Why Does My Java Program Display the Menu Before Adding or Removing Items?
  • Context: Comp Sci
  • Thread starter Thread starter schapman22
    Java List Program
3 replies · 3K views
schapman22
I am supposed to write a program that uses a bag of strings to keep track of a list of chores. The user can add, remove, view, etc. items on the list.
When I run the program and i choose an option from the menu. It displays the menu again before you can add or remove the item you want. I can't figure out why it is doing this. Thank you in advance.
Code:
 * To change this template, choose Tools | Templates
 * and open the template in the editor.
package edu.colorado.collections;
import java.util.Scanner;
 * @author Scott
public class Main
     * @param args the command line arguments
    public static void main(String[] args)
        ArrayBag<String> choreList = new ArrayBag<>();
        int entry;
        String chore;
        boolean endProgram=false;
        Scanner keyboard = new Scanner(System.in);
        while(!endProgram)
            System.out.println("Choose an option from the following list.");
            System.out.println();
            System.out.println("Add item to list(press 1)");
            System.out.println("View number of items on list(press 2)");
            System.out.println("View a list of chores(press 3)");
            System.out.println("Remove an item from the list(press 4)");
            System.out.println("Exit program(press 5)");
            entry = keyboard.nextInt();
            switch(entry)
                case 1: System.out.println();
                    System.out.println("What would you like to add?");
                    chore = keyboard.nextLine();
                    choreList.add(chore);
                    break;
                case 2: System.out.println();
                    System.out.println("There are " + choreList.size() +
                        " items on your list.");
                    break;
                case 3: System.out.println();
                choreList.printList();
                    break;
                case 4: System.out.println();
                    System.out.println("Which item would you like to remove?");
                    choreList.remove(chore);
                    break;
                case 5: endProgram=true;
                    break;
I don't know Java, but took a quick look at keyboard.nextInt() and keyboard.nextLine(). The issue seems to be the way these functions work. keyboard.nextInt(), will skip any whitespace until it reaches the next string of digits and in this case it stops just before a new line character that the user already entered. Then when you call keyboard.nextLine(), it sees the newline character that was already entered and returns with a null string, causing the issue you're having.
The fix is to add keyboard.nextLine() immediately afterthe keyboard.nextInt(), in which case the second call to keyboard.nextLine() will get the data you want.
The reason this isn't a problem when using keyboard.nextInt() twice in a row is that nextInt() considerd newline to be the same as any whitespace character, and just skips past it to look for another string of digits, which will result in getting another line of input from the user.
