Why does the golden ratio appear when solving trig equations?
17 replies · 6K views · last reply
dimension10
[tex]\sin \theta = \cos \theta[/tex]
\theta=\frac{\pi}{4}
2.
[tex]\sin \theta = \tan \theta[/tex]
[tex]\theta = 0[/tex]
3.
[tex]\cos \theta = \tan \theta[/tex]
[tex]\theta =\arcsin (\varphi -1)[/tex]
4.
[tex]\sin \theta = \csc \theta[/tex]
[tex]\theta = \frac{\pi}{2}[/tex]
5.
[tex]\sin \theta =\sec \theta[/tex]
[tex]\theta[/tex] does not exist.
6.
[tex]\sin \theta =\cot \theta[/tex]
[tex]\theta = \arccos (\varphi -1)[/tex]
7.
[tex]\cos \theta =\csc \theta[/tex]
8.
[tex]\cos \theta =\sec \theta[/tex]
[tex]\theta=0[/tex]
9.
[tex]\cos \theta = \cot \theta[/tex]
[tex]\theta=\frac{\pi}{2}[/tex]
10.
[tex]\tan \theta =\csc \theta[/tex]
[tex]\theta =\arccos(\varphi-1)[/tex]
11.
[tex]\tan \theta = \sec \theta[/tex][tex]\theta=\frac{\pi}{2}[/tex]
12.
[tex]\tan \theta = \cot \theta[/tex]
[tex]\theta=\frac{\pi}{4}[/tex]13.
[tex]\csc \theta =\sec \theta[/tex]
14.
[tex]\csc \theta =\cot \theta[/tex]
15.
[tex]\sec \theta =\cot \theta[/tex]
[tex]\theta=\arcsin (\varphi - 1)[/tex]
I used quadratic equation for some equalities. Which showed that the golden ration was involved. But my question is "geometrically, why?"
Mathematics news on Phys.org
Hi!
Interesting question. I have always been fascinated by the golden ratio which keeps appearing at places where you least expect :smile: Will have to think about this one.
Oops. There was a LaTeX error.
1.
2.
3.
4.
5.
6.
7.
8.
[tex]\theta=0[/tex]
9.
10.
11.
12.
13.
14.
15.
IIRC, [itex]\cos\frac{\pi}{5} = \frac{\phi}{2}[/itex]. That's related to the pentagon. Hmm...
Here are the hyperbolic equalities.
1.
[tex]\sinh x = \cosh x[/tex]
[tex]x= \infty[/tex]
2.
[tex]\sinh x =\tanh x[/tex]
[tex]x=0[/tex]
3.
[tex]\cosh x =\tanh x[/tex]
[tex]{x}_{1}=\frac{- \arcsin (\frac{\sqrt{3}}{2}+\frac{i}{2})}{i}[/tex]
[tex]{x}_{2}=\frac{- \arcsin (\frac{\sqrt{3}}{2}-\frac{i}{2})}{i}[/tex]
4.
[tex]\sinh x = csch x[/tex]
[tex]x=arcsinh 1[/tex]
5.
[tex]\sinh x = sech x[/tex]
[tex]x=\frac{\ln (2 \varphi +1)}{2}[/tex]
6.
[tex]\sinh x =\coth x[/tex]
[tex]x=\frac{\arccos(1-\varphi)}{i}[/tex]
7.
[tex]\cosh x =csch x[/tex]
[tex]x=arcsinh \sqrt{\varphi-1}[/tex]
8.
[tex]\cosh x =sech x[/tex]
[tex]x=0[/tex]
9.
[tex]\cosh x =\coth x[/tex]
[tex]x=arcsinh (\varphi - 1)[/tex]
10.
[tex]\tanh x = csch x[/tex]
[tex]x=arccosh (\varphi - 1)[/tex]
11.
[tex]\tanh x =sech x[/tex]
12.
[tex]\tanh x = \coth x[/tex]
[tex]x=\infty[/tex]
13.
[tex]csch x =sech x[/tex]
[tex]x=arctanh 1[/tex]
14.
[tex]csch x =\coth x[/tex]
[tex]x=0[/tex]
15.
[tex]sech x = \coth x[/tex]
[tex]x=arcsinh (\varphi -1 )[/tex]
Still a lot of golden ratios.
Ok, so that's why its related...
6.
This one doesn't look right. I'm pretty sure there should be a real solution there.
After just doing some calculations I'm pretty sure that the solution to 6. should be
[tex]x = \pm \, \cosh^{-1} \phi[/tex]
BTW. Inverse hyperbolics can usually be alternatively represented using logs.
You mean arccosh right?
That works too. But my solution also works. I converted sinh x to - i sin i x and it works.
And by the way, what is the LaTeX code for arcsinh, arccosh, sech, cosech?
Two things:
1) The inverse hyperbolic functions are not "arc(whatever)". They are actually "ar(whatever)". i.e., arsinh(x), arcosh(x), artanh(x), etc.
2) I don't believe there is latex commands for most of these. You typically have to use \mbox{arsinh}(x), etc.
Tests:
[itex]\arsinh(x), \arcosh(x), \artanh(x), \sech(x), \csch(x)[/itex]
Check to make sure latex doesn't use the misnamed versions:
[itex]\arcsinh(x), \arccosh(x)[/itex]
Mute said:
Two things:
Ok, thanks.
Tests:
Oh. So it can be written as [tex]\mbox{arsinh}(x)[/tex]?
Yep. If you're writing in an actual latex document, you can always define new commands so that you don't always have to use mbox.
For example, writing
\newcommand{\arsinh}{\mbox{arsinh}}
in the top before the document begins would let you use \arsinh as a command.
Yes the "f^{-1}" notation is still very commonly used for both trig and hyp-trig functions. See for example : http://mathworld.wolfram.com/InverseHyperbolicFunctions.html
Yes I know that it works but I was considering being consistent with your original post in which you were clearly only considering real solutions.
For example :
5.
There are no real solutions to that equation, but there definitely are complex solutions. Basically I was pointing out that the expression in question doesn't evaluate to a real number, whereas previously you seemed to be only considering reals.
I was just clarifying to make sure it was an inverse hyperbolic function and not something like sin^2...
Are you sure there are complex solutions?
[tex]\sin \theta =\frac{1}{\cos \theta}[/tex]
[tex]\sin \theta \cos \theta =1[/tex]
As the maximum of both [tex]\sin \theta[/tex] and [tex]\cos \theta[/tex] is 1, both [tex]\sin \theta[/tex] and [tex]\cos \theta[/tex] should be 1. Then as [tex]\cos \theta=1[/tex], [tex]\frac{\theta}{\pi}[/tex] is a whole number, thus [tex]\sin \theta=0[/tex]. But we have earlier said that [tex]\sin\theta=1[/tex] and [tex]1 \neq 0[/tex] so there is no value of theta.
