There is a lot of unreferenced assertions in this thread, most erroneous, and unfortunately due to time constraints I am going to add my own unreferenced (and therefore likely erroneous) assertions. :-/
Bystander said:
Fernando L. said:
cosmik debris said:
DiracPool said:
we're talking about reversing hundreds of millions of years of evolution.
As already commented on, evolution always move forward in time. As a process how can it not?
If something like gills evolved again, they could be convergent, as gill arches are now used to form the throat, larynx et cetera. Mind that some land living vertebrates do retain some of their gill openings in development by accident, it is a known phenomena in humans, so such a pathway could use some or all of the earlier trait basis. [The "Why Evolution Is True" blog related such a case a few months ago.]
It is a teleological idea that evolution has a goal, often relying on pre-evolutionary ideas of a "ladder of descent". Sticking pity labels on process characteristics is always problematic, and sticking erroneous labels on it is confusing.
Similarly already commented on, selective pressures on a population may preserve traits or evolve new ones, but the population need not be at a local (or global) optimum but simply surviving. The global optimum (most biomass) for evolution acting on individual populations is the prokaryote unicellular 'body' form. (Ecologically we can expect a spread, and it is beneficial since the world with plants is the most globally productive - seen as net primary productivity - yet.)
Jupiter60 said:
I would think that because whales are aquatic animals having gills would be an advantage. I guess that's not the case.
And again as already commented on, evolving several complementary ways of air uptake may be advantageous and is how tetrapods switched to lungs. Animals may use skin (amphibians), air sacks (various tetrapods) or intestinal tissue (swim bladder) as supplement. The mechanism may work best under water (gills), with access to water (skin uptake) or be independent of water life (intestinal uptake).
johnnymorales said:
As long as whales are warm blooded, gills will be incompatible with their make up.
johnnymorales said:
Every single animal that has gills is cold blooded or mostly coldblooded (some sharks and Tuna and sea turtles) whose warmer body temps. lie in their interior, are far from the gills where they are less affected by the extreme cooling effects of breathing with gills, and restricted to certain organs and tissues (muscle, brain).
Arguably, no longer. A few months ago the find that there is at least one warmblooded species of fish, the opha, was released, an accidental finding. "
Heated blood makes opah a high performance predator that swims faster, sees better" [
https://swfsc.noaa.gov/news.aspx?ParentMenuId=39&id=20466 ]
You can argue that it would be harder, perhaps impossible for whales to evolve similar counterstreaming heat exchangers as the opah use, since the opah body temperature is a lot lower than in mammals. (But it is a recurring development, IIRC the gnu antilope has evolved that to shield its brain from its unusually high body temperature of some 44 deg C or so. And we have some similar heat exchange mechanisms for the brain at a lesser efficiency level.) But it could be possible.
Mostly, evolving gill analogs would be under several constraints (contributes relatively little oxygen; must be shielded against heat losses).
