Why does light not slow down when moving through air?
  • Context: Undergrad
  • Thread starter Thread starter madphysics
    Light Mystery
30 replies · 7K views
madphysics
So black holes are incredibly dense points of matter that affect everything in their area with very powerful gravity field, including light. \
So, asuming that gravity affects only matter, that by default says that light is a physical particle.
So why don't the regular laws apply to it? When light moves through the air in the atmosphere, why doesn't it slow due to air resistance like all other objects with mass?
Astronomy news on Phys.org
When light travels through the atmosphere its speed is slightly lower than in vacuum.
You assumtion is wrong. Gravitation affects mass and energy. Under gravitation mass and energy is equivalent.
As has been stated, your assumption is incorrect. If you look at general relativity, gravity is a manifestation of the curvature of spacetime. Light, or photons, travel along null geodesics, which are essentially a generalization of straight lines in curved space. So if a photon is traveling along spacetime it is going to follow that generalized straight line path, which in curved spacetime means it will appear to be bent (giving rise to gravitational lensing).
And at any rate, light does behave as it should. In mediums denser than vacuum, the speed of light is less than it is in the vacuum (this gives rise to index of refraction for example).
thanks for the help. I have two more question:
Does light continue slowing down as it moves through more of an atmosphere?
If light is in the electromagnetic spectrum, then all other wavelengths of the spectrum travele at the same rate. Correct?
- No, the velocity only changes at the interface.
- In vacuum, yes. In media, no, it depends. Otherwise there would be no rainbows..
If light is bent around a black hole, does it bend around all points of gravity, however small?
And even if it doesn't, do the other waves of the spectrum bend around black holes?
yes! light bend around all points of gravity!
yes! the other waves of the spectrum also bend around black holes!
As the medium becomes denser then in general yes, the effective speed of light decreases. For example light travels fastest in a vacuum, slower in air and slower still in water.
And correct, light is just an electromagnetic wave. What makes it special to us is we can see a sliver of the electromagnetic spectrum and have called it light. Light is the same thing as x-rays or radio waves. All that differs is the frequency (or wavelength).
Yes, as stated it will move around all sources of gravity. But the effects will be very very very small for small sources of gravity.
you have to remeber that black holes have one of the strongest gravitational pulls. they pull in a lot of thing, including light.
The bending of light around the periphery of Sun was one of the experimental confirmations of General Relativity.
physically speaking light really slows down a bit
Chris Hillman said:
Nothing [] anyone said in this thread so far is really correct. If anyone really cares, ask me why not.
So melodramatic.. won't you enlighten us all then to the error of our ways?
In the presence of a medium of refractive index n, the speed of light is reduced to c/n. Since the atmosphere has an refractive index of around 1.000295 at sea level for visible light, it is not slowed down much.
You may interested to know that light beams have been slowed down to a walking pace and even stopped completely (http://www.afrlhorizons.com/Briefs/Jun02/OSR0201.html just from google).
Chris Hillman said:
Nothing anyone said in this thread so far is really correct. If anyone really cares, ask me why not.
Wont it just be easier to tell us? I'm eager to know why what mathman said is wrong.
Oh, it wasn't so bad
Somewhat to my surprise, people care. Hmm... it wasn't nearly as bad as I said... sorry!.
Oops, nothing. I was "kicking" about a bunch of posts which came later on. Here are my pedantic corrections/comments:
I think madphysics is trying to ask whether light bends around any compact object, or indeed any concentration of mass-energy in some region, or just around black holes. The answer is of course "yes".
Light bending does not depend upon the frequency of the light--- this is very important, if it weren't true, we'd see colored fringes in those Hubble images of lensed galaxies. But in any case I suspect madphysics meant to ask if "massless" radiation which is not electromagnetic radiation--- in particular, gravitational radiation, also experiences bending. The answer is "yes", because wave packets of such radiation have (roughly speaking) world lines which are null geodesics (in vacuum).
Well, from what I just said you can see that I wouldn't put it this way.
[snip]
Sorry, Brad, that looks OK too.
All objects with mass M have pretty much the same "gravitational pull". The interesting thing about neutron stars and black holes is that they are so much more compact than ordinary objects, which means that you can get a lot closer without striking "the surface" (or encountering the horizon). Since the tidal forces scale like M/r^3, smaller r for given M means much larger tidal forces.
sanjeeb is thinking of the "Shapiro light delay effect", but this name is potentially misleading since, at the level of tangent spaces, light always travels at c (in vacuum). This effect is really a global effect; in a sense "the effective speed of light" over a large course can be different from c. One way to understand that this is no contradiction is to realize that even in flat spacetime there are multiple operationally significant notions of distance in the large for accelerating observers (which at very small scales all reduce to the notion given by the metric tensor). In particular, radar distance, the notion relevant to the Shapiro effect, can exhibit odd behavior when a light path travels near a massive object such as the Sun.
These corrections are probably incomplete since at least two of the other posters are in my ignore list, in part because I tired of correcting their frequent misstatements concerning gtr.
OK, shame on me for not reading more than the last half of the thread. I'll try not to make such sweeping statements in future :blushing:
I think people were a little offended by your comments Chris because it just came across as very arrogant that you accused *everyone* of being wrong and you wouldn't even justify your reasoning, instead we would have to ask you for the privlidge of divulging your greater widsom upon us.
In scientific circles, these kind of sweeping statements are highly offensive. But your apology is welcome and I won't hold it against you in future!
Thanks, natski, I appreciate that!
OK, we now return you to the original thread
Sorry i hope you don't mind me posting this here rather than starting a new topic
I believe I'm right in saying that light can't escape a black hole due to it following a pathway through bent space which starts and ends in the black hole.
so if somehow we could survive the trip through the EV of a black hole and then tryed to look out through the EV back into normal space what would we view the EV from inside as being ,bright due to all light trying to escape following pathways back in or black.
If you are picturing null geodesics inside the event horizon, any outgoing ones must fall back without ever getting outside the horizon.
ukmicky said:
So if somehow we could survive the trip through the EV of a black hole and then tryed to look out through the EV back into normal space what would we view the EV from inside as being ,bright due to all light trying to escape following pathways back in or black.
See Andrew Hamilton's website (see my sig) for some pointers, then ask again.
That statement seems a bit too strong.
In general relativity if we have two objects with a given mass-energy the amount of "bending" depends on both objects since each object produces some Weyl curvature. Of course the mass-energy of a photon is almost nothing in comparison with an an object like the Sun, so we conveniently ignore it.
According to GR, each particle in the universe that has either energy or mass must be surrounded by some Weyl curvature. The more energy or mass the more curvature. Thus a higher frequency photon must be surrounded by more Weyl curvature than a lower frequency photon.
oh by the way, is it true that a more massive object will exert a greater gravitational pull?
Hi, S1nG,
Ask yourself: what is the answer in Newtonian gravitation? Given that gtr has a Newtonian limit, that suggests that the answer in gtr should be essentially the same. While in strong fields some elaboration of what you mean by "gravitational pull" would be required, the best short answer is probably "yes".
hellfire said:
I thought this issue about "gravity rainbow" was clarified here:
https://www.physicsforums.com/showthread.php?t=162490
wasn't it?
Who is mentioning "gravity rainbow" here?
Everything that has either mass or energy creates Weyl curvature. More mass or more energy means more curvature. So two photons with a different energy must create a different Weyl curvature, right?
Are you saying I am wrong about that? Then please explain what is wrong.
I am not saying your statement about curvature is wrong. What I am saying is that there will not be observable consequences, because all photons travel on same geodesics in the same space-time. This is what I argued in the other thread.
So what is wrong IMO is your comment "That statement seems a bit too strong" related to Chris Hillman's statement about the Hubble images. My interpretation of this comment of you was that you are referring again to some "gravity rainbow". If you did not then I apologize for bringing this into discussion again.
http://news.softpedia.com/news/Black-Holes-May-Not-Exist-57614.shtml
A new theory based on controversial new calculations says that black holes may not exist, or least not as scientists imagine. It eliminates the existence of the "event horizon" and claims to have solved a paradox in astrophysics.
Current models say that black holes are space objects which have an immense gravitational field that cuts off a region of space from the rest of the universe, trapping all matter and radiation that enters that region. Black holes are thought to form in two ways, as a direct result of the gravitational collapse of a star, or by collisions between neutron stars.
The event horizon, questioned by this theory, is a general term for a boundary in spacetime, defined with respect to an observer, beyond which events cannot affect the observer. Light emitted from inside the horizon can never reach the observer, and anything that passes through the horizon from the observer's side is never seen again.
But the existence of this event horizon contradicts the equations of quantum mechanics, which always preserve information. So, Tanmay Vachaspati and his colleagues at Case Western Reserve University in Cleveland, Ohio, US, performed new calculations to see what happens as a black hole is forming.
They used the functional Schrödinger equation, that describes the space- and time-dependence of quantum mechanical systems, to follow a sphere of matter as it collapses inwards, and predict what a distant observer would see.
The results were surprising, showing that the gravity of the collapsing mass starts to disrupt the quantum vacuum, generating what they call "pre-Hawking" radiation. This Hawking radiation is the current explanation for the preservation of information, a hypothetical flow of particles, which is thought to result from the black holes' event horizons messing with the quantum froth that is ever-present in space.
Vachaspati says that the lost radiation reduces the total mass-energy of the object, making it impossible to get dense enough to form an event horizon and a true black hole. "There are no such things", he says "There are only stars going toward being a black hole but not getting there."
His conclusion is that what really forms in there is a "black star", looking much like a black hole, but never reaching this stage. This idea seems to solve the information paradox, but faces firm opposition from other theoretical physicists.
I really wanted to start a new thread on this interesting topic but since SF brought it up. the paper can be found here
http://arxiv.org/PS_cache/gr-qc/pdf/0609/0609024v3.pdf
and the Bad Astronomer has a post (with several oversimplifications which are readily pointed out in the comments section) here:
http://www.badastronomy.com/bablog/2007/06/19/news-do-black-holes-really-exist/
I think you should create a new topic since it's an interesting issue.
Paste the link here when you do.
