Why does switching the order of integration simplify double integrals?
  • Topic:
  • Thread starter Thread starter harpazo
    Integrals
9 replies · 3K views · last reply
harpazo
I just started learning double integrals. It is interestingly difficult. I know that switching dxdy to dydx can simplify the integration. I am not too clear why switching dxdy to dydx or vice-versa can make things easier.
Let S = integral symbol
SS [x/(1 + xy)] dxdy
Which is easier: SS [x/(1 + xy)] dxdy or
SS [x/(1 + xy)] dydx?
The region R is given to be:
{(x, y)| 0 less than or equal to x less than or equal to 1, 0 less than or equal to y less than or equal to 1 }.
What's the difference?
Hi Harpazo,
What is your region of integration?
Euge said:
Hi Harpazo,
I forgot to include the region. I will now edit the question.
- - - Updated - - -
Euge said:
Hi Harpazo,
The question has been edited.
Isn't the region of integration just a square? Since there's no variation in either variable there won't be any difference in reversing the order of integration...
To integrate with respect to y first, let u= 1+ xy. Then du= xdy . When y= 0 u= 1 and when y= 1, u= 1+ x. The first integral becomes [tex]\int_1^x \frac{du}{u}du= \left[ln(u)\right]_1^x= ln(x+1)[/tex]. We now have [tex]\int_0^1 ln(x+1)dx[/tex].
The other order is a little harder because of that "x" in the numerator.
HallsofIvy said:
To integrate with respect to y first, let u= 1+ xy. Then du= xdy . When y= 0 u= 1 and when y= 1, u= 1+ x. The first integral becomes [tex]\int_1^x \frac{du}{u}du= \left[ln(u)\right]_1^x= ln(x+1). We now have [tex]\int_0^1 ln(x+1)dx[/tex].<br /> <br /> The other order is a little harder because of that "x" in the numerator.[/tex]
[tex] <br /> Part of your LaTex reply did not display.[/tex]
I've edited that post to correct the problem.
What's the difference between integrating over dxdy as opposed to dydx for this problem?
What Prove It was trying to say above is that it makes no difference, because the region over which you are integrating is rectangular. If you have a triangle, or some region where $x$ and $y$ are interacting, then it can make a great deal of difference, and interchanging the order of integration is one of the standard tricks you should have in your toolbox.
Thank you. I know it is a great tool to have in terms of multiple integrals. It takes a complicated or almost impossible double integral, in this case, and makes it easy to integrate.
