Why is power equal to voltage times current?
  • Level: High School
  • Thread starter Thread starter oneamp
    Current Power Volts
34 replies · 6K views · last reply
Nugatory said:
You can write either I2 or ##I^2## and it will be a lot clearer what you mean. (try quoting this post to see what I did, or look for the sticky down in the feedback section).
Thank you. That is very helpful and I'm confidant it will make my future posts clearer, to myself as well as others..
and use V for voltage rather than E
E is more commonly use for Energy ... ie ... E = mc2
cheers
Dave
cheers
Dave
That's actually curious. I was taught Ohms Law is I = E/R but I see now that textbooks and modern reference material replace E with V as you recommended. I may be old but not so old I can't change for something half way reasonable. V it is :)
The old name for "voltage" was "electromotive force", which is probably where enorbet's I = E/R came from.
The term EMF is still used sometimes (e.g. the "back EMF" in an electric motor) but being pedantic, the EMF is the "cause" of a voltage in a circuit, not the actual voltage itself. (And the name EMF is also confusing because it has nothing to do with the idea of "force" as used in mechanics.)
In the standard notation for electromagnetism E is the electric field, not the voltage. http://hyperphysics.phy-astr.gsu.edu/hbase/electric/efromv.html
emf is still used when you are referring to an induced 'voltage'. So the secondary of a transformer has an 'emf' induced and an antenna will also have an emf induced into it and a chemical cell will generate an emf. This term distinguishes this manifestation of a voltage from the Potential Difference that is actually measured in a circuit, fed from a real electrical source - one with a source resistance (so called Internal Resistance of a battery)
So PD would be equal to Emf - Current times source resistance or:
PD=rI.
I remember my Dad always used E = IR, after his college ONC and HNC courses on 'EE' (=Voltage Voltage??haha). It confused me, wham I started using V = Ir at school.
Flavours change from generation to generation. I remember , in A Level Mechanics and Physics, acceleration was always lower case f. So v=ut+ft2/2 was what we used in our equations of motion calculation.
It's a moving target, as new variables arrive and pinch the commonly used symbols.
