Why does the speed remain the same?
  • Thread starter lioric
    Speed
47 replies · 5K views · last reply
lioric
Textbook problem 4: alpha particle at 550 m/s in a 0.045 T magnetic field at 52 degrees, asking for magnetic force, acceleration, and whether speed changes.
F= qvB sin theta
F=ma
[/B]
A) 6.2x10^18N
B)9.5x10^8m/s^2
C) this is the problem when I searched lot of solutions they say that speed remains the same
Could someone explain this to me[/B]
Orodruin said:
How is the force direction related to the particle velocity?
Using the right hand rule, v and b are at 52 degrees and the force should be 90 degrees to the velocity. Am I right?
Yes, but what conclusion can you draw from this? (The magnetic force is always at a right angle to both the field and the velocity!)
Orodruin said:
So let me ask you this: how do you compute the speed?
It's already given in the question 550m/s
Think about a circular motion: The velocity can change in direction but the speed remains the same..
I mean in general, not necessarily in this problem.
Orudruin asks, how do you get the speed (scalar) if you know the velocity ( a vector) .
Speed = distance/ time
If you know the velocity the magnitude is the speed right?
Yes, so how do you find out the magnitude of a vector? Or, more useful, how do you find the squared magnitude of a vector? (The magnitude is constant if the magnitude squared is constant!)
I didn't quite get that but I ll give it a shot
Magnitude squared in this case 550^2
I didn't understand the magnitude square thing
But I think this is what happened
An alpha particle with a velocity of 550m/s goes in a magnetic field in an angle of 52 degrees
So like in the right hand rule the alpha particle is deflected 90 degrees to the field so the acceleration is to change the velocity by changing the direction but the speed remains the same.
If that is right how would I know if the speed did change?
This is something you will have to understand to understand the solution of the problem.
We are not interested in this particular case at the moment, we are interested in the general case when you are given a velocity vector ##\vec v##. If I give you a general velocity vector ##\vec v = v_x \vec e_x + v_y \vec e_y + v_z \vec e_z##, what is the speed of the object?
This is what we are trying to guide you to! This is why you should follow the steps I am giving you.
I'm really trying to get this in my head please continue. I'll follow the steps
As for the question with the 3D vector, I don't know but if it was just x and y only v would be found using Pythagoras theorem. I know that much. I don't know about the 3 D one
Pythagoras' theorem holds in an arbitrary number of dimensions.
Have you learned about the scalar product (dot product) of two vectors?
I think I got it tell me if this is right
V= square root Vx^2+Vy^2+Vz^2
Is this the speed?
Is this the speed?
Yes, so what is the derivative of the speed with respect to time? You may use that dVx/dt = ax (x-component of acceleration) and so on.
Acceleration? But it's derivative of velocity
Yes, that is exactly what I said!
To clarify, the derivative of speed is not acceleration! You need to compute it instead of making wild guesses.
I m sorry
I know rate of change of velocity is acceleration but I don't know if there is a rate of change of speed
lioric said:
I m sorry
Of course there is, and it is what the problem wants you to compute! I am not asking you for a name (names are conventions), I am asking you to do the actual math.
Ok let's see
If v = square root Vx^2+Vy^2+Vz^2
You want me to differentiate this with dv/dx?
With respect to t, not x.
But there is no t in there
Yes there is. The velocity generally depends on time. The derivative of velocity wrt time is called acceleration.
Ya but we are finding speed not velocity
