Why does the gradient vector point straight outward from a graph?
2 replies · 4K views
gikiian
A gradient vector points out of a graph (or a surface in 3D case). Locally, it makes an angle of 90 degrees with the graph at a particular point. Why is that so?
Thanks.
Hi.
The gradient vector measures the change and direction of a scalar field. The direction of the gradient is expressed in terms of unit vectors (in 3-dimensions, say) and points in the direction of the greatest rate of increase of the scalar field, and whose magnitude is the greatest rate of change.
Another way of looking at it is that the "directional derivative", the rate of change of function f(x,y,z) as you move in the direction of unit vector [itex]\vec{v}[/itex], is given by [itex]\nabla f\cdot\vec{v}[/itex]. If the function is given implicitely by f(x,y,z)= 0 (or any constant, then on the surface f is a constant and so it derivative is 0 in any direction tangent to surface: the dot product of [itex]\nabla f\cdot \vec{v}[/itex], with [itex]\vec{v}[/itex] tangent to the surface, is 0 so [itex]\nabla f[/itex] is perpendicular to the surface.
