Why don't the Slits collapse the wave function?
90 replies · 17K views
DrChinese said:
There is a way to learn which slit the photon pass through without absorbing it. If you put a polarizer in front (or behind) each slit, and the polarizers are crossed (at 90 degrees apart as to their relative orientation), then the photon passes through. Because of the polarizer, you know which slit it passed through (or could learn later); therefore there is no interference pattern.
I can see two situations here. If we send toward the slits a circular polarized photon, then each component of linear polarization would pass through each slit and then re-combine. The interference pattern would still be there.
If we sent a linearly polarized photon with either horizontal or vertical polarization, then we would know which slit it went through. Every photon that lands on the screen would be coming from the slit that corresponds to its initial polarization. In this case I guess the interference pattern would be destroyed. But I also think that 50% of the time the photon would be absorbed by the polarizer film in the slit with crossed polarization. If you use a polarizer that works by reflection, in that case you could absorb the photon after being reflected. So I don't know if this would qualify as a non-absorption detection experiment. It would also be equivalent to putting any obstacle in front of one of the slits. What you are detecting is the photon that doesn't make it through and not the one that does.
Well Dr. Chinese you got me thinking for a while. This is an interesting modification of the double-slit experiment and I had fun thinking about it.
