Why Does Substitution Change the Integral's Bounds?
  • Context:
  • Thread starter Thread starter karush
    Form Integral
6 replies · 2K views
karush
MHB
$\displaystyle\int_0^\frac{1}{2}\frac{4}{1+4t^2}dt$
my first step with this was
$\displaystyle4\int_0^\frac{1}{2}\frac{1}{1+4t^2}dt$
thot this could be a log rule. but doesn't seem to fit into that
the answer to this is $\frac{\pi}{2}$
Note that
\[\int_0^{\frac{1}{2}}\frac{4}{1+4t^2}\,dt = 4\int_0^{\frac{1}{2}}\frac{1}{1+(2t)^2}\,dt\]
Make the substitution $u=2t$ to get
\[2\int_0^1\frac{1}{1+u^2}\,du\]
This should integrate to something familiar.
I hope this helps!
Just a note on top of what Chris L T521 wrote, the solution will not contain a logarithm. It requires trig substitution which you might not have seen yet. I don't want you to keep pursuing the idea on this that the answer will contain a logarithm.
ok saw using trig substitution...
As a further hint, observe that if we let:
$\displaystyle u=\tan(v)$
then:
$\displaystyle du=\sec^2(v)\,dv=(1+\tan^2(v))\,dv=(1+u^2)\,dv\, \therefore \,dv=\frac{1}{1+u^2}\,du$
Now, rewrite the definite integral in terms of v, making sure to also rewrite the limits of integration in terms of v.
presume we are referring to the base form of.
$\displaystyle \int\frac{dx}{x^2+a^2}=\frac{1}{a}tan^{-1}\left(\frac{x}{a}\right)$
BTW why is there a 1 on the interval
Chris made a substitution from the variable $t$ to the variable $u$. Since these are not the same, the bounds won't stay the same. If the interval for variable $t$ is $[0,1/2]$ and $u=2t$ then the interval in terms of $u$ is $[2*0,2*1/2]$ or simply $[0,1]$.
When doing substitution problems you can either rewrite the interval in terms of the new variable or solve the indefinite integral and then rewrite everything in terms of the first variable. Just make sure you apply the correct bounds.
