Why does measuring electron spin along one axis change the spin direction?
nurrifat
σx|x>=+|x>
σx|-x>=-|-x>
These equations also follows for σy and σz corresponds states |y> and |z>.
if we measure along axis X then X state vector let it go which means up spin and opposite not go through which means down spin.
and also same for y and z axis.
But,
σx|u>=|d> σx|d>=|u>
σy|u>=i|d> σy|d>=-i|u>
σz|u>=|u> σz|d>=-|d>
these 3 equations can't make any sense to me. i can't draw any physical meaning to these equations.
here 1st equation shows if up spin electron goes through along X axis then after measurement spin wilbe down.but this up electron has to be up for any specific axis??right?? without axis up down is unmeaningfull.isn't it??
opps mayb i complexed the sentence
if we measure along axis X and then if state X goes through it shows electron spin up and if not go then it means electron spin is down.
It seems to me the u and d states are superpositions of the eigenstates of the spin operators. For example, for the first equation one you could say
[itex]\left|u \right\rangle = \frac{1}{\sqrt{2}}\left|+x \right\rangle + \frac{1}{\sqrt{2}}\left|-x \right\rangle[/itex]
[itex]\left|d \right\rangle = \frac{1}{\sqrt{2}}\left|+x \right\rangle - \frac{1}{\sqrt{2}}\left|-x \right\rangle[/itex]
and the equation is okay. Furthermore, I'd just change my labels like so (because what I name each axis is arbitrary)
[itex]x → z[/itex]
[itex]u → +x[/itex]
[itex]d → -x[/itex]
So it looks like the expression you may have see in your textbook.
[itex]\left|+x \right\rangle = \frac{1}{\sqrt{2}}\left|+z \right\rangle + \frac{1}{\sqrt{2}}\left|-z \right\rangle[/itex]
[itex]\left|-x \right\rangle = \frac{1}{\sqrt{2}}\left|+z \right\rangle - \frac{1}{\sqrt{2}}\left|-z \right\rangle[/itex]
Try to see if you can find a superposition of eigenstates that work for the others to make sure you understand. Remember to make sure the states are normalized.
