Why does perpendicular force not change an object's speed?
46 replies · 6K views · last reply
Faiq
If a force acts on an object perpendicular to its velocity, why does the speed remains unchanged? Wouldn't the force give rise to a vertical component of velocity on the object and thus increase the speed of the object?
It would change the direction of the velocity vector, but not its magnitude.
It provides a little change of velocity, and if the force keeps acting on the object it may do the constant-speed circular motion, for it doesn't give the object acceleration parallel to itself.
That's what the calculus tells you. If you kept accelerating in the same direction, then you would change the speed. But in a circular motion, you constantly change the direction of the acceleration. If you consider an infinitesimal time-step of size epsilon, the amount of speed change is proportional to epsilon squared. So, in the limit of epsilon->0, there is no speed change.
How should the speed change, increase or decrease?
"Wouldn't the force give rise to a vertical component of velocity on the object"- It would, but without changing the magnitude of the velocity vector, and thus only changes the direction of velocity.
To prove this, take P to be the power of the force delivered when the object has velocity V,
Then P= (Force vector).(Velocity vector) at that instant, but since Force and velocity are perpendicular, P would be 0.
Hence work done by the force would be 0, and hence change in Kinetic energy would be zero.Thus, the speed would remain same, but the direction of velocity changes.
I know the velocity is changing because of the direction. Let's suppose the object is stationary. If the force acts on it in any direction it will give rise to a SPEED in that direction. Why can't we apply the same analogy in circular motion? More importantly, why isn't force giving rise to a component of SPEED in any direction?
Because you cannot apply a force perpendicularly to a velocity of zero.
Speed doesn’t have components, it's a scalar.
Energy considerations are often a good way into solving problems and explaining things.
Here's something to think about. You are thinking that, perhaps, speed should increase. If the speed increased then so would the Kinetic Energy. That would involve the need for Energy to be put into the system. (in the absence of friction, circular motion will carry on forever) The only way that energy to be put in would be in the form of Work, which is Force times the distance moved along the line of action of the force. The Force would be the centripetal force and the distance (when moving in a circle) would be Zero (radius doesn't change). So no work is done and, hence, the Kinetic Energy (and consequently the speed) can't be increasing.
You may be imagining a long, narrow right triangle with the velocity of the object as the long side, the incremental velocity produced by acceleration as the short side and the resulting final velocity as the hypotenuse. That picture is problematic for three reasons (or one reason expressed in three ways perhaps).
1. In the limit as the size of the interval goes to zero, the hypotenuse is the same length as the initial velocity (mentioned by Khashishi)
2. The acceleration is in a constantly changing direction. It's not really a right triangle because the current acceleration not always at right angles to the initial velocity. The short side is a circular arc whose direction is ambiguous.
3. The picture is prejudiced toward progress forward in time. If you extend it backwards to a tiny prior interval, the initial velocity is the hypotenuse, the increment is the short side and the final velocity is the long side. Rather than speeding it up, the mental picture says that the acceleration should be slowing the object down.
It is not changing speed because at no time is there a component of force in the direction that it is moving.
The force will be drawing the object towards the center. So as soon the object will change direction and try to orient towards the center it would've traveled a small distance in the direction of force.
So?
I am not talking about the triangle because when the angle is very small it can resemble a right triangle. What I am asking is whenever we apply a force the objects is accelerated in that direction. As a result the magnitude of velocity must change. And if it isn't changing then it must be because the other component of the velocity is decreased. So what is decreasing the other component?
Chestermiller said:
So?
There will be a gain in energy which could compensate for the increase in kinetic energy.
Yes it is but the radius does not decrease (it doesn't get any closer to the centre) so no Work is done. If you were sitting at the centre of rotation and going round at the same rate, the string you were holding would not be changing length and the tension in the string would be the same. No change in energy so no change in speed,
You are basically asking how the Calculus method can be used to establish the v2/r formula. If you understand any calculus then the answer is easy. If not then it may be best to accept it and find out later how to derive the formula. Physics will be full of formulae that you cannot yet derive but you are happy to accept the results - so don't feel bad about it. An arm waving explanation is not really a 'proof' in any case.
But the object does travel in the direction of force so according to Energy = Force * Displacement there could be an increase in energy. Btw that wasn't my question.
My question is simply why is the magnitude of velocity not changing even though a force is acting on the body?
I am going to list why I am confused about this.
1. If a force acts on an object, the object is accelerated. What I think it means is it gets velocity in that direction and the other components of velocities on that object are not influenced by that force. (Components of velocity perpendicular to the force)
2. Since an object is accelerated and gains a "new" velocity in that direction, the resultant velocity will be bound to be greater
How can there be any change in the Energy if the motion is not speeding up or slowing down?
[or vice versa].
I can comprehend calculus but calculus wasn't used to derive the formula v2/r (when I was taught)
This was how it was derived
dx = dv/v (assuming that angle x is very small )
vdx = dv
v dx/dt = dv/dt
Then by substituting the necessary equation we arrived at a = v2/r
No. It does not. Not at all. It travels now in the direction of the force a moment ago, but that is not the same thing.
How can it, if the string doesn't get shorter?
At this time, I think you need to find reasons why you may be wrong, rather than in still wanting to be right. There is something in your head that is not letting you accept the 'correct' answer. :smile:
vdx = dv
v dx/dt = dv/dt
How can you say that calculus was not used? Your last post was full of it.
Okay I have a thought experiment. Let's say an object A and B are traveling at constant speeds. Both objects are subjected to a same force for a very small time. The force is centripetal in nature to A but is just a normal resultant force to B. So after that time will both objects travel at different velocities, as the A's velocity will remain unchanged? Why is that contradiction arising?
A force with a constant direction is not centripetal.
Direction for A is not constant, but the time is very small
The direction is nearly constant. But that nearly is exactly the problem. The resulting speed is nearly unchanged by a constant force. If you account for the fact that the direction is changing then the resulting speed is exactly unchanged.
Faiq:
Please correct me if I am wrong.
I think what you are asking is the following: If a mass is traveling in a horizontal circle on a frictionless table, tethered by a string at the center of the circle, is a constant speed for the mass consistent with the Newton's 2nd law force balances on the mass in the x and y directions (Cartesian coordinates) for the entire motion around a circle? In other words, is there as solution to Newton's 2nd law equations consistent with constant speed motion of the mass in a circle tethered at the center with a string (even if one uses Cartesian coordinates to analyze the motion)?
Does this capture the essence of what you are asking?
What is the difference between the motions? At any instant, the object moving in a circle would travel in a straight tangential line if the force were removed (there is no 'memory' of what it's doing. A and B would be deflected by exactly the same amount.
You need to understand how the calculus can be used in situations like this. You have to go through the derivation with extreme care in order to work out the limits for the quantities are as δt → 0 when you start the calculation using finite time and small straight line motion. Some quantities are unchanged and some go to zero (as with all differentiation from first principles when you start with tan(θ) = δy/δx etc. etc.) You quoted dx/dt but how was it derived from scratch? Understand that and your questions and worries will be answered. It was second year A level for me, way back and Mr. Worthington was extremely meticulous about it all.
Chestermiller said:
Faiq:
Yes that's what I am trying to ask
