as precise in separating them as a glass prism is, but that doesn't mean that people are wrong when they say that a rainbow manifests the spectrum of visible light, or when they say that a raindrop is a spheroidal prism that produces a circular spectrum. That's part of a reasonable explanation for why, from the ground, the rainbow looks like a multlcolored semicircular arch.
Maybe so, but you made reference to "what people call the prism effect", and that isn't restricted to all the light (for a given spectral frequency) coming out at the same angle, as individual light frequencies would in an abstractly perfect prism ##-## the effect by which white light is separated visibly into its consituent frequencies is reasonably called the prism effect, because the prism is the model object for production of that effect.
Actually, the same laws of reflection and refraction apply to any shape of surface because they relate to the Normal. The fact that a raindrop has a curve makes no difference to what goes on; lenses and curved mirrors are designed on the basis of Ray Optics, which breaks any surface into elemental facets.
When right angled prisms are used in optical instruments, care is taken to ensure the light strikes input and output faces Normally, with the specific intention of eliminating dispersion but that is only an example of different behaviour from a raindrop.
An appropriate (shallow) three sided prism can be used to incorporate internal reflection and dispersion on the way in and out. Much the same effect as in a raindrop and with the same angles involved..
As with many foolishly contentious arguments this one now wallows in a sea of semantic purity devoid of Physics. I will now take a short swim myself.
To disperse means to "distribute or spread over a wide area" and dispersion is the act of so doing.
The classic Newton sunlight-through-the-window-shade experiment causes a projection (real image) of this color-dispersed light while the rainbow provides a virtual image of the color-dispersed light. In each case the separartion is caused by the same physics: the frequency dependence of the speed of light. This is in contradistinction to a diffraction grating whch really is different.
Whether you wish to call this the "prism effect" is a matter of personal preference.
JeffJo said:
Late to the party, I know. But in skimming the thread I didn't see the right answer, and did see much that is wrong. (And speaks poorly of Newton.)
Thanks for joining the party, but it is getting late..
My old coworker was color blind. Manufactuers would send furniture with wrong labels on occasion, so if he happened to deal with it, the customer would receive the wrong coloured furniture. To make matters worse, it always happened to somebody who was from out of town.
At one of my happiest jobs, the other physicst was red green colorblind and this was occasionally startling. I vividly remember Rick wandering into my office with two "gelatin" filters, one magenta and one forest green, to ask me which was which! He could not see any difference!
It is not reasonable to interpret that sentence from @sophiecentaur as saying that dispersion is synonymous with refraction.
  • Skeptical
Yes. As a semantic issue I always interpret "/" to be shorthand for "and/or" and so this is exactly correct.
