Why does the effectiveness of low-Z shielding increase with photon energy?
The effectiveness of low-Z shielding, such as concrete, increases with photon energy due to the predominance of the Compton Effect at higher energies. For instance, less concrete is required to achieve the same lead equivalent at 500 keV compared to 200 keV. This phenomenon is attributed to the mass attenuation coefficient decreasing with increasing gamma energy, while the mass energy-absorption coefficient shows a slight increase between 0.2 to 0.5 MeV. The elemental absorption edge of lead at approximately 88 keV also plays a significant role in this behavior, as the photo-ionization cross-section decreases with higher photon energies, aligning more closely with that of concrete.
  • Understanding of Compton Effect in photon interactions
  • Knowledge of mass attenuation and mass energy-absorption coefficients
  • Familiarity with lead and concrete as shielding materials
  • Basic principles of gamma radiation and its energy levels
  • Research the Compton Effect and its implications for low-Z materials
  • Study the mass attenuation coefficients for various materials at different photon energies
  • Examine the cross-section data for lead and concrete at varying gamma energies
  • Explore regulations and guidelines for shielding in medical applications, particularly in PET departments
Physicists, radiation safety officers, and engineers involved in designing shielding for medical imaging facilities, particularly those working with PET technology and gamma radiation.
taffer33
Concrete for example - you need less concrete to obtain the same lead equivalent for photon energy 500 keV than for 200 keV. What is the reason for this?
Ok, I did some thinking ;) Is it because for low Z materials, photons with higher energy interacts with absorber almost by Compton Effect only? And Compton is independent of atomic number.
Can one show some calculations or data to support the assertion that "you need less concrete to obtain the same lead equivalent for photon energy 500 keV than for 200 keV." The mass attenuation coefficient continually decreases as a function of gamma energy, although the mass energy-absorption coefficient increases slightly between 0.2 to 0.5 MeV. But this is misleading, since the 500 keV gamma will scatter to a lower energy, and that photon will scatter, and so on.
https://physics.nist.gov/PhysRefData/XrayMassCoef/ComTab/concrete.html
https://archive.org/details/jresv38n6p665
it's in this article for example
I asked this question as I was reading about shieldings in PET departments, where they suggest lead/concrete ratio 12-15, while ratio for 150 keV X-Ray is 80... (These are example regulations from my country).
It's a property of lead rather than a property of the concrete.
Have a look at the cross-section per unit mass of lead below, and compare it to the same for concrete:
Lead has an elemental absorption edge at around 88keV, so the cross-section for lead is massively increased when the photon energy, as the photon energy is further increased, the photo-ionisation cross-section due to that particular energy-level decreases, becoming more comparable to that of the concrete.
  • · Replies 17 ·
  • · Replies 21 ·
