Why Does the Sky Appear Blue During the Day?
  • Context: High School
  • Thread starter Thread starter vincikai
    Sky
64 replies · 15K views
vincikai
okay, i forgot why is the sky blue again? :confused:
Scattering. The refractive index of the atmosphere tends to spread the bluish part of the spectrum around, while blocking other parts of it. That's a pretty sad explanation, but I hope that it will hold you until the big guns come around. Welcome to PF!
The sky is blue because we kind of live at the bottom of a rainbow, only it's an "atmosphere bow".
Look at the colours on a rainbow. Blue is at the bottom. That's been refracted most. You can see the other colours that get refracted less at dusk or dawn. Sometimes you can even see what's called "the green flash".
http://mintaka.sdsu.edu/GF/
It's blue again because the sun rose this morning.
I love this logic!:smile:
So, how high would you have to climb for the sky to be green or yellow?
If we dug a hole, and looked up from the bottom, would we see an Indigo or Violet sky?
Dave, it's a nice simple analogy. Hits the spot, you know?
http://math.ucr.edu/home/baez/physics/General/BlueSky/blue_sky.html
"If shorter wavelengths are scattered most strongly, then there is a puzzle as to why the sky does not appear violet, the colour with the shortest visible wavelength. The spectrum of light emission from the sun is not constant at all wavelengths, and additionally is absorbed by the high atmosphere, so there is less violet in the light. Our eyes are also less sensitive to violet. That's part of the answer; yet a rainbow shows that there remains a significant amount of visible light coloured indigo and violet beyond the blue. The rest of the answer to this puzzle lies in the way our vision works..."
dave got a pretty good point i think. Isnt the sky blue because the air molecules reflects mostly blue light? that will say: lightbeams with the wavelength that we see as the color "blue"
Have a look at this picture of a rainbow, Doc. The blue is the bottom stripe. The red and yellows of dawn/dusk are at the top. And there isn't much green.
http://www.sundog.clara.co.uk/rainbows/images1/shim18.gif
Farsight said:
Yep. Look at the photo above.
Nope, you cannot see ultra violet light. However, you have see visible violet light - [itex]\lambda ~ 400nm[/itex].
Farsight said:
Yep. Look at the photo. There's a half-width band of pale translucent yellow under the indigo. With a real rainbow you have to turn your head sideways before you can see it.
I zoomed in on the image as close as I can with my browser, and I can't find any yellow pixels below the violet band.
Of course, I didn't expect to see any UV light anyways, since my monitor displays colors with a mixture of red, green, and blue. :-p
Farsight said:
It isn't obvious, it's rather like an "after image" colour when you close your eyes after looking at a bright light.
Maybe it's more than merely "like" that. :-p
Look at the photo Hootenanny. And take a sidelong look at a rainbow next time you see one. It ain't violet.
I don't disagree that the photo shows violet light. However, I disagree with the fact that you said it was UV light, UV light is outside the visible spectrum, therefore we cannot see it. We can however, see visible violet light. In addition, I have seen a rainbow with a purple stripe before.
You can't actually see a colour. All you can really see is a brightness inside the violet, but you have to use the side of your eye. There is definitely some light in this region where the UV ought to be. Search google on "interference bows".
Exactly. By definition you can't see UV light.
Interference bows aren't ultraviolet light.
I know, hurkyl. But have a look again for some yellow pixels. You will find them. That's step one.
Sure it's beyond the normal colour range Dave, and sure, you can't normally see it. But not by definition.
Go to google and type in 'define: UltraViolet light'.
Ultraviolet light has a wavelength of [itex]100nm < \lambda < 400nm[/itex], the shortest visbible wavelength of light our eyes can percieve is 400nm therefore, I repeat again UV light is not visible to the naked eye under any cicumstances
If you know that interference bows are not ultraviolet light, then why the heck did you bring them up?
You might want to check the definition again. e.g. the first three Google definitions, or the first sentence at Wikipedia.
Zapper: you get your hosepipe out in the bright sunshine, and turn the nozzle to a fairly fine mist, preferably in front of a dark area like an open garage door. You position the spray and yourself so you can see the rainbow you're making. Now you turn your head sideways to look at the rainbow with your peripheral vision. You should be aware of a brightness below the violet band.
All: we all know bees can see UV. And diurnal birds and rats and bats have some degree of UV perception.
http://www.mpih-frankfurt.mpg.de/global/Na/eindex.htm
Wait... and you are saying that this IS the UV spectrum?
I work with a UV laser, 248 nm wavelength to be exact. It is perfectly invisible to me, which makes it even more dangerous, especially since it's a Class IV laser. How do I detect it when I do laser allignment? Using a business card! The coating causes luminescence on the surface of a business card and this makes a visible light that *I* can see. However, this does not mean I can actually see UV light. All it means is that the interaction of UV light with something causes light in the visible range to be produced that my eyes can pick up.
Do you see the difference here?
Last time I checked, the "visible spectrum" was defined by human optical range, the same way "audible range" was defined by human hearing range. Unless you are a bat, you have brought up something completely irrelevant here.
Zz.
I'm not sure of the difference between UV vision and UV perception or whether florescence is involved. And I can't vouch for this, but I think it's interesting:
http://www.sciencedaily.com/releases/2003/10/031017073642.htm
"Bats from Central and South American that live on the nectar from flowers can see ultraviolet light (Nature, 9. October 2003 p. 612-614). This was discovered by York Winter, a German researcher at Munich University and the Max-Planck-Research Centre for Ornithology together with colleagues from Germany and the University of Guatemala. As bats generally lack cone pigments in their eyes, the flower bats capture the ultraviolet with the rhodopsin of their rod pigments..."
