Why is one a buffer solution but not the other?
  • Thread starter Thread starter A1s2s2p
    Buffer
50 replies · 6K views
A1s2s2p
A student prepares two solutions:
Solution A is prepared by mixing 50cm3 of 0.100mol dm-3 CH3COOH(aq) with 25cm3 of 0.100mol dm-3 NaOH(aq)
Solution B is prepared by mixing 25cm3 of 0.200mol dm-3 CH3COOH(aq) with 50cm3 of 0.100mol dm-3 NaOH(aq)
Explain why solution A is a buffer solution, but solution B is not.
None
I believe it is because of the reaction
CH3COOH(aq) + NaOH(aq) ↔ CH3COONa(aq) + H2O(aq)
In solution A, the reacants are in the same proportion (concentration wise) as the stoichiometric constants ij the equation, but in solution B the concentrations are in the ratuo 2:1.
What do you know about buffers? What is the definition of the buffer solution?
A buffer solution is a solution that is made up of a weak acid and conjugate base, which minimises a change in pH when lsmall amounts of acid or base are added. In the question, both solutions are made up of the same weak acid and base, the only differences are volumes used and concentratioj.
Have you calculated amounts of acid and conjugate base in each case? Just by following stoichiometry?
You mean by n=C*v?
n - number of moles (mol)
C - concentration (mol dm-3)
v - volume (dm3)
There were reactions taking place - what is present in the solutions afterwards?
H2O, NaOH, CH3COOH and CH3COONa?
Check their concentrations. Use simple stoichiometry (hint: check what is the limiting reagent).
Well, the concentrations in solution A in the ratio of CH3COOH:NaOH is 1:1, however in solution B it is 2:1, the stoichiometry ratio is 1:1.
Also, what is the limiting reagent? I don't remember doing it, I don't think it's part of our course.
If you are expected to do buffers, you are expected to know how to do stoichiometry calculations, limiting reagents are part of that.
No, you are looking at concentrations of reactants, not at concentrations of products of the reaction.
Write reaction equation first.
:confused: I am not seeing that this: "solution A is a buffer solution, but solution B is not." is correct.
With buffers I know we only need to know what a buffer is, how to calculate its pH and find the ratio of the two compounds to get the pH, amongst a few other things.
I'm OK with the definition and a few other things, but not good with the maths and equations for buffers.
The question I asked in the OP was an example question
CH3COOH(aq)+NaOH(aq)↔CH3COONa(aq)+H2(l)O
Products are still 1:1.
In our second year textbook I don't find limiting reagent in the index, maybe it could be in the first year textbook.
Let me post the image.
Not the best of quality. NaOH is partially cut off from the left hand side.
All I know is that the mole ratio of CH3COOH(aq):NaOH(aq) in solution A is 2:1 and in solution B it is 1:1, while the stoichiometric ratio is 1:1.
Well maybe a speck of dust has surrounded my brain, that is one hypothesis.
However I am still seeing the statement you are required to explain as wrong. It requires a lot of ingenuity the student to give the justification for a wrong statement. If I give you a counter authority to not have to justify this statement, but just to work out what would be the right answer, e.g. which of these solutions is a better buffer, then maybe that is easier for you to do.
I think your conclusions in #9 are wrong but maybe you were trying to force them to conform to what you’re being told,So have another look. What are the ratio of moles in the two cases?
Edit: I see you have corrected in #15
Yeah, they have made mistakes before. Once, in the first year physics textbook, they quoted the density of seawater as being 10 times less than what it is meant to be. It was for an exam style question.
So, what do I do with the tree moe ratios?
Okay to get to the answer, at a given acid-base ratio do you understand whether increasing the total concentration makes the Buffer better or worse.?
And at given concentration What is the acid base ratio that makes the best buffering?
OK, for both cases calculate how much acid and how much conjugate base is present after the reaction.
Based on what I remember reading from the textbook, changing the concentrations of the acid and/or base changes the pH of the buffer solution.
Oh dear, the point of textbooks is to supplement memory, you can go back to them.
Evidently you need to know about strong and weak acids, strong and weak bases. About buffering power. All of which follow from the simple equilibrium equations for, in this case, acid dissociation. So far in this thread we have not seen a chemical equation for the ionic equilibrium involving acetic (ethanoic) acid...
Everything follows from those things.
But I was just saying that the textbook doesn't mention anything to do woth how good of a buffer something is, only what a buffernsolution is, how to work out its pH, how to wrk out the ratio of salt to base/acid for a given pH, stuff to do with buffers and pH curves, and controlling pH in blood, there's nothing to do with how good or bad a buffer solution is.
How would I do that, especially for after? Look, I said I'm not good with the maths and equations involved with buffers, I'm trying to make sure I know what I need to know for the exam. I don't want to write something down which is completely wrong and useless and look stupid, I just want make sure I know what I'm doing.
The questions below on the image, ones with benzoic acid, and ammonia, I can do
Follow the stoichiometry - what reacted, what was left. It doesn't require any equations related to buffers, it does require things that you were taught in the past.
For solution A - how many moles of NaOH were used? How many moles of acetic acid were used? They reacted according to the equation you have already listed. Assuming reaction went to completion - what was left? What was produced? How many moles of each? (Ignore water, we are interested only in the acid and its conjugate base).
Okay, if you don’t want to look stupid you need to be able to answer not just those questions but any question like that.
Look in your book about titration curves. At what point in the curve is is the rate of change of pH with added strong base or acid the least? Which is to say, buffering is best. Okay, ‘good’ or less good buffering is vague language, instead we can define “buffering capacity“ as d[NaOH]/d(pH). The higher that is the better buffering.
If you want to take this further here, you need to write out the equilibrium equations for the ionic equilibrium in play here, and also the relevant ‘electroneutrality’ equation or condition which is no doubt in your book.
Not sure how much of this, or what bits, was needed but I wrote as much as I thought would be.
1. In the reaction, for stoichiometry it was 1, in terms of actual moles, 1.
2. In the reaction, for stoichoimetry it was 1, in terms of actual moles, 2.
Well, for the forward reaction (assuming completion): CH3COOH(aq)+NaOH(aq)→CH3COONa(aq)(+H2O(l)), 1 mole of sodium ethanoate would be produced (along with water).
The solution would be a mix of sodium ethanoate, ethanoic acid, and sodium hydroxide (since in reality it is reversible, and ethanoic acid partially dissociates and equilibrium lies far to the left in the reaction: CH3COOH ↔H++CH3COO-)
Solution A would have 1 mole of sodium hydroxide dissociate into Na+, and ethanoic acid would partially dissociate into H+ and CH3COO-, with 1 mole excess of ethanoic acid.
The 1 mole of excess would dissociate as well into its respective ions, but those ions will react with the existing ethanoate and hydrogen ions in the reaction:
CH3COO-+H+↔CH3COOH
I know that, as I said, I'm fine with the other questions in the image except for that one.
The questions in the image come under 'Buffer solutions' which covers the following:
  • What a buffer solution is
  • Calculating the pH of a buffer solution
  • A buffer solution made from a weak acid and conjugate base.
  • How a buffer works
  • The Henderson-Hasselbalch equation
  • A buffer solution made from a weak base and conjugate acid.
  • How to calculate the salt:(acid/base) ratio to get a given pH.
  • How pH is controlled in the blood.
Covered in 4 pages.
The next section is on buffer solutions and pH curves, but it only talks about the buffer range and how to find the Ka using the half-equivalence point.
Sorry, what you wrote doesn't mean anything. 1 of what? Actual moles of what?
No. Just because the reaction equation states "1 mole of NaOH reacts with 1 mole of acetic acid" doesn't mean 1 mole of NaOH reacts every time.I asked you how much acid and how much NaOH were initially put in the solution, have you calculated these numbers? Was there 1 mole of any of these substances present at any moment?
And it is their relative amounts that will tell you which solution is a buffer and which is not. That's what I am asking you to calculate, that's what epenguin hints at in his posts.
Not sure if its right or not, but after using Ka and an ICE table, I got a concentration ratio of CH3COOH:NaOH:CH3COONa as:
Solution A - 73:74:1
Solution B - 105:52:1
It seems like solution A is the buffer contains around equal concentrations of ethanoic acid and sodium ethanoate at equilibrium, while solution B contains almost twice the concentration of ethanoic acid to sodium ethanoate.
Results:
Some information I found (from page 2 of http://pmt.physicsandmathstutor.com/download/Chemistry/A-level/Notes/Edexcel/12-Acid-Base-Equilibria/Set-A/Acids%20and%20Bases%20-%20Buffer%20Solutions%20and%20Uses.pdf):
