Why is it harder to run underwater but easier to lift
  • Context: Undergrad
  • Thread starter Thread starter TheWonderer1
    Lift Underwater
Running underwater is significantly more challenging than running in air due to the combined effects of water resistance and buoyancy. While lifting an object underwater is easier because of the buoyancy force, the resistance encountered when trying to move through water complicates the act of running. The primary difficulty arises from the need to displace water, which creates substantial resistance against the motion of the legs. Therefore, while buoyancy assists in lifting, it does not sufficiently counteract the resistance faced during running.
  • Understanding of buoyancy principles
  • Knowledge of water resistance dynamics
  • Familiarity with density concepts in fluids
  • Basic physics of motion in different mediums
  • Research the physics of buoyancy and its applications in fluid dynamics
  • Explore the effects of water resistance on movement in aquatic environments
  • Study the principles of density and how they affect object behavior in water
  • Investigate techniques for improving performance in underwater activities
Individuals interested in physics, athletes training for underwater activities, and anyone seeking to understand the mechanics of movement in different mediums.
TheWonderer1
Both involve water resistance, buoyancy, and density of water and air. Therefore, I would expect that the lift up of your foot would be easy but putting your foot down would be the most difficult. Lifting an object is easier bc of buoyancy force. Although, apart the object must be buoyant itself for that to work. I don't really get that bc buoyancy would still be there based on the general principles involved. I'm guessing the force wouldn't overcome the resistance possibly making it only somewhat easier.
hi there
none of your comments actually addressed your question " why is it hard(er) to run under water
And because you didn't state, I will at this point assume you are comparing it to running in air ?
your comments never took into account the main reason for the difficulty to run under water ( other than stating what it is)
You got side-tracked by talking about buoyancy
do you know the reason now ?
Not going to lie to you. That didn't make much sense. I thought the comparison would be obvious. I'm going to say the main reason is resistance and the water being displaced. Maybe let me ask is it turn that picking up your foot is easier underwater? Just as it is easier to pick up an object. I didn't state what was going on bc it is definitely density and resistance. I'm wondering bc I have an interest in buoyancy force right now. I think it is quite cool. It would seem to me that the foot itself is pulling up with the buoyancy force so that would be easier. However, you still have water resistance. Although, if a gold foot from an old statue needs to be lifted. I would think water resistance would come into play. However, I can still pick up my dad as a kid in the pool so that seems a bit contradictory!
When lifting a heavy object, buoyancy is helping you. When you are trying to run, water resistance is the main problem, while buoyancy doesn't help much, since the weight involved is relatively small.
  • · Replies 23 ·
  • · Replies 67 ·
24K
12K
  • · Replies 38 ·
