Why is i^i equal to a real number?
  • Context: Graduate
  • Thread starter Thread starter Max cohen
19 replies · 5K views
Max cohen
Take euler's formula for the identity of complex numbers:
[itex]e^{xi}=cos(x)+sin(x)i[/itex]
If we substitute the value [itex]\pi[/itex] for x it turns out that
[itex]e^{i\pi}=-1[/itex]
most of us already knew this wonderfull trick.
BUT if we substitute [itex]\frac{\pi}{2}[/itex] for x we get (because cos pi/2 = 0 and sin pi/2 = 1):
[itex]e^{\frac{\pi}{2}i}=i[/itex]
Now if you raise both sides of this identity to the power i, you obtain (since i^2 = -1):
[itex]e^{-\frac{\pi}{2}}=i^i[/itex]
Calculating the value of [itex]e^{-\frac{\pi}{2}}[/itex] it turns out that
[itex]i^i=0,2078795763...[/itex]
Isn't that just the weirdest thing ever?? :confused:
That's just the principal value. There are an infinite number of values for the expression i^i, all real.
The general form is given by :
[tex]i^i = e^{-\frac{1}{2}(2k + 1)\pi}[/tex], where k ranges over all integers. The principal value is for zero k.
are you sure of that formula? try k=1.
:-p
I think you mean:
[tex]i^i = e^{-\frac{1}{2}(k + 1)\pi}[/tex]
since it works for every k*(pi/2) with zero k beeing the principal value if I'm correct
Sorry, I was wrong. The general form should be [tex]i^i = e^{-\frac{1}{2}\pi(4k + 1)}[/tex].
dextercioby said:
Nope,it can't be that one.
Daniel.
Why not ?
k = 0, obvious.
k = 1, exp (-5pi/2) = z.
z^(-i) = exp(5*i*pi/2) = exp(i*pi/2 + 2*i*pi) = i
and so forth.
Alright
You said (see above)
[tex]i^{i}=e^{-\frac{1}{2}\pi(4k+1)}[/tex]
I say
[tex]k=0[/tex] (1)
[tex]\mathbb{R}\ni i^{i}=e^{-\frac{\pi}{2}}[/tex] (2)
[tex]k=1[/tex] (3)
[tex]\mathbb{R}\ni i^{i}=e^{-\frac{5\pi}{2}}\neq e^{-\frac{\pi}{2}}\substack{(2)\\\displaystyle{=}} i^{i}\in\mathbb{R}[/tex] (4)
Do you see something fishy...? :rolleyes: You're working with very real numbers...No more multivalued functions...
Daniel.
Okay,now here's what u and Max Cohen wanted to write.
[tex]i^{i}=e^{-\frac{\pi}{2}+2ki\pi} \ ,\ k\in\mathbb{Z}[/tex]
Daniel.
No, that's not what I wanted to write. I meant that i^i has an infinite number of real, distinct values as given by the general form. The form you wrote trivially gives only a single real value.
My first form was wrong because it generated values for (-i)^i as well. But this form is definitely right.
Complex exponentiation is multivalued, and yes, it can even give an infinite number of distinct real results.
Nope.Everything is in terms of real numbers.U use equality sign,and the reals have a funny way of behaving way when in the presence of the equality sign...
[tex]i^{i}=:a\in\mathbb{R}[/tex]
You're telling me that [tex]a=e^{-\frac{\pi}{2}}=e^{-\frac{5\pi}{2}}=e^{-\frac{9\pi}{2}}=...[/tex]
and that's profoundly incorrect.
Daniel.
This isn't what he's saying. He's saying that you have many different choices for [tex]i^i:=e^{i\log{i}}[/tex]. log is a multivalued function, [tex]\log{i}=\pi i/2+2\pi i k[/tex] for any integer k. The choice of k chooses the branch of log you are working with. So [tex]i^i=e^{i(\pi i/2+2\pi i k)}=e^{-\pi /2-2\pi k}[/tex] and the different values of k give different values of i^i, depending on which branch of log you're using. [tex]e^{-\frac{\pi}{2}},e^{-\frac{5\pi}{2}},e^{-\frac{9\pi}{2}},\ldots[/tex] are all valid answers for i^i, just as [tex]\pi i/2,5\pi i/2,9\pi i/2,\ldots[/tex] are all valid answers for log(i).
^Exactly. :smile:
dextercioby said:
Alright.Point taken.:smile: I never thought of it this way before,so i have a reason to thank you.
Daniel.
Cool. :smile: Perhaps the orig. poster was not right when he said math is weird, but math certainly is beautiful and mysterious. ;)
"The arcane pleasures of abstruse maths is only for the select few of lofty intellect and weird speech patterns"
Was that what you meant?..:wink:
Oooh, I have goosebumps. LOL. :biggrin:
