Why Doesn't Aluminium Corrode?
  • Thread starter Thread starter Jadaav
    Aluminium
Aluminium does not corrode due to the formation of a protective layer of aluminium oxide (Al2O3), also known as corundum, which is highly resistant to further oxidation. This oxide layer is amphoteric and inert, preventing reactions with carbon dioxide (CO2) and protecting the underlying metal from corrosion. The discussion clarifies that aluminium oxide does not form a carbonate when heat is applied, as it is stable and does not react with CO2 under those conditions. The terms corindone and corundum refer to the same compound, with corundum being the crystalline form of aluminium oxide.
  • Understanding of aluminium oxide (Al2O3) and its properties
  • Knowledge of corrosion processes and protective coatings
  • Familiarity with amphoteric oxides
  • Basic chemistry concepts regarding heat reactions and stability of compounds
  • Research the properties and applications of aluminium oxide (Al2O3) in industry
  • Learn about corrosion prevention techniques for metals
  • Explore the chemistry of amphoteric oxides and their reactions
  • Investigate the thermal stability of carbonates and their decomposition reactions
Chemistry students, materials scientists, and professionals in metallurgy or corrosion engineering will benefit from this discussion, particularly those interested in the properties of aluminium and its oxide forms.
Jadaav
Hi guys,
I wanted to know why does Aluminium not corrode and why does it not form a carbonate when heat is applied to it?
Chemistry news on Phys.org
It reacts immediately with air oxygen as soon as it comes in contact wit air, forming a very resistant and protective layer of aluminium oxide (corindone).
That means that the corindone protects the aluminium from corrosion.
And what about its reaction with heat to form carbonate? Does the corindone also protects it from heat or ?
What exactly do you mean with "reaction with heat"?
ah I meant when heat is applied to it
well, when I searched for corindone It lead me to corundum instead, guess its the same thing ?
'Aluminium oxide is the family of inorganic compounds with the chemical formula Al2O3. It is an amphoteric oxide and is commonly referred to as alumina, corundum as well as many other names, reflecting its widespread occurrence in nature and industry. Its most significant use is in the production of aluminium metal, although it is also used as an abrasive due to its hardness and as a refractory material due to its high melting point.'
This solves my questions about the corrosion and carbonate of Aluminium.
but still has a doubt of corindone and corundum, reply please
So you mean:
Al2O3 + 3CO2 -->heat--> Al2(CO3)3 ?
If you mean that reaction it's strange because usually carbonates decomposes, with heat. E.g. :
MgCO3-->heat--> MgO + CO2
Anyway, aluminium oxide doesn't react with CO2 essentially because it's extremely stable (inert) and also because it's not very basic (it's amphoteric).
lightarrow said:
So you mean:
Why you react Aluminium oxide with Carbon dioxide?
I have now understood it completely:)
Aluminium oxide is a non-reactive gas and can only react as an acid or base.:)
that's going to help me very much for my exam:D
thanks very much mate;)
Yes, forgive my mistake, I thought in english was the same as in italian...
If you are calling aluminum oxide a gas, you have still a lot to understand.
Note that corundum is a name for crystalline aluminum oxide. I doubt oxide layer on the metal surface is crystalline, microcrystalline at best.
Nevermind;),
Didn't expect to have this question in my exam, but glad that I could answer.
I didn't put aluminium oxide in the exam, hope fully.
It was only asked to explain briefly:D
I know, I'm still at a low level though.
Correct.
Yes, I agree with you.
  • · Replies 18 ·
11K
