Why is it difficult to start a car in winter?
  • Thread starter Thread starter Mr Virtual
    Car
Starting a car in winter is challenging primarily due to the increased internal resistance of the battery at low temperatures, which reduces current output. Cold temperatures also cause gasoline to evaporate less and make engine oil thicker, further complicating the starting process. Additionally, lubricant oils become less viscous in the cold, impacting engine performance. An engine block heater can help mitigate these issues by warming the oil and battery. Overall, the combination of these factors significantly affects a vehicle's ability to start in winter conditions.
Mr Virtual
[ Urgent: I have to give a physics practical exam cum viva voce tomorrow for class +2 ]
I don't have any idea as to which topic in physics it is related to. I just know that in winter, you pull the choke to allow more gasoline into the engine, which starts the engine right away. But I need a simple answer based on a principle in physics.
Mr V
Liquids evaporate less when cold. Gasoline becomes thicker. And finally, what happens when a battery becomes cold in regards to the chemical process? It happens _____ than usual.
Yeah, what PowerIso said. And also that lubricant oils become less viscous at cold temperatures. An electrical engine block heater designed to offset this problem is usually placed on the oil pan.
I think the problem with starting your car in winter has more to do with the characteristics of your battery and the internal energy of it. Not to mention the CCA rating
Thanks to all of you. I found out the answer I needed while surfing the net. They are more or less what you told me.
The basic reason, apart from thickening of the oil, is that internal resistance of battery is more at low temperature, which means less current, which means difficulty in starting the car.
Thanks again.
Mr V
  • · Replies 18 ·
9K
