- 143
This problem is from the 2009 AP C Mechanics Exam. I get the same answers as the posted solutions except for part d. I'm hoping someone can tell me what I'm doing wrong. I'm going to show my work for part a and part c even though I got them correct, because they are used for part d.
A 3.0 kg object is moving along the x-axis in a region where its potential energy as a function of x is given as , where U is in joules and x is in meters. When the object passes the point x = -0.50 m, its velocity is + 2.0 m/s. All forces acting on the object are conservative.
(a) Calculate the total mechanical energy of the object.
[tex] E = KE + PE = \frac{1}{2}mv^2 + 4x^2 \\ <br /> = \frac{1}{2}\left( {3\,{\rm{kg}}} \right)\left( {2\,{\rm{m/s}}} \right)^2 + 4\left( { - 0.5\,{\rm{m}}} \right)^2 =7 J \\ [/tex]
(b) Calculate the x-coordinate of any points at which the object has zero kinetic energy.
(c) Calculate the magnitude of the momentum of the object at x = 0.60 m.
Come up with a formula for velocity as a function of time, using the formula derived in part a. This velocity formula will also be used in part d.
[tex] KE = \frac{1}{2}mv^2 = E - U = 7 - 4x^2 \\ <br /> v = \sqrt {\frac{{14 - 8x^2 }}{m}} = \sqrt {\frac{{14 - 8\left( {0.6} \right)^2 }}{3}} = 1.93\,{\rm{m/s}} \\ <br /> p = mv = \left( 3 \right)\left( {1.93} \right) = 5.77\,{\rm{kg - m/s}} \\ [/tex]
(d) Calculate the magnitude of the acceleration of the object as it passes x = 0.60 m.
acceleration is the derivative of velocity, so take the derivative and set t to 0.6.
[tex] KE\left( x \right) = 7 - U\left( x \right) = 7 - 4x^2 \\ <br /> v\left( x \right) = \sqrt {\frac{{2\left( {7 - 4x^2 } \right)}}{m}} \\ <br /> a\left( x \right) = \frac{1}{2}\frac{2}{m}\left( { - 8x} \right)\left[ {\frac{{2\left( {7 - 4x^2 } \right)}}{m}} \right]^{ - 1/2} \\ <br /> \frac{{ - 8x}}{m}\left[ {\frac{{2\left( {7 - 4x^2 } \right)}}{m}} \right]^{ - 1/2} \\ <br /> \frac{{ - 8\left( {0.6} \right)}}{3}\left[ {\frac{{2\left( {7 - 4\left( {0.6} \right)^2 } \right)}}{3}} \right]^{ - 1/2} =-0.83 m/s^{2} \\ [/tex]
But this is not the same answer as the scoring guide. They get 1.6 m/s2.
I know my velocity formula is correct, because I got the correct momentum in part c. I'm pretty sure I took the derivative correctly. I even verified that with graphing software.
Additionally, I did a double check by using my velocity formula to compute the velocity at 0.6 s and 0.6001 s. The acceleration would then be (v2-v1)/Δx , where Δx is 0.0001. I also get -0.83 m/s2 with this method.
How did I get the same wrong answer using 2 different methods?
Their justification is here: http://apcentral.collegeboard.com/apc/public/repository/ap09_physics_c_mechanics_sgs.pdf
Thanks!
Thanks!
