Why Equator only exists for a rotating body like Earth?
The discussion revolves around the concept of an equator and its relation to planetary rotation, specifically questioning why only rotating bodies like Earth have an equator. Participants explore theoretical scenarios involving non-rotating planets and the implications of tidal locking.
  • Some participants propose that an equator is defined as the intersection of a sphere's surface with a plane perpendicular to its axis of rotation, implying that without rotation, an equator cannot exist.
  • Others question the notion of a non-rotating planet, suggesting that any planet must have some rotation, especially if it is tidally locked.
  • A participant raises the idea that the moon, while rotating, has its axis of rotation located at the Earth-moon barycenter, leading to questions about whether it has an equator.
  • Some participants argue that if a planet does not revolve as seen from Earth, it may still appear to have an equator from the perspective of its inhabitants.
  • There is a discussion about the definition of angular momentum and its implications for the existence of an equator on planets.
  • Some participants clarify that the equator is a line on the surface of a sphere, while others emphasize that it can be viewed as a surface in certain contexts.
The discussion contains multiple competing views regarding the existence of equators on non-rotating bodies and the definitions involved. No consensus is reached on the implications of rotation and angular momentum for defining an equator.
Participants express uncertainty regarding definitions and the conditions under which a body can be considered to have an equator, particularly in relation to rotation and tidal locking.
avito009
I read that a non rotating planet like Lubricon VI does not have equator because it does not rotate. So why only rotating planets have equator?
Astronomy news on Phys.org
Per wiki:
An equator is the intersection of a sphere's surface with the plane perpendicular to the sphere's axis of rotation and midway between the poles.
Without an axis of rotation, there's no way to assign the necessary plane and it can't have an equator.
I am having trouble getting my head around the notion of a planet that does not rotate. If it is tidally locked, like the moon, then it certainly rotates. If it is not tidally locked, then it also must rotate. What am I missing? Or am I still diverting blood flow from my brain to digest Christmas Dinner?
Why must it rotate? It must orbit its star, but there's not requirement that it must rotate about its own axis. (Though it's extremely unlikely to have absolutely zero rotation)
That's interesting. The moon is rotating at the same rate that it is orbiting the earth. Since it is rotating, then it must have an axis of rotation. This axis of rotation is located inside the Earth (earth moon barycenter). So does the moon not have an equator, even though it is rotating? Is it a requirement for the axis of rotation of a body to be located within the body itself in order for it to qualify as having an equator?
No, you're thinking of revloution, not rotation. The Moon does both.
So the axis of rotation for the Earth moon system is the Earth moon barycenter, but the axis of rotation for the moon is inside the moon? So does it have an equator?
Exactly. The Moon rotates around its own axis of rotation in addition to orbiting the Earth-Moon barycenter.
In post #7 I stated that the axis of rotation of the Earth moon system is the Earth moon barycenter. However, after further thought I realized that rotation is not a good way to describe an orbit.
Here is an image from Wikipedia showing the orbit and orientation of the Earth moon system:
Notice that a lunar axis of rotation is shown along with a lunar equatorial plane. So it would seem that the moon does have an equator. I'm guessing that if an object is truly not rotating then it's orientation must not change with respect to very distant bodies such as quasars.
If the planet doesn't revolve as seen from Earth, it definitely looks like revolving for its inhabitants (with day being equal to a year) - so it has a well defined equator.
If the planet doesn't revolve for its inhabitants (no daytime), it definitely looks like revolving from the Earth - so it has a well defined equator.
In reality, by the OPs definition, there are no planets with zero angular momentum, so all planets have an equator.
You mean the definition Drakkith posted? I'm not seeing how that conclusion logically follows from the definition...
The same definition was implicit in the OP as well. Planets, by definition, are quite massive. The only way for a planet to have zero angular momentum would be to start with one with near-zero angular momentum and attempt to bring its rotation to a stop. Even that would be difficult since there are probably other gravitational bodies in the area - so you would need to compensate for tidal forces as well.
Actually the equator is not a line it's a surface and there's a line ,around which the mass rotates, which is perpendicular to the surface for a mass that is not rotating around itself there is no such line!
As complicated as people appear to be making this, it seems to be a simple concept that I believe I answered adaquately in the 2nd post.
Drakkith I'm sorry you're right I didn't read the posts
Borek you'r right, i just wanted to emphasize
  • · Replies 41 ·
  • · Replies 27 ·
  • · Replies 19 ·
