Why Doesn't Aluminium Corrode?
  • Thread starter Jadaav
    Aluminium
13 replies · 12K views · last reply
Jadaav
Hi guys,
I wanted to know why does Aluminium not corrode and why does it not form a carbonate when heat is applied to it?
It reacts immediately with air oxygen as soon as it comes in contact wit air, forming a very resistant and protective layer of aluminium oxide (corindone).
That means that the corindone protects the aluminium from corrosion.
And what about its reaction with heat to form carbonate? Does the corindone also protects it from heat or ?
What exactly do you mean with "reaction with heat"?
well, when I searched for corindone It lead me to corundum instead, guess its the same thing ?
'Aluminium oxide is the family of inorganic compounds with the chemical formula Al2O3. It is an amphoteric oxide and is commonly referred to as alumina, corundum as well as many other names, reflecting its widespread occurrence in nature and industry. Its most significant use is in the production of aluminium metal, although it is also used as an abrasive due to its hardness and as a refractory material due to its high melting point.'
This solves my questions about the corrosion and carbonate of Aluminium.
but still has a doubt of corindone and corundum, reply please
Jadaav said:
ah I meant when heat is applied to it
So you mean:
Al2O3 + 3CO2 -->heat--> Al2(CO3)3 ?
If you mean that reaction it's strange because usually carbonates decomposes, with heat. E.g. :
MgCO3-->heat--> MgO + CO2
Anyway, aluminium oxide doesn't react with CO2 essentially because it's extremely stable (inert) and also because it's not very basic (it's amphoteric).
lightarrow said:
So you mean:
Why you react Aluminium oxide with Carbon dioxide?
I have now understood it completely:)
Aluminium oxide is a non-reactive gas and can only react as an acid or base.:)
that's going to help me very much for my exam:D
thanks very much mate;)
Yes, forgive my mistake, I thought in english was the same as in italian...
If you are calling aluminum oxide a gas, you have still a lot to understand.
Note that corundum is a name for crystalline aluminum oxide. I doubt oxide layer on the metal surface is crystalline, microcrystalline at best.
Nevermind;),
Didn't expect to have this question in my exam, but glad that I could answer.
I didn't put aluminium oxide in the exam, hope fully.
It was only asked to explain briefly:D
I know, I'm still at a low level though.
Correct.
Yes, I agree with you.
