pinball1970
2025 Award
- 3,876
- 6,209
- TL;DR
- I would like a better understanding of the glow in the dark mechanism. Why are photons emitted slowly?
A question about Glow in the dark
Fluorescent chemicals can activated by UV, absorb energy at short wavelength then emit photons the human eye can see in the visible spectrum.
Stop the UV source, the visible light emission stop. You cannot see anything. Electron returns to non-excited state photon emitted eye detects it.
With Glow in the dark chemistry applied to textiles, stimulate with UV then stop the light source and the material glows for a few minutes.
My question is, as is with normal colour and fluorescence the effect stops immediately the light is switched off.
Why does the effect linger with Glow in the dark? Why are the emissions so much slower not instant the moment the light is switched off?
I have the read the wiki page regarding, forbidden states including,
An example is phosphorescent glow-in-the-dark materials,[2] which absorb light and form an excited state whose decay involves a spin flip, and is therefore forbidden by electric dipole transitions.
The result is emission of light slowly over minutes or hours.”
This transition state delays the release of a photon? Why does the material glow straight away? No delay? What is the difference between immediate photons and later photons?
I looked up “spin flip”
https://arxiv.org/abs/1603.02572
“Rashba effect due to a perpendicular electric field or a dielectric substrate, gives a negligible radiative decay rate (about 107 times slower than that of bright excitons).
Spin flip due to Zeeman effect in a sufficiently strong in-plane magnetic field can give a decay rate comparable to that due to the intrinsic interband spin-flip dipole.”
Is the sort of thing I should be looking at?
Intuitively in terms of a physical process is this like heating a material which releases the heat/energy slowly in line with the environment? Or is this more like radioactive decay?
