Why hyperbolic geometry in spacetime if it is flat?
The discussion centers on the relationship between hyperbolic geometry and flat spacetime, particularly in two-dimensional spacetime with coordinates (t,x). Participants explore the idea that while a flat spacetime can be represented with various coordinate systems, the curvature of the space is ultimately determined by the metric rather than the choice of coordinates. There is confusion about the implications of hyperbolic motion and how it relates to the geometry of spacetime, with some arguing that hyperbolic coordinates may not be necessary in a flat spacetime context. The conversation also touches on the importance of defining simultaneity in different coordinate systems and how this affects the perception of spatial curvature. Ultimately, the dialogue seeks to clarify the connection between hyperbolic geometry and the nature of spacetime.
closet mathemetician
This is driving me crazy. Consider a two-dimensional spacetime, with coordinates (t,x). If this is a flat spacetime, we can just imagine a regular-old two-dimensional plane. On that plane I could just as easily map a Cartesian/Euclidean coordinate system as a hyperbolic system of coordinates. The coordinate system is a choice.
Now, suppose I have a flat rubber sheet. I map a Euclidean coordinate chart to the sheet. Now I bend the sheet so that it has constant negative curvature. Now, I'm "forced" into a hyperbolic coordinate system because of the geometric shape of the space. The Euclidean coordinates I drew onto the sheet have become warped. I now don't have a choice of coordinate systems.
If spacetime is really flat, why are we forced into a hyperbolic geometry?
What do you mean by "hyperbolic coordinate system"? The curvature is determined by the metric, the coordinate system itself doesn't tell you anything about the curvature. It is true that in a flat spacetime, if you pick different coordinate systems and then use the metric to figure out the http://www.bun.kyoto-u.ac.jp/~suchii/embed.diag.html for some info.
That makes sense, ok a metric that gives a hyperbolic motion?
What do you mean by hyperbolic motion? And do you not like my idea of rephrasing the question in terms of the geometry of space (not spacetime) at a particular instant in time according to the time coordinate?
I think you are thinking that the Minkowski metric has the same form as a hyperbola:
ds²=-c²dt²+dx²+dy²+dz²
That does not imply a curved hyperbolic geometry any more than the Euclidean metric (ds²=dx²+dy²+dz²) implies curved spherical geometry.
I mean motion that would follow the geodesic hyperplanes of a hyperbola. And no, its not that I didn't like your rephrasing, I was just trying to express the idea of a hyperbolic curvature associated with a geometry other than just by coordinates, i.e., the metric, in agreement with what you said. I apologize if my use of terms was not rigorous or mathematically precise. I'm just a noob who's interested in physics.
That's a good point DaleSpam. I'll ponder that some more.
But isn't that a coordinate-dependent notion? A given geodesic may have the equation of a hyperbola in one coordinate system and the equation of a straight line in a different coordinate system.
Well, the spatial curvature of a given 3D spacelike slice of 4D spacetime is determined by the metric (which determines the length of any spacelike curve that lies within that slice), it's just that the choice of how to slice 4D spacetime into a stack of 3D slices depends on how simultaneity is defined in your coordinate system.
No need to apologize! I'm just trying to pin down what your question means a little better...can you explain what you read or were thinking about that made you link hyperbolic geometry with flat spacetime? Was it about cosmology and how the universe is supposed to be hyperbolic if the mass density is below a certain critical value (which implies space is hyperbolic if the mass density is zero, which should just be flat SR spacetime), or about the thing DaleSpam pointed out with the metric resembling the equation for a hyperbola, or something else?
  • · Replies 30 ·
  • · Replies 21 ·
  • · Replies 40 ·
  • · Replies 16 ·
