Is the product of two hermitian matrices always hermitian?
  • Context: Undergrad
  • Thread starter Thread starter Happiness
    Hermitian
The discussion centers on the Hermitian nature of the momentum operator squared, ##p^2##, and its fourth power, ##p^4##, particularly in the context of hydrogen states with azimuthal quantum number ##l=0##. It is established that while ##p^2## is Hermitian, ##p^4## is not, due to the failure of the operators to commute in this specific case. This contradiction arises from the implications of Hermiticity and the boundary terms involved in the calculations, leading to the conclusion that ##p^4 \neq (p^2)^2## under these conditions.
  • Understanding of quantum mechanics principles, particularly Hermitian operators.
  • Familiarity with the momentum operator in quantum mechanics, specifically ##p^2## and ##p^4##.
  • Knowledge of boundary conditions and their implications in quantum state calculations.
  • Ability to interpret mathematical expressions involving operators and their Hermitian properties.
  • Study the properties of Hermitian operators in quantum mechanics.
  • Explore the implications of operator commutation relations in quantum systems.
  • Investigate boundary conditions in quantum mechanics and their effects on operator behavior.
  • Learn about the mathematical treatment of quantum states, particularly in hydrogen atom scenarios.
Quantum mechanics students, physicists analyzing operator properties, and researchers studying the implications of Hermitian operators in quantum systems.
  • #61
Hans de Vries said:
Note that ##p^2## is NOT an Hermitian MATRIX since.
##p^2~~=~~ -\dfrac{\hbar^2}{r^2}\dfrac{d}{dr}\left( r^2\dfrac{d}{dr} \right) ~~=~~ -\hbar^2\left(\dfrac{2}{r}\dfrac{\partial}{\partial r}+\dfrac{\partial^2}{\partial r^2}\right)##
It is the sum of (infinite dimensional) real matrices and the righthand side tells us that one of them is anti-symmetric ##(\partial_r)## while the other is symmetric ##(\partial^2_r)##. The diagonals of these matrices look like:
\begin{smallmatrix}
0&1&0&0&0&0&0 \\
-1&0&1&0&0&0&0 \\
0&-1&0&1&0&0&0 \\
0&0&-1&0&1&0&0 \\
0&0&0&-1&0&1&0 \\
0&0&0&0&-1&0&1 \\
0&0&0&0&0&-1&0
\end{smallmatrix} ~~~~~~~~~~
\begin{smallmatrix}
2&-1&0&0&0&0&0&0 \\
-1&2&-1&0&0&0&0&0 \\
0&-1&2&-1&0&0&0&0\\
0&0&-1&2&-1&0&0&0 \\
0&0&0&-1&2&-1&0&0 \\
0&0&0&0&-1&2&-1&0 \\
0&0&0&0&0&-1&2&-1 \\
0&0&0&0&0&0&-1&2
\end{smallmatrix}
A real matrix must be symmetric to be Hermitian so it is the ##\partial_r## that destroys the symmetry. (The complete term ##\tfrac{2}{r}\partial_r## is not symmetric either).
Now in some cases it may be that it for fills the equation ##\langle f \,|\, p^2\,g \rangle = \langle p^2\,f \,| \,g \rangle## which is used as the definition of an Hermitian operator depending on ##f## and ##g##. For instance the trivial ##f=g=0##. There is no reason to assume that for less trivial examples of ##f## and ##g## this somehow should be true for ##p^4## as well.Some good references:
Spherical Polar Laplacian: Quantum Physics, Eisberg & Resnick appendix M
Hermitian Operators: Mathematical methods for Physicists, (edit: Arfken & Weber), Chapter 10.2
How do you obtain these matrices?
  • #62
\begin{smallmatrix}
0&1&0&0&0&0&0 \\
-1&0&1&0&0&0&0 \\
0&-1&0&1&0&0&0 \\
0&0&-1&0&1&0&0 \\
0&0&0&-1&0&1&0 \\
0&0&0&0&-1&0&1 \\
0&0&0&0&0&-1&0
\begin{smallmatrix}
2&-1&0&0&0&0&0&0 \\
0&-1&2&-1&0&0&0&0\\
0&0&0&0&0&0&-1&2
\end{smallmatrix}
That's not a valid argument since you forgot that the scalar product in this case is (omitting the angular piece, i.e., concentrating on wave functions that are only ##r## dependent (particularly of course the ##\ell=0## energy eigenstates of spherical systems fulfill this constraint)
$$\langle \psi |\phi \rangle=\int_{0}^{\infty} \mathrm{d} r r^2 \psi^*(r) \phi(r).$$
Now consider
$$p^2=-\frac{1}{r^2} \partial_r (r^2 \partial_r)$$
Let's check for hermiticity (as a necessary constraint for self-adjointness) [edit: corrected in view of #63]
$$\langle \psi |p^2 \phi \rangle=-\int_0^{\infty} \mathrm{d} r \psi^*(r) \partial_r (r^2 \partial_r \phi(r)) \\
=-r^2 \psi^*(r) \partial_r \phi(r))|_{r=0}^{\infty} + \int_0^{\infty} \mathrm{d} r r^2 \partial_r \psi^*(r) \partial_r \phi(r) \\
=r^2 [\partial_r \psi^*(r) \phi(r)-\psi^*(r) \partial_r \phi(r))]|_{r=0}^{\infty} - \int_0^{\infty} \mathrm{d} r \partial_r[r^2 \partial_r \psi^*(r)] \phi(r) \\
=r^2[\psi^*(r) \partial_r \phi(r)-\psi^*(r) \partial_r \phi(r)]|_{r=0}^{\infty} + \langle p^2 \psi|\phi \rangle.$$
So ##p^2## is Hermitean indeed if the boundary terms vanish.
This holds for the ##\ell=0## wave functions (see also the quotes from Griffiths's book in the first few postings of the thread, though he forgot to take the conjugate complex of the left wave function, which is unimportant for his case though since there you can choose the eigenstates as real functions).
  • #63
Isn’t there a ##\partial_r## too many in your first boundary term (although not changing the conclusion)?
  • #64
Of course you are right. I edited the posting accordingly.
  • #65
They are just the difference (discrete) versions of the first and second order differentiation. When you consider a function ##f(x)## then its discrete version becomes ##f(n)## where ##n## is an integer. The discrete version of the first and second order derivatives may be given by:
##\Delta(n) = f(n+1)-f(n)~~~~~~\mbox{and}~~~~~~\Delta^2(n) = f(n+1)-2f(n)+f(n-1)##
These two sequences "slide" along the diagonal of the matrices because a differentiation is in principle a convolution.
Thus ##\partial_x## is a convolution with ##\tfrac{\partial \delta(x)}{\partial x}## and ##\partial^2_x## is a convolution with ##\tfrac{\partial^2 \delta(x)}{\partial x^2}## where ##\delta(x)## is the Dirac function.
This is where we get the two sequences from:
##\begin{array}{lrrrrrrrrr}
\mbox{The discrete delta function:} & ~~0&~~0&~~0&~~0&~~1&~~0&~~0&~~0&~~0 \\
1^{st}~\mbox{difference of delta function:} & 0&0&0&1&-1&0&0&0&0 \\
2^{nd}~\mbox{difference of delta function:} & 0&0&0&1&-2&1&0&0&0 \\
\end{array}##
Note we used f(n+1)-f(n-1) for the first order difference in the matrices. Technically this avoids the extra unwanted shift of an 1/2 lattice step
  • #66
ok, I see what you did but not really how it applies here. I would have assumed that, to get a matrix representation, I would have to calculate something like
## (p^2)_{mn} = \langle\Psi_m|p^2|\Psi_n\rangle##
and this would be symmetric ##(p^2)_{mn} = (p^2)_{nm}##?
  • #67
As for any self-adjoint operator it should read
$$(p^2)_{mn}=(p^2)_{nm}^*.$$
What's to prove is that this is not the case for the ##\ell=0## bound states of the hydrogen atom for the operator ##p^4##, which is shown in #62.
The conclusion is that the ##\ell=0## bound states of the hydrogen atom are not in the domain of the operator ##p^4##.
  • #68
(p2)mn=(p2)∗nm.(p2)mn=(p2)nm∗.​
Sure, but in this specific case everything is real anyway.
vanhees71 said:
What's to prove is that this is not the case for the ℓ=0ℓ=0\ell=0 bound states of the hydrogen atom for the operator p4p4p^4, which is shown in #62.
The conclusion is that the ℓ=0ℓ=0\ell=0 bound states of the hydrogen atom are not in the domain of the operator p4p4p^4.
I know, and I think we have arrived at these conclusions already multiple times during this thread. With my latest posts I was trying to understand @Hans de Vries comments about ##p^2##, since I am not familiar with this “getting matrices from discretised versions of functions and operators”.
  • #69
vanhees71 said:
... the scalar product in this case is (omitting the angular piece, i.e., concentrating on wave functions that are only ##r## dependent ...
1) The trivial Self-Adjoint, Hermitian Operators.
The Laplacian ##\nabla^2## is symmetric while ##p^2## is the part that acts on the radial part of the eigenstates. We have in a trivial way the following (integral) equations:
##\langle\,\bar{g}\,|\,\nabla^2 f\,\rangle ~~=~~ \langle\,\overline{\nabla^2 g}\,|\,f\,\rangle~~=~~ \langle\,\nabla^2 \bar{g}\,|\,f\,\rangle##
because for each individual point of the fields ##f## and ##g## the following holds.
##g(\nabla^2 f)~~=~~ ((\nabla^2)^\intercal g) f ~~=~~ (\nabla^2 g) f##
The integral expressions are trivial in this case because the expressions above hold for every point so their integral over any bounded area holds as well. An operator here is classified as Self-Adjoined / Hermitian based on the integral equations. This is one step beyond qualifying them based on their (infinite-dimensional) matrix properties. This is a key difference.
2) The original question in the OP
Now if ##p^2## was real-symmetric then ##p^4## would be as well. They both would classify as (infinite dimensional) Self-Adjoined Hermitian operators in a trivial way just like ##\nabla^2##. This seems to be the expectation in the OP. He expects ##p^4## to be Hermitian operator but based on the wrong assumption that ##p^2## is an (infinite dimensional) Self-Adjoint, Hermitian matrix, but this is not the case.
The first order derivative term is real anti-symmetric. Therefore the transpose of ##p^2## is:
##\Big(p^2\Big)^\intercal~~=~~ \hbar^2\left(\dfrac{2}{r}\dfrac{\partial}{\partial r}-\dfrac{\partial^2}{\partial r^2}\right)##
Nevertheless ##p^2## becomes a Self-Adjoint, Hermitian operator according to the integral definition, not in the trivial way as ##\nabla^2## does.
3) Non trivial Self-Adjoint, Hermitian Operators.
We consult the excelent Arfken & Weber to see under which conditions a second order differential operator ##\mathcal{L}## becomes a Self-Adjoined operator. In other words when ##\langle\,v\,|\,\mathcal{L}\,u\,\rangle = \langle\,\mathcal{L}\,v\,|\,u\,\rangle##, starting with the simpler case ##\langle\,u\,|\,\mathcal{L}\,u\,\rangle = \langle\,\mathcal{L}\,u\,|\,u\,\rangle##
It is Arfken & Weber (10.6) which tells us if ##\mathcal{L}## is self-adjoint.4) Operator ##p^2## as a Self-Adjoint Operator.
At first it seems that acording to (10.6) that ##p^2## is not a Self Adjoined operator.
##p^2~~=~~ -\dfrac{\hbar^2}{r^2}\dfrac{d}{dr}\left( r^2\dfrac{d}{dr} \right) ##
but if we multiply it by a factor ##r^2## then ##r^2 p^2## becomes a Self Adjoined operator. This factor ##r^2## is readily explained when we look at the calculations of Hendrik van Hees a few post back. What he does is identical to the steps in Arfken & Weber but now for the specific case of ##p^2##.
vanhees71 said:
Now consider
=r^2[\partial_r \psi^*(r) \phi(r)-\psi^*(r) \partial_r \phi(r)]|_{r=0}^{\infty} + \langle p^2 \psi|\phi \rangle.$$
The factor ##r^2## is explained by the integration. We integrate over spheres so we need a factor of ##r^2## to account for the surface of the spheres depending on ##r##. The multiplication of ##p^2## by ##r^2## thus makes it into a self-adjoint operator according to (10.6)
There seems to be no reason that a combination of ##p^4## and ##r^2## would also make a valid self-adjoint operator as in the trivial cases.
  • #70
The worst bit of ##p^4 \Psi_n## at ##r\to0## behaves like ##e^{-r}/r^2##, so if I write out the integrals of this part I get something like
##4 \pi \int_0^\infty \mathop{dr} e^{-r}##
or in cartesian coordinates
## \int_{-\infty}^{\infty} \int_{-\infty}^{\infty} \int_{-\infty}^{\infty} \mathop{dx} \mathop{dy} \mathop{dz} e^{-\sqrt{x^2+y^2+z^2}}/(x^2+y^2+z^2)##
and you are saying that these are not the same? Or am I misunderstanding?
You are misunderstanding. The problem is not the value of the integral over a function. The problem is the value of a function itself at ##r=0##, which appears as a boundary term after a partial integration. In Cartesian coordinates there is simply no boundary at ##r=0##, so in partial integration one does not need to worry about it.
  • #71
Only in the Lebesgue inner product. But the transformation to spherical coordinates changes the inner product.
Thus you are working in the wrong inner product!
  • #72
All these operators are self-adjoint or more precisely essentially self-adjoint. The important lesson to be learned is
(a) Hermiticity is not sufficient for an operator to represent an observable; it must be an essentially self-adjoint operator
(b) In QT the operators describing observables with a continuous or partially continuous spectrum have a domain and co-domain which is smaller than the entire Hilbert space. For position and momentum you can use some Schwartz space of quickly falling functions, which is dense in the Hilbert space.
Here we have an example, where some eigenfunctions of the Hamiltonian belong not to the domain of the operators we are interested in. Though ##\hat{p}^2## is well defined applied to these states, the result is not in the domain. That's why another application of ##\hat{p}^2## (making together ##\hat{p}^4##) leads to trouble. Again, for a good treatment check the two nice pedagogical papers
https://arxiv.org/abs/quant-ph/9907069
https://arxiv.org/abs/quant-ph/0103153
To make the usual sloppy physicists' math rigorous (implying of course taking the caveats in situations like the here discussed with ##\hat{p}^4## seriously), the most elegant way is to use the "rigged Hilbert space". This you find in the following dissertation
http://galaxy.cs.lamar.edu/~rafaelm/webdis.pdf
and in the textbook
A. Galindo, P. Pascual, Quantum Mechanics, Springer Verlag, Heidelberg (1990), 2 Vols.
  • #73
Note that for any arbitrary real Anti-symmetric matrix ##\mathcal{A}## the following holds:
$$\langle\,\psi\,|\,\mathcal{A}\,\psi\,\rangle = 0 ~~~~~~~~~~
\langle\,\mathcal{A}\,\psi\,|\,\psi\,\rangle = 0 ~~~~~~~~~~
\langle\,\psi^*\,|\,\mathcal{A}\,\psi\,\rangle = 0 ~~~~~~~~~~
\langle\,\mathcal{A}\,\psi^*\,|\,\psi\,\rangle = 0 ~~~~~~~~~~$$
Therefor we need two independent wave functions for the Self-Adjoint test for an operator ##\mathcal{L} ## like in:
$$\langle\,\psi^*\,|\,\mathcal{L}\,\varphi\,\rangle~~=~~
\langle\,\mathcal{L}\,\psi^*\,|\,\varphi\,\rangle $$
Any arbitrary real ##\mathcal{L=S\!+\!A} ## with a symmetric part and an anti-symmetric part would pass the "test" below for being Self-Adjoint:
$$\langle\,\psi^*\,|\,\mathcal{L}\,\psi\,\rangle~~=~~
\langle\,\mathcal{L}\,\psi^*\,|\,\psi\,\rangle$$
Because the anti-symmetric part is eliminated during the calculation.
  • #74
We can not just use a specific eigenfunction ##\psi##, for instance the radial part of (##\ell=0##) in combination with the Self_Adjoint test because we need two independent wavefunctions. See post #73
The boundery-term in your calculation in #62 for ##\hat{p}^2## does not cancel in the case of two independent wave-functions and one needs to rely on the ##r^2## factor to make it 0.
  • #75
According to Arfken & Weber (10.6) the operator ##p^2## is not self-adjoint in a Cartesian inner product but it is self-adjoint in a spherical radial inner product.
See the ##r^2## factor in post #69.
  • #76
Sure, you can take any two ##\ell=0## wave functions. All belong not to the domain of ##\hat{p}^2## as an essentially self-adjoint operator. I think, Griffiths has it right here.
  • #77
Hans de Vries said:
According to Arfken & Weber (10.6) the operator ##p^2## is not self-adjoint in a carthesian inner product but it is self-adjoint in a spherical radial inner product.
Sure, that's what I've shown above.
  • #78
Demystifier said:
You are misunderstanding. The problem is not the value of the integral over a function. The problem is the value of a function itself at r=0r=0r=0, which appears as a boundary term after a partial integration. In Cartesian coordinates there is simply no boundary at r=0r=0r=0, so in partial integration one does not need to worry about it.
Sure, I understand what you were saying there, but I do not think it is enough to just wave your hands and say “at infinity everything will be fine” without deriving what the terms at infinity really would be. Anyway, I was pointing the the last equation in #7. Do you agree that, if we just calculate both these integral, i.e. define the function ##\Phi_n = p^4 \Psi_m## and calculate
##\int \mathop{d^3 x} \Psi_n \Phi_m##
and
##\int \mathop{d^3 x} \Phi_n \Psi_m##
and take their difference we get a definite answer (if it is 0 ##p^4## is hermitian, otherwise not)?
Now we already know the answer if we calculate everything in spherical coordinates. So if we get a different answer in cartesian coordinates, the value of these integrals depends on what coordinate we choose to calculate them (or at least, it is not valid to go between cartesian and spherical coordinates). As these are all reasonably behaved functions, this would beg the question in what case spherical coordinates can be used anyway (though I would love to learn about subtleties).
  • #79
Hans de Vries said:
According to Arfken & Weber (10.6) the operator p2p2p^2 is not self-adjoint in a carthesian inner product but it is self-adjoint in a spherical radial inner product.
What is a “carthesian inner product”? The usual inner product should be
##\langle\Psi|\Phi\rangle = \int \mathop{d^3 x} \Psi^*\Phi##
and it should not matter what coordinates I choose in practice.
  • #80
If you use a nonlinear transformation of the coordinates as new coordinates, the integral inherits an additional Jacobian determinant, and hence looks different. Thus the choice of coordinates matters;
the general form of the inner product is ##\langle\Psi|\Phi\rangle = \int \mathop{d^3 x} w(x)\Psi(x)^*\Phi(x)## with a weight ##w(x)\ge0##, and this weight is different in different coordinate systems.
  • #81
Yes, but ##w(x)## is different in different coordinates systems in a way that the integral value stays the same, right? I was assuming this is implicitly contained in the notation ##\mathop{d^3 x}##, i.e. in cartesian coordinates
##\mathop{d^3 x} = \mathop{dx} \mathop{dy} \mathop{dz}##
whereas in spherical coordinates
##\mathop{d^3 x} = \mathop{d\phi} \mathop{d\cos\theta} r^2 \mathop{dr}##.
In that sense I don't understand how the inner product can be “cartesian”.
  • #82
To a Cartesian coordinate system corresponds the weight ##w(x)=1##. Note that ##x## is just a dummy variables and can as well be the Cartesian ##(x_1,x_2,x_3)## as the spherical ##(r,\phi,\theta)##; for the latter, ##w(x)=r^2\sin\theta##.
  • #83
A. Neumaier said:
Note that xxx is just a dummy variables and can as well be the Cartesian (x1,x2,x3)(x1,x2,x3)(x_1,x_2,x_3) as the spherical (r,ϕ,θ)(r,ϕ,θ)(r,\phi,\theta); for the latter, w(x)=r2sinθw(x)=r2sin⁡θw(x)=r^2\sin\theta.
Which are exactly the expressions I wrote above. My point is that
##\langle\Psi|\Phi\rangle = \int \mathop{dx}\mathop{dy}\mathop{dz} \Psi^*(x,y,z)\Phi(x,y,z) = \int \mathop{d\phi}\mathop{d\theta}\mathop{dr} r^2 \sin\theta \Psi^*(r,\theta,\phi)\Phi(r,\theta,\phi)##
so what sense does it make to call the inner product “cartesian” or “spherical”? It is just “integral over ##R^3##”, no matter what coordinates I choose to perform that integral.
  • #84
My point is that
It is the Lebesgue integral over ##R^3##, but only if you say that ##x## denote Cartesian coordinates.
  • #85
Ok, so this is supposed to be an cartesian inner product over spherical coordinates, i.e.
##\langle\Psi|\Phi\rangle = \int \mathop{d\phi}\mathop{d\theta}\mathop{dr} \Psi^*(r,\theta,\phi)\Phi(r,\theta,\phi)##
that then is somehow only defined on the subspace where the integral converges? What am I learning from this other than that it is a strange definition of the inner product?
  • #86
Rhi is a valid inner product defining a Hilbert space in which id/dr is self adjoint. It is equivalent to the physical inner product when one rescales the wave function by the square root of the weight obtained by the substitution rule.
  • #87
and
I agree.
I think I should do a careful calculation by myself, before that I cannot tell anything definite.
  • #88
fresh_42 said:
What would be ##P## to get ##P^2= -\dfrac{\hbar^2}{r^2}\dfrac{d}{dr}\left( r^2\dfrac{d}{dr} \right)##?
Actually ##P## (or better ##\hat{p}_r##) here is given by the radial part of the Spherical Polar form of the Dirac equation. The following is from Paul Strange's book
Look at (8.9) and concentrate on the essential radial part of ##\hat{p}##:
$$\hat{p}_r ~=~i\tilde{\gamma}_5\tilde{\sigma}_r\left(\hbar\dfrac{\partial}{\partial r}+\dfrac{\hbar}{r}\right)$$
If we square this radial part then we get ##p_r^2## because the ##\tilde{\sigma}_r## anti-commute but the two terms commute.
$$\hat{p}_r^2 ~=~\left[~i\tilde{\gamma}_5\tilde{\sigma}_r\left(\hbar\dfrac{\partial}{\partial r}+\dfrac{\hbar}{r} \right)~\right]^2 ~=~ -\hbar^2\left(\dfrac{\partial^2}{\partial r^2}+\dfrac{2}{r}\dfrac{\partial}{\partial r} \right)~=~ -\dfrac{\hbar^2}{r^2}\dfrac{\partial}{\partial r}\left( r^2\dfrac{\partial}{\partial r} \right)$$
The definition of ##\tilde{K}## which contains the angular parts of ##\hat{p}## using the angular momentum operators is:
  • #89
So, with the (correct) version of the post above we may write more general for ##P=\hat{p}_r##:
##\hat{p}_r~~=~~ i\hbar\left(\dfrac{\partial}{\partial r} +\dfrac{1}{r}\right)##
For an arbitrary power ##\hat{p}_r^n## we can write
##\hat{p}^n_r~~=~~ (i\hbar)^n\left(\dfrac{\partial}{\partial r} +\dfrac{n}{r}\right)\left(\dfrac{\partial}{\partial r}\right)^{n-1}##
or alternatively:
##\hat{p}^n_r~~=~~ (i\hbar)^n\left(\dfrac{1}{r^n}\dfrac{\partial}{\partial r}r^n\right)\left(\dfrac{\partial}{\partial r}\right)^{n-1}##
  • #90
Ah, now I found the error in my argument. When one does partial integration in Cartesian coordinates, one encounters sub-integrals of the form
$$\int_{-\infty}^{\infty}dx \, \partial_x F(x,y,z)=F(\infty,y,z)-F(-\infty,y,z)$$
Naively I thought that such terms vanish because ##F## exponentially vanishes for ##x\rightarrow\pm\infty##. But that's not necessarily true for ##y,z\rightarrow 0##, because ##F(x,y,z)## diverges for ##y,z\rightarrow 0##. So now I agree with older statements by @vanhees71 and @A. Neumaier that the source of the problem is divergence of the potential at ##r=0##. If the potential has been regularized for small ##r##, then the Hamiltonian eigenfunctions would have well defined derivatives at ##r=0## and the problem would disappear.
And by the way, we already had a thread with the same question: https://www.physicsforums.com/threa...n-for-hydrogen-like-l-0-wavefunctions.563295/
  • · Replies 22 ·
16K
