Why doesn't my method for finding electric flux through a cube work?
5 replies · 2K views · last reply
latentcorpse
A point charge Q is placed at the centre of a cube. What is the electric flux through each face of the cube.
ok so the answer is to say that since the cube is a closed surface, Gauss' Law tells us that the total flux through the cube is [itex]\frac{Q}{\epsilon_0}[/itex] and then from symmetry 1/6 of that is through each face. so the final answer is [itex]\Phi=\frac{Q}{\epsilon_0}[/itex].
I was wondering why i don't get the same answer when i do it this way:
set it up with cartesian coordinates. let's find the flux through the face with outward normal [itex]\vec{e_x}[/itex].
[itex]\vec{E}=\frac{Q}{4 \pi \epsilon_0 (\frac{a}{4})^2} \vec{r}[/itex]
now [itex]\vec{r}=(\frac{1}{\sqrt{3}},\frac{1}{\sqrt{3}},\frac{1}{\sqrt{3}},)[/itex] and [itex]\vec{e_x}=(1,0,0)[/itex]
so [itex]\Phi=\int_S \vec{E} \cdot \vec{dA} = \frac{Q}{\pi \epsilon_0 a^2} \vec{r} \cdot \vec{e_x} \int_S dA = \frac{Q}{\pi \epsilon_0 a^2} \frac{1}{\sqrt{3}} a^2[/itex]
which ends up as [itex]\Phi=\frac{Q}{\sqrt{3} \pi \epsilon_0}[/itex]
obviously the first way is much easier but surely it should be possible both ways?
There are two problems that I can find:
  • The cube's surface is not a constant distance a/4 from the charge, as you appear to assume
  • The unit vector r^ is not (1/√3,1/√3,1/√3) everywhere on the surface.
ok yeah so i see now that its not a constant a/2 from each surface
what is [itex]\hat{\mathbf{r}}[/itex] then (i really should know this!)
is it possible to do this problem this way or is gauss' law the only way?
The vector (x,y,z) points in the same direction as r^, everywhere. Normalize that vector, and you'll have r^.
It should be possible, just not necessarily easy.
yeah so [itex]({x \over |x|},{y \over |y|},{z \over |z|})[/itex]
why doesn't the one i wrote earlier work though?
Not quite, that vector just has components (±1,±1,±1). Try dividing by |r| instead of |x|, |y|, and |z|.
Not sure if this will help, but: the integral you're trying to do contains an r-hat term. What you wrote earlier is not equal to r-hat, therefore using it will give a wrong answer when you do the integral. (Or did I misunderstand your question here?)
