Why Does My Fortran Code Give an Unclassifiable Statement Error?
3 replies · 3K views
gabforse
Hey so I'm getting the error message:
Code:
Euler_Method.f90:43.1:
fun=(c)(1-c)/(d+2)
Error: Unclassifiable statement at (1)
And here is my code:
Fortran:
PROGRAM Euler_Method
! The purpose of this program is to read in endpoints, initial
!conditions, and a stepsize from the user, and then use Euler's
!method to approximate the value of the function f(x,y)=y(1-y)/x+2
!over that interval.
IMPLICIT NONE
REAL:: alpha, h, inr, x, y
INTEGER:: i, b
WRITE(*,*) "Please enter the rightmost endpoint"
WRITE(*,*) "of the interval over which you wish to find an"
WRITE(*,*) "approximation of f(x,y). (Must be integer value)"
READ(*,*) b
WRITE(*,*) "Please enter x of y(x)."
READ(*,*) inr
WRITE(*,*) "Please enter y of y(x)."
READ(*,*) alpha
WRITE(*,*) "Please enter the stepsize."
READ(*,*) h
DO i=0, b
y=2
x=0
x=x+h*fun(x,y)
y=y+h
!Output at each step
WRITE(*,*) x
END DO
WRITE(*,*)"The final approximation is:",x,"."
CONTAINS
REAL FUNCTION fun(c,d)
IMPLICIT NONE
REAL, INTENT(in):: c,d
fun=(c)(1-c)/(d+2)
RETURN
END FUNCTION fun
END PROGRAM Euler_Method
fun=(c)(1-c)/(d+2)
You forgot to add a "*" to multiply. It should be "fun=(c)*(1-c)/(d+2)".
fun=(c)(1-c)/(d+2)
IMPLICIT NONE
INTEGER:: i, b
READ(*,*) b
READ(*,*) inr
READ(*,*) alpha
READ(*,*) h
DO i=0, b
y=2
x=0
x=x+h*fun(x,y)
y=y+h
WRITE(*,*) x
END DO
CONTAINS
IMPLICIT NONE
fun=(c)(1-c)/(d+2)
RETURN
END FUNCTION fun
fun=(c)(1-c)/(d+2) should be fun=(c)*(1-c)/(d+2), I think.
EDIT: lol
@gabforse, Krylov and Samy_A both figured out the reason for your compile error. The lesson for you is that you can't use mathematics or physics notation in programming languages. To denote multiplication, you can't just put symbols next to each other, as in ab; you have to explicitly add the multiplication operator *.
Another difference the new programming students stumble on is that in mathematics, = means "equal to." In many programming languages, = is used to assign a value to a variable, and a different operator is used to compare two values for equality. Fortran uses .EQ., and newer Fortran versions use == as well (taking a cue from C, C++, and others).
