Why does the speed remain the same?
  • Thread starter Thread starter lioric
    Speed
47 replies · 5K views · last reply
lioric said:
Ya but we are finding speed not velocity
Seriously? You have gotten the speed as a function of velocity, now you need to differentiate this function with respect to time, the speed is generally going to depend on time because the velocity on which the speed depends does. Just apply the chain rule!
I think I understand
The speed doesn't change because the particle goes in a circular motion and no work is done on it
The motion is a spiral, not a circle, but the spirit of it is the same. What I want you to do is to work this out in mathematics and to see why the magnetic force does not do any work (in general, it does not matter if it is homogeneous or not - the motion may not be a spiral or circle in that case).
That's my problem I don't know how to do that in math
You learned the dot product (scalar product) of two vectors, and you should know that the dot product of a vector with itself is the square of the magnitude of the vector. So ##\vec b \cdot \vec b = |\vec b|^2##, or you can write it in the form ##a=\sqrt {{\vec b} ^2}##, ##b## meaning the magnitude of ##\vec b##.
You have the time dependent velocity vector ##\vec v(t)## . The speed is its magnitude, ##v(t)= \sqrt {{\vec v(t)} ^2}##
v(t) is just a function of ##\vec v##, and ##\vec v## is a function of t, Determine dv/dt, using the chain rule. What do you get?
It might be confusing that ##\vec v## is vector. How would you differentiate a function F(t)=f(g^2(t)) with respect to time?
Df/dt right?
It would be g^2 since t has no power and the differentiation is with respect to t I don't need to do anything with g
Do you know the chain rule? What is the derivative of ##f(t) = \sqrt{sin(t)} ## with respect to t, for example?
Sorry my bad
Handwritten derivation of f(t) = square root of sin t: df/dt = (sin t)^(1/2) times sin t, then 1/2 (sin t)^(-1/2) times cos t, then 1/2 times cos t over the square root of sin t.
Is this ok?
lioric said:
Sorry my bad
Is this ok?
No. Somehow you ended up with the correct derivative, but the work you show is wrong.
In the second line of your attached image, you have
$$\frac{df(t)}{dt} = (\sin t)^{1/2} \cdot \sin t$$
This is wrong. On the right side, you haven't taken the derivative yet -- ##(\sin t)^{1/2}## is the same as ##\sqrt{\sin t}##. Also, where did the extra factor of ##\sin(t)## come from?
The third line is correct, and so is the last line.
lioric said:
Is this ok?
The end is OK. Now you have the function ##f(t)= {\vec v(t)} ^2##. What is df/dt? Do not worry about that the inner function is a vector, just apply the chain rule.
Do/dt=2v(t)
lioric said:
Do/dt=2v(t)
No, you have to differentiate the inner function, too. If v(t)= sin(t), for example, what is the derivative of f(t)=(sin(t))2 ?
2(sin (t))cos t
lioric said:
2(sin (t))cos t
Good. cos(t) is the derivative of the inner function. So how do you write the derivative of f(t)=(V(t))2 in general?
2(V(t))V
lioric said:
2(V(t))V
No, you did not take the derivative for the inner derivative.
I am sorry to say so, but your attempts here indicate to me that you are not mathematically prepared to take the physics class you are in. A word of advice would therefore be to go back to your single and multi variable calculus before trying to go further. Continuing without the prerequisite math is only going to come back to bite you in the end.
I know you guys have tried very hard to help me. I'm sorry for being such a pain
And I know there is no escape from maths. I just have hard time understanding the question.
Thank you for all you have done I'll try to get by some other way.
This here is exactly why I recommend you to revisit your calculus. If you do not even understand the question, how can you hope to understand the answer? There is no shame in going back to repeat the basics, you will need the basics to build on that knowledge.
