- 29,795
- 21,610
It's all mathematics.symbolipoint said:I was not referring to Statistics instruction or to practices there. I was referring to instruction in Trigonometry.
So what is this? Cultural difference among the various universities' departments?Orodruin said:I have not called anyone ”my professor” in decades. As a university professor I’d happily argue with the people making such bad standards.
And I see your reaction, but as I say that is (or for sure was) the truth, not kidding. Professors were often enough, busy. Their graders were busy. If a certain form of an answer was specified, then that was what we needed to use. If not followed, then less credit for an exercise. If answer in the back of book was in a different form, then we knew what to do. If grader checks students homework and the work did not conform to a specified outline, then either less credit or no credit; if professor gave a test or quiz and said, "Do not do computations! Give answer in symbolic form only!", then students who did not follow received no credit. If prof. gave test or quiz and said, "round all answers to the nearest tenths place", then any answer not so reported received no credit. If computer science professor expected exercise assignments turned into include data table and flow-diagrams, he meant it. When students were given low scores on such assignments and tried to ask the professor about this, students were cut-off from receiving those discussions or explanations. Most of these professors were not lenient.symbolipoint said:Still the practices as they may be conducted or expected is the truth. Try arguing about this with your professors and see how much progress you make.
Generally I have little pity left over for this. Yes, I am generally quite busy, but quality in teaching is one of the university's main pillars and students should expect better.symbolipoint said:Professors were often enough, busy. Their graders were busy.
It seems to me that, if what you say is true, some of your professors were suffering from psychological disorders. Which may be a good reason not to be unduly influenced by them and not to promote their somewhat sadistic methods or excessive pedantry as a productive way to teach mathematics.symbolipoint said:And I see your reaction, but as I say that is (or for sure was) the truth, not kidding. Professors were often enough, busy. Their graders were busy. If a certain form of an answer was specified, then that was what we needed to use. If not followed, then less credit for an exercise. If answer in the back of book was in a different form, then we knew what to do. If grader checks students homework and the work did not conform to a specified outline, then either less credit or no credit; if professor gave a test or quiz and said, "Do not do computations! Give answer in symbolic form only!", then students who did not follow received no credit. If prof. gave test or quiz and said, "round all answers to the nearest tenths place", then any answer not so reported received no credit. If computer science professor expected exercise assignments turned into include data table and flow-diagrams, he meant it. When students were given low scores on such assignments and tried to ask the professor about this, students were cut-off from receiving those discussions or explanations. Most of these professors were not lenient.
Refering to the quote of message in post #36,PeroK said:It seems to me that, if what you say is true, some of your professors were suffering from psychological disorders. Which may be a good reason not to be unduly influenced by them and not to promote their somewhat sadistic methods or excessive pedantry as a productive way to teach mathematics.
The example you gave would often be a factorization fact exercise for some Algebra 1 students who may have not yet been in Algebra 2; and most typically the students would learn about general solution for quadratic equation in Algebra 2. So that example could be a situation in which instructor expects the use of factorization and not use general formula solution.Office_Shredder said:Or let's say you have solve x2−9=0. Your student carefully applies the quadratic formula and writes
0±0+4∗92∗1That's their final answer. You have to assign this answer a grade that reflects their understanding of the concepts of Algebra. What do you give them? An A? That's what people are kind of arguing for here.
Write all answers as rationalized fractions is strict, but at this level you need a policy to demonstrate if people understand what they've written or if they're just regurgitating symbols back at you.
Just copying or quoting a section of text that contains LaTeX doesn't worksymbolipoint said:(note: the formatting for part of the quoting did not work properly, to show that quadratic formula solution of your example.)
This discussion of whether equivalent answers are allowed or not puts me in mind of Randall Munroe's response after a lengthy and fruitless discussion with a Verizon customer service drone over a bill for $.002. In case the name is not familiar, he's the author of the XKCD blog/cartoons.Office_Shredder said:Or let's say you have solve
##x^2-9=0##. Your student carefully applies the quadratic formula and writes
##\frac{0 \pm \sqrt{0+4*9}}{2*1}##
Yet in post #40, you did make it work. How?Mark44 said:Just copying or quoting a section of text that contains LaTeX doesn't work
I quoted the section of text up to the start of the LaTeX, and then opened the edit window to copy the unrendered LaTeX and paste it onto the end of what I had quoted. As a mentor I'm able to edit posts, but that capability probably isn't available to regular members.symbolipoint said:Yet in post #40, you did make it work. How?
Perhaps it's an idea for you to go round all the threads on PF and edit the absurd and inexplicable instances of ##\dfrac 1 {\sqrt 2}##? Since it is such an abomination to those with heightened mathematical sensibilities.Mark44 said:As a mentor I'm able to edit posts, but that capability probably isn't available to regular members.
No, thanks. I don't have a problem with ##\frac 1 {\sqrt 2}## -- I was just offering a plausible explanation for why elementary algebra textbooks spend so much time on simplifying these types of expressions.PeroK said:Perhaps it's an idea for you to go round all the threads on PF and edit the absurd and inexplicable instances of ##\dfrac 1 {\sqrt 2}##? Since it is such an abomination to those with heightened mathematical sensibilities.
No wonder I'm a fan of the Houston Eulers.MidgetDwarf said:high school algebra text are based of Euler's Elements of Algebra. Where Euler does not rationalize the denominator. Who are we to argue wit Euler.
Either way, neither of these denominators is rationalized.PeroK said:To the best of my knowledge, no one writes ##\dfrac{\sqrt \pi}{\pi}## instead of ##\dfrac 1 {\sqrt \pi}##.
Square roots appear in the denominator all over statistics, quantum mechanics, and the gamma factor in SR!
Ah, so they are both wrong!SammyS said:Either way, neither of these denominators is rationalized.
##\dfrac{\sqrt \pi\,}{\pi}## , ##\dfrac 1 {\sqrt \pi\, }##
Right. It should be ##\frac{\sqrt{154}}{22}##PeroK said:Ah, so they are both wrong!![]()
##\dfrac{1/\sqrt\pi}{1}##SammyS said:Either way, neither of these denominators is rationalized.
But you still have a denominator (in the numerator fraction) that is irrational.Orodruin said:##\dfrac{1/\sqrt\pi}{1}##
Fixed
You’re welcome to rationalise itMark44 said:But you still have a denominator (in the numerator fraction) that is irrational.
This is the way it was presented in the precalculus books I taught from in the '70s. I liked it because it made the pattern: ##sin(0)=\sqrt{0}/2; sin(30)=\sqrt{1}/2; sin(45)=\sqrt{2}/2; sin(60)=\sqrt{3}/2; sin(90)=\sqrt{4}/2##. The students seemed to like that.symbolipoint said:Clebsch-Gordan not my areaMy statement (post #7) was about Trigonometry instruction; not other topics.
Interesting representation in keeping with denominator of 2. I really never saw it done like that.FactChecker said:This is the way it was presented in the precalculus books I taught from in the '70s. I liked it because it made the pattern: ##sin(0)=\sqrt{0}/2; sin(30)=\sqrt{1}/2; sin(45)=\sqrt{2}/2; sin(60)=\sqrt{3}/2; sin(90)=\sqrt{4}/2##. The students seemed to like that.
But teaching conventions like that may have changed a lot since the '70s.
It's a convention, nothing more. Real numbers have reciprocals too!romsofia said:so, yes, your teacher is correct to take points off your test because you're technically wrong to keep it as ##\frac{2}{\sqrt{5}}##.
I would guess none. If that is all it takes to turn someone off mathematics, he wasn't into it in the first place.PeroK said:How many students are turned off mathematics by this sort of pointless pedantry?
