Why is Dictionary in FriendList null after instantiation?
  • Thread starter Thread starter SlurrerOfSpeech
    Confused
5 replies · 2K views
SlurrerOfSpeech
I have a class like
Code:
    public class FriendList
        public Dictionary<string, int> names { get; set; } // List of friends names and number of occurrences (in case two or more friends have the same name)
        public DateTime timestamp { get; set; } // date/time on the data file
        public static FriendList operator / ( FriendList first, FriendList second )
            // Returns a FriendList of every friend in first but not second, with the timestamp
            // of the returned object being an arbitrary value.
            FriendList firstNotSecond = new FriendList();
            foreach ( KeyValuePair<string,int> thisName in first.names  )
                int secondNum = second.names.ContainsKey(thisName.Key) ? second.names[thisName.Key] : 0;
                if ( thisName.Value > secondNum )
                    firstNotSecond.names[thisName.Key] = thisName.Value - secondNum;
            return firstNotSecond;
        public void PrintInfo ( )
            Console.WriteLine("Friends from list timestamped with {0}", this.timestamp.ToString());
            foreach ( KeyValuePair<string, int> thisFriend in this.names )
                Console.WriteLine("\t\t{0} ({1})", thisFriend.Key, thisFriend.Value);
        public int CountFriends ( )
            int count = 0;
            foreach ( KeyValuePair<string, int> namein this.names )
                count += name.Value;
            return count;
but when I use that class in the following procedure
Code:
        private void BuildFriendHistory ( )
            // Takes all text files currently in the Data folder
            // and extracts their friends lists into a List<FriendList>.
            // Prints any error encountered along the way.
            this._fhist = new List<FriendList>();
            foreach ( string thisFilePath in Directory.GetFiles(this._datadir) )
                FriendList flist = new FriendList();
                string line;
                System.IO.StreamReader file = new System.IO.StreamReader(thisFilePath);
                while ( (line = file.ReadLine()) != null )
                    int k = line.LastIndexOf(' ');
                    flist.names[line.Substring(0, k)] = Int32.Parse(line.Substring(k + 1));
                this._fhist.Add(flist);
I'm getting a NullReferenceException on the line
Code:
and I know (because I've stepped through and checked) that
Code:
and
Code:
are not NULL. Therefore NULL is some part of
Code:
flist.names
and I'm wondering if you can help me figure out why.
Mods, you can remove this thread. I figured out my problem (Needed to create a constructor for FriendList objects and in that constructor intialize this.names = new Doctionary<string,int> () )
C:
Either flist is null or flist.names is null. Before drilling down to flist.names[line.Substring(0, k)], you should do some sanity check to make sure that neither of this is null. Nowhere in the code you posted did I see anything where flist is initialized, which you're probably already figured out.
BTW, just because a problem gets solved, we don't automatically delete a thread.
I thought that if you have a class like
Code:
public class MyClass
    SomeType MyField1 { get; set; }
    SomeOtherType MyField2 { get; set; }
then both fields are implicitely newed when creating a new MyClass.
Code:
Your code is C#, right? Assuming you have a constructor for MyClass, space is allocated for the data members of MyClass, but unless the constructor initializes these members explicitly they wil be initialized to 0 in some form, for numbers, and null if they are objects of some kind.
Got it. Thanks!
