Mentor
- 23,906
- 11,366
Yes...
Buckleymanor said:If I were to hit a bowling ball with a tennis bat and then a marble, both with the same amount of force won't one travell further than the other.
The marble and the bowling ball are separated on the floor of the craft.
Yes if they were both sitting in or on the catapult together the bowling balls mass and the marble mass would each have an influence on each other and the catapult, so they would accelerate at same rate.This is kind of similar to hitting both the bowling ball and the marble with the bat at the same time, except that hitting them with the bat has much more complicated physics come into play such as elasticity and such. Imagine you had them both sitting on a catapult at the same time and simply launched them into the air with it. Both would accelerate at the same rate to the same speed.
Buckleymanor said:If they were separated and on the floor of the spacecraft , or placed on separate seats in the front of car when the craft decelerated or the car crashed and elasticity was 'allowed' to do what it does.
You would be able to tell that the objects are being accelerated and not in a gravitational field.
To be honest I am haveing trouble trying to understand this.Drakkith said:In your spaceship you are accelerating them both at the same time to the same speed. Both of them are accelerating at the same rate and once you reach your maximum velocity both will be traveling at that velocity. Each one takes a different amount of force to accelerate, but since they are both on the floor of the ship at the same time they both have to accelerate at the same rate.
And the answer I received from russ_wattersIf I were to hit a bowling ball with a tennis bat and then a marble, both with the same amount of force won't one travell further than the other.
If that is the case then won't it be possible to distinguish between acceleration due to gravity and acceleration due to acceleration.Yes...
Buckleymanor said:To be honest I am haveing trouble trying to understand this.
If you just had the the bowling ball on the floor of the spaceship and you accelerated it to your maximum velocity and then applied the brakes or reverse thrust and measured the distance and the speed it traveled at.
Then you repeated the same experiment with just the marble won't the distances and speeds of the two objects be different.
Yes, one will travel faster than the other. But in that case you are hitting the objects separately at different times. That scenario is not analogous to the spacecraft scenario. Ask yourself this question: What would happen if you attached the bowling ball and the marble together and hit them both at the same time? That would be more analogous to the spacecraft scenario. You don't have to even attach them together, just hit them both at the same time.If I were to hit a bowling ball with a tennis bat and then a marble, both with the same amount of force won't one travell further than the other.
Correct me if I am wrong but that would only apply if the bowling ball and marble were on board the craft at the same time.If you took the bowling ball up first and measured it's velocity it would be slower than the marbles.And you cannot measure the distance the bowling ball or marble travel. Both will travel to the other side of the ship at the same velocity and hit the wall. Remember that in order to say that acceleration is the same as gravity we cannot "cheat" and look outside to see what is actually going on. We are forced to measure things inside the ship.
Buckleymanor said:Correct me if I am wrong but that would only apply if the bowling ball and marble were on board the craft at the same time.
Measured its velocity relative to what?
Buckleymanor said:You accelerate the craft for a given amount of time with maximum thrust with just the bowling ball on board then decelerate for another measured amount of time with maximum reverse thrust.
Then repeat with just the marble on board and then compare the time it took for the marble and bowling ball to leave the floor and hit the far side of the ship.
Are you sure won't they have different closing velocities.Drakkith said:It would be equal. In both cases the only thing you are decelerating is the ship, not the marble or bowling ball. So applying maximum thrust would cause both to reach the other side of the ship after an equal amount of time.
Buckleymanor said:Are you sure won't they have different closing velocities.
The marble and the ball would have attained different velocities with the initial acceleration.
Because you are only decelerating the ship the marble would have a greater intial velocity than the bowling ball because the ship would be lighter.
For instance if it were possible to stop the ship the craft that weighed more could not attained the speed of a lighter craft with the same amount of thrust.
I don't see how that will prevent the lighter object reaching the other side of the ship more quickly.Drakkith said:No, we are measuring the velocity relative to the ship, not an outside source. In such a case the velocity of the ship relative to an outside object is irrelevant, only the acceleration upon braking matters.
Buckleymanor said:I don't see how that will prevent the lighter object reaching the other side of the ship more quickly.
The ship would have to accelerate at the same velocity for both which it won't becuase it's more massive with one object on board than the other.
Of course it is, from the moment the craft leaves from wherever it takes off from it is doing work on every part of the ship including every thing on board.Whovian said:No, the engine is accelerating the ship, but is not doing any work on the ball until it hits the edge. The ship and its contents are more massive, but it's what the engine is doing work on or accelerating that matters, and it isn't doing either to the ball initially. And aren't we starting to get into the basics of General Relativity here?![]()
From the moment the ship takes off it will expend more fuel and accelerate less if a heavy object is on board if this was not the case you could take a mountain on board and use no more fuel than if a marble was there.No, the engines are only exerting a force on the ship, not the ball. The ship is not more massive because the ball is there. Only once the ball reaches the other side of the ship will it's mass have to be taken into account in regards to the acceleration.
Buckleymanor said:From the moment the ship takes off it will expend more fuel and accelerate less if a heavy object is on board if this was not the case you could take a mountain on board and use no more fuel than if a marble was there.
What is mass if it is not the resistance to a force applied.
I agree it won't exert a force on the ball if it is not in contact with it but it will still have to use more energy to decelerate a faster moveing ship, and that depends on which ball was on board when it was first accelerating.Drakkith said:Ignore the ship taking off. Focus on the deceleration part. That is where your confusion lies. If the ball is NOT in contact with the ship then the ship cannot exert a force upon it, meaning that it takes no extra energy to decelerate the ship while the ball is not in contact with the ship.
Buckleymanor said:I agree it won't exert a force on the ball if it is not in contact with it but it will still have to use more energy to decelerate a faster moveing ship, and that depends on which ball was on board when it was first accelerating.
TurtleMeister said:It appears that your misconception is that the speed relative to the point of take off is relavent to this time interval. Well, it is not. The time interval in question remains the same regardless of what speed the spacecraft has attained relative to the start point and regardless of how much energy it took to achieve that speed.
Buckleymanor said:So for a spaceship traveling at allmost lightspeed the time intervall will be the same as craft traveling at 1000Kph.
