Why does this integral go to zero?
  • Context: Graduate
  • Thread starter Thread starter vertices
    Integral Zero
9 replies · 3K views
vertices
Why does this integral go to zero? Where alpha+ is a creation operator?
[tex]\int \frac{d^3k}{w_k} k^j \left(\alpha^+ (\underline{k}) \alpha^+ (-\underline{k})e^{2iw_k x^0}\right)[/tex]
ansgar said:
odd integrand
Sorry - stupid question, why is it an odd integrand? If it is an odd integrand, alpha(+k) and alpha(-k) are either odd and even (or even and odd) or both odd. An odd function has the property that f(-x)=-f(x) and an even function has the property that f(-x)=f(x) - why must the creation operators have these properties? As I understand it, they are just coefficients of the general expansion of the field, so they should be totally arbitrary..
as far as I see, there is a k in front of the parenthesis..
yes but that k is just a constant. We are integrating wrt vector k, I think.
EDIT: In anycase, if the k was a variable in the integration, why would this make the integral zero? (sorry if this is a stupid question)..
why isn't it the j-th component? j = 1,2,3
d^3k = dk1 dk2 dk3
so the integral is a 3-vector relation.
where did you find this expression?
d^3k = dk1 dk2 dk3
Oh okay, that makes sense.
The original question itself is this:
find
[tex]\int d^3.\underline{x}T^{0j}(x)[/tex]
in terms of creation and annihilation operators.
Basically, when I expand it out (very long), I get two integrals like the one in the OP - which should go to zero according to the solutions I've been given... I just don't understand why.
well the integral you posted first is odd, so it is zero
and from
[tex] \int d^3.\underline{x}T^{0j}(x)[/tex]
you that it is a j0 tensor which is what you have posted in your post. i.e it SHOULD depend on the j-th coordinate
Yes it should depend on the jth coordinate.
Sorry I'm sure this is a really stupid question, but would I be right in saying that the alpha functions must both be even (or one even one odd, or both odd), for the integral to be zero (as evenxevenxodd=odd (the standalone k is odd).
Why must this be the case? The alpha functions are Fourier coefficients of a general field, why can we impose such a constraint to these functions?
you see that the integral is zero since it is odd due to the k^j factor
Also you have a(-x)a(x) which is even under x -> -x
so it doesen't matter if a(x) is odd or even under x-> -x, since they come in this combination.
