Why is superdeterminism not the universally accepted explanation of nonlocality?
395 replies · 65K views
billschnieder said:
Bah! I had hoped you will have seen problem the so called "DrChinese challenge" by now. You keep saying:
- give me a dataset with values for simultaneous polarization outcomes at 0, 120 and 240 degrees.
Don't you yet understand that "dataset with simultaneous outcomes" implies an experiment is being performed. Previously I asked you to describe the experiment and I will give you the dataset but you never described the experiment because you can not and nobody can because THERE CAN NEVER BE AN EXPERIMENT WHICH SIMULTANEOUSLY MEASURES TWO PHOTONS AT 3 ANGLES (yes I'm shouting this time).
Therefore failure of anybody to provide your purported dataset is not due to anything other than the fact that the request is nonsensical.
Under local realism cloning of entangled pair is completely valid operation. From that follows that "DrChinese challenge" is applicable to LR models.
While I am proponent of local realism I side with DrChinese in this. Have to say that you can have constructive discussions with DrChinese and I am grateful to him as discussions with him have shaped a lot my own understanding about entanglement problem.
f95toli said:
I don't normally get involved in these discussions, because ultimately I don't think they are very interesting.
However, I thought I'd add my (usual) comment about experimental QM.
Whereas nearly all "conceptual" (and many practical) experiments are done using light, there are lots of examples of QM experiments that do NOT involve light, angular momentum, polarization, photon detectors etc.
People have performed experiments that are formally exactly analogues to the early (optical) tests of Bell's inequalities. We will probably see the first demonstrations in my own field pretty soon (solid-state QIP, which has nothing to do with optics but the QM formalism is obviously the same)
Hence, any attempt to explain away Bell type experiments by saying that that results are due to the fact we do not understand a specific technical detail of Aspect's original experiments is ultimately futile.
Moreover, note also that we are nowadays often -in practical- terms more concerned about OTHER inequalities that for one reason or another are better to test experimentally. A good example are tests of Legget-type inequalities which can used to test whether or not QM is local.
Can you give one good reason why your position is not subject to confirmation bias?
lugita15 said:
Argh! ThomasT, I told you, the argument does not assume it, it proves it.
I would like to see this. Hmm, my guess would be that you are assuming perfect (anti-)correlations for matching measurement settings.
You're right, I am assuming that. But that's a harmless assumption to make. Perfect correlations for matching measurement settings is a consequence of quantum mechanics, so surely if a local realist theory wanted to match the predictions of QM then it would have to have perfect correlations for matching measurement settings. I highly doubt this is what ThomasT is disputing.
(You can, of course, be the fringe type of local realist who has a theory making predictions contrary to QM, but who believes that the only reason the experiments have proven QM right is that they're subject to various flaws, loopholes, and systematic biases. But as Bell tests become more sophisticated, that becomes an increasingly untenable positon, arguably even more so than superdeterminism.)
ThomasT said:
I didn't get that. How does it prove it?
The whole point of the entire proof is to show that the correlation is linear, but if you want the step that directly leads to it, look at 11: "So 75% of the time, P(-30)=P(0), and 75% of the time P(0)=P(30), so there's no way that P(-30)≠P(30) 75% of the time." But this is pretty much an indisputable step, because it's just math, not physics: if A has a 25% chance of occurring, and B has a 25% chance of occurring, then the probability that at least one of them occurs is at most 50%. It's definitely not possible for A to have a 25% chance of occurring, B to have a 25% chance of occurrring, but a 75% chance that at least one of them occurs.
Presumably you don't disagree with the straightforward math of step 11, so if you reject the conclusion that local realism implies linear correlation you must reject one of the earlier steps.
I don't understand your notation. For example, what does this mean? "So 75% of the time, P(-30)=P(0), and 75% of the time P(0)=P(30), so there's no way that P(-30)≠P(30) 75% of the time." I'm assuming that P(-30) refers to the probability of coincidental detection while keeping the setting of the A polarizer vertical and offsetting B, to the left, 30 degrees. And that P(30) refers to the probability of coincidental detection while keeping the setting of A vertical and offsetting B, to the right, 30 degrees. If so, then what? I don't get what "75% of the time, P(-30)=P(0)" is supposed to mean. Or what "75% of the time P(0)=P(30)" is supposed to mean.
Do you just mean that the probability of coincidental detection at θ=30 degrees is .75?
I think that's what you mean, so let's go with that. But wait, where did that come from? The polarizers were actually set that way, and you noted the result? Right?
Ok, so we have a probability of coincidental detection at θ=30 of .75 .
Then we set A 30 degrees to the left and B 30 degrees to the right, so now we have a θ of 60 degrees.
So now do we do some runs to see what the rate of coincidental detection at θ=60 degrees is, or do we first assume something about what that rate should be? And if we assume something about what that rate should be, then what's that assumption based on?
ThomasT, I define P(θ) in step 2: "A local realist would say that the photon doesn't just randomly go through or not go through the detector oriented at an angle θ; he would say that each unpolarized photon has its own function P(θ) which is guiding it's behavior: it goes through if P(θ)=1 and it doesn't go through it P(θ)=0."
Let's get right to the heart of the matter. If P(-30)=P(0) and P(0)=P(30), then P(-30) must equal P(30). Thus if P(-30) does not equal P(30), either P(-30)≠P(0) or P(0)≠P(30) (or both). Since there is a 25% error rate whenever there is a thirty degree separation, we know that the probabilities that P(-30)≠P(0) is 25%, and the probability that P(0)≠P(30) is 25%, and the probability that at least one of these two statements is true is at most 25%+25%=50%. This is not a physical assumption or constraint, it's just math. If event A happens 25% of the time and event B happens 25% of the time, then it's guaranteed that at least 50% of the time neither one of them occurs. If taxis are available in New York City a quarter of the time, and buses are available a quarter of the time, then you know that transportation is available at most 50% of the time. I hope you don't dispute this.
That assumes that there's a linear correlation between θ and rate of coincidental detection. But the historically observed and documented behavior of light suggests otherwise. So, where did this assumption come from?
In step 11 we're not making any assumptions about physics, we're just doing math. If the probability of A is 25% and the probability of B is 25%, then the probability of "A or B" is at most 50%, regardlesss of what A and B are and whether they have anything to do with each other. (Note that "A or B" means at least one of them is true.) That is just a simple mathematical fact. In this case, A is "P(-30)≠P(0)" and B is "P(0)≠P(30)".
As I said, once you've gotten down to step 11 there is no room for argument left, it's just math. If you want to dispute the reasoning you'll have to find an earlier step you disagree with.
jadrian said:
By the way i think you should be focusing more on simply c and d which i presume are next to the measurement devices and thus are far apart so they are the "conspirators", because they causally effect the outcome of the measurements by bumping the measurement device into whatever angle. either way a and d or c and d doesn't matter which you consider to be conspiring. There should be nothing conspiratorial about particle d being able to affect particle c and therefore effect a because in the history of the universe, the 10^10^MILLION (who can say how many?) interactions that have taken place, through causality and info exchange, HAVE PREDETERMINED that particle d was going to effect c and therefore a. you say a and d seemingly have nothing to do with each other. THEY HAVE EVERYTHING TO DO WITH EACHOTHER! Simple logical determinism would lead you to the conclusion that d had causal effects on perhaps everything in the universe which ultimately led to the causal outcome of the measurement of a. Not only that but particle d,d1,d2,d3 d infinity not only via cause-effect cause-effect cause-effect...eventually caused c to affect the measurement device for a, but d, d1, d2... caused the experimenters to make the experiment take place in the first place.
i don't believe faster than light info transfer will be an issue here as it is not an issue with normal entanglement, because info transferred at the speed of light will always beat instantaneous info transfer to the punch. Sending light in opposite directions i suspect would be solvable by relativity to give the same conclusion.
dont think of it not particles all knowing about each other, think of it as historical interactions in the universe as spreading a virus to every particle in the entire universe.
its not that every particle knows everything about every other particle. it only knows what has happened to it in the past. but the addition of all current states of particles which are in their current state because of their continuous past history traced back in time will give you the full information in the universe, and having this information, you would be able to predict it. and if you could predict it, that would mean it must be deterministic as a whole. so although we cannot predict the future, and the future isn't predictable, que sera' sera'.
let me clarify this a little bit. the "conspiracy" is simply the result of the history of the causal interactions of ALL the stuff in the universe. the affect of d on a is not just a relationship between of d and a. it is a result of d and a being the part of the sum of everything in the universe. d and a alone would not be able to affect each other if isolated from the history of all interactions in the universes past. it requires all the information in the universe to result in determinism. there is nothing super about it.
if determinism only is effective within lightcones, in which case if outside each others lightcones, a and d could not affect each other just as future events cannot effect the past, as lightcones expand at the speed of light, if there were particle a that had not yet interacted with other particles d1 d2 d-infinity, (i stated before that this should be impossible under a causally governed universe) in this hypothetical case it would be not practically, but THEORETICALLY impossible to do such an experiment or have such nonlocal effects even without an experiment. also, along with photons a and b traveling in opposite directions, so too will plenty of other EFFECTUAL information be propagated to a and d from particles locally and causally effecting the photon source, so it would make a and d effectively the same as being locally deterministic. it would be determined tho in the universe that the lightcones would eventually expand to make a and d react causally therefore deterministically.
Demystifier said:
Lugita15, I would like to see your response to my post #127.
Oh, I agree wholeheartedly that all of the theories listed in your blog post are viable alternatives (with the exception of Joy Christian), and that they are each in one way or another local, and even that some of them are in one way or another realistic or deterministic. But I think the only alternative out of your list that deserves the appelation "local determinism" is superdeterminism, because it is the only when where the real future states of real particles in our 3-dimensional universe are determined by the real past states and real local interactions of real particlces (whew, I think I put enough qualifications). But yes, there are several viewpoints that someone like backwards causation where some pedant could make the argument that we have a local determinist theory.
Still, it's a worthwhile task to show that local realism (unless it's superdeterministic) using the conventional definition cannot reproduce the predictions of quantum mechanics.
jadrian said:
let me clarify this a little bit. the "conspiracy" is simply the result of the history of the causal interactions of ALL the stuff in the universe. it is a result of d and a being the part of the sum of everything in the universe. d and a alone would not be able to affect each other if isolated from the history of all interactions in the universes past. it requires all the information in the universe to result in determinism. there is nothing super about it.
but outside our lightcone they will have their own lightcone, in which their determinism will eventually mesh precicely with our determinism leading to the same result that the future of everything is predetermined.
Wouldn't retro-casuality have exactly the same outward appearance as superdeterminism to us? It is certainly more economical (in occam sense) - the 'conspiracy' in each case only has to go back in time as far as needed to achieve correct outcomes as opposed to setting it all up just before big bang. Also laws of physics are time-symmetrical already (:those that counts anyway:).
Not sure what most of this means, but would like to remind you that a and d have never existed within a common light cone. They were "born" separated and remain separated their entire existence. Yet they were made to be entangled, displaying correlations characteristic of twins. Yet other photons from the same laser sources at the same time, those not made to be entangled, show no such relationship. Further, the decision to entangle is made AFTER the photons are detected and their existence has ended.
And you are trying to say that local deterministic systems naturally display this behavior. You might want to rethink that. Clearly, you need something "super" to explain this. Because your explanation above doesn't explain why some photons show the correlations and others don't. Following your concepts, all of them should evidence Bell state statistics.
DrChinese, you're not a very good conspiracy theorist. Clearly the particles are always entangled with each other, but never display this entanglement unless they know that quantum mechanics would consider them to be entangled, in which case they would each try to act in exactly the right way so that everyone is fooled into thinking quantum mechanics is right. Theories are so easy to make when you abandon things like Occam's razor.
I was trying (unsuccessfully it seems :smile: ) to force jadrian to realize that the laser source must be imparting the hidden (it is a conspiracy, so something should be hidden) information to the photon at the time it is created. But that the same laser source only imparts the correct information for perfect correlations to a small subset of photons, just those that some spacelike-separated robotic observer will eventually mark as being in a Bell state (and no others).
So that means the laser source ALSO knows enough about that robotic observer to know which ones will be seen to be entangled (since the robotic observer makes that decision at a later time).
Oh, and the laser source ALSO knows which direction the polarizers for a and d are set in. That, of course, so that the Bell relationship holds. Of course, those polarizers can be set by 2 more robotic observers using let's say, 2 different random algorithms. Which of course the laser source knows this too.
Of course, there are actually 2 separate laser sources which are phase locked together. So both knows what the other is going to do. On the other hand, the photons don't even need to exist at the same time any more than they need to exist in the same location, so that the appearance of entanglement crosses both space and time if we want to set it up that way.
And so, as you say, does the theory continue on without the benefit of Occam...
Linear relationship between θ and correlation level follows directly from that assumption.
So your statement that "the argument does not assume it, it proves it." ... well, I wouldn't say it's very truthful.
Local realistic theory can not reproduce all predictions of QM.
But local realistic theory can try to reproduce QM predictions in domain where they are experimentally verified. And that domain does not include (something close to) perfect correlations for matching measurement settings.
What I think ThomasT is disputing is that given Malus law it is very unreasonable conclusion that there is linear relationship between θ and correlation level.
No, I am a type of local realist who tries to make falsifiable local realistic explanations agreeing with QM in a domain where it is experimentally tested.
You're right, it's a fairly direct route from the assumption that there is perfect correlation at identical polarizer settings to the conclusion that the local realist must believe that the correlation is linear. But ThomasT does not agree with this fairly direct line of reasoning, so I'm trying to convince him that it works.
If I could persuade ThomasT of this, I'd be done.
But that just has to do with practical experimental limitations. The point I'm arguing with him about is whether someone can believe that all the predictions of quantum mechanics are correct and still believe in (non-superdeterministic) local realism. I'm trying to show that the answer is no, because one experimental prediction of QM is perfect correlations at identical polarizer settings, from which the local realist is forced to believe in a linear correlation relationship, which is in contradiction with another experimental prediction of QM.
I agree that this is the point of contention, but keep in mind that he thinks a local realist can believe in the nonlinear correlation given by Malus' law, while at the same time also believing that there is perfect correlation at identical settings. I hope you agree that he's wrong on this point.
Out of curiosity, which experimental loophole of Bell tests do you cling onto? Detector efficiency, communication, freedom of choice, or something else?
exactly. it shouldn't be called super determinism. it should be called universal causality. if I am the first with this this then i claim it. adrians universal causality
if you could match experimental settings, which you cant, then you wouldn't have correlations, youu would have the exact same result.
lugita15 said:
OK, let me give you an example of why you need special initial conditions.
In a deterministic theory, in order to predict the current behavior of any object, you need to know the initial conditions of the object, as well as the deterministic laws of the universe. In Newtonian mechanics, for example, you need to know the positions and velocities of all the particles at time t=0, and then F=ma will tell you the behavior of the particles at all later times.
Now let's consider what a local deterministic explanation of entanglement would look like. Let particles A and B be an entangled pair of photons, which are separated by a great distance and then sent through polarization detectors. We also have particles C and D: C tells the experimenter what angle he should set the polarizer that measures A, and D tells the experimenter how to set the polarizer that measures B. You can think of C and D as neurons in the brains of the experimenters if you like.
Now we find experimentally that the behavior of particle A through its measurement device is strongly correlated with the angle at which B's measurement device is set. And that angle is determined by particle D. So we have a correlation between the behavior of particles A and D.
But particles A and D are separated by such a large distance, so they cannot communicate with each other to coordinate their behavior (unless you have a nonlocal theory like Bohmian mechanics which allow undetectable faster-than-light signalling between particles). So a local determinist has to conclude that A and D are correlated not based on a current relationship between the present states of A and D, which would be impossible, but based on a past relationship of the initial states of A and D.
This is what we mean by special initial conditions: A and D seemingly have nothing to do with each other. After all, it is A and B that were in the entangled state, and yet somehow we have to conclude that the initial conditions of A and D had to be specially set so that a correlation between A and D would be observed in the future. And instead of just D, we can have a large number of particles D1, D2, D3,... which together determine the measurement setting, so the initial state of particle A had to have been set based on the initial states of all these particles. And in the real world, almost all particles in the universe are interacting in some way with almost all other particles, so really the setting of measurement device depends on almost everything in the universe, from which we conclude that the initial conditions of the whole universe were specially set so that the right kind of correlation would be displayed billions of years later between particle A and the measuring device.
This is why superdeterminism is called "conspiratorial". That doesn't mean it's wrong, it just has some issues which make it rather difficult to construct a viable superdeterministic theory, but let me repeat that some potential first steps toward such a theory have already been taken by a few people.
also with d could have this instantaneous effect on a as i could decide to shoot my self in the head or not depending on the angle, wouldn't this be faster than light info tranfer, violating relativity?
this further seems proof that d and are within the lightcone of the distant past, in which case, the info about what d will do to affect a is predetermined. and nonlocal interactions can only occur within a lightcone or you violate relativity.
also, has it been proven in a lab that time moves forward and isn't frozen or moving backwards? it seems like that is something our intuition has guided us to regard as truth. is there not enough intuition in the world to regard determinism as truth?
DrChinese said:
Free will is not a necessary component of QM. So I certainly am not rejecting superdeterminism because of that. I reject superdeterminism as an explanation for Bell test results, and I do so for the reasons already stated.
Please bear in mind that there are no candidate superdeterministic theories to reject at this point, so it is a moot point in many ways. The reason I mention the amount of local information to be stored in every particle is because a candidate theory will end up postulating this (in some form or fashion) as a way to explain Bell test results. It is not necessary to assume free choice for measurement settings in any stage of the argument, but you must explain how (i.e. the exact mechanism, since we have no other reason to suspect it exists) the choice is propagated in a superdeterministic candidate.
Not so easy, I assure you. Which is again, the answer to your original question.
then why even call it superdeterminism. there is no conpiracy! its simply causality governed by relativity. call it universal causality. yes it is that easy.
jadrian said:
exactly. it should be called super determinism. it should be called universal causality.
No, it is obviously different. superdeterminism does not by itself imply retro-causality. Instead some constraints are placed on the initial conditions which somehow pre-determine the outcomes of all Bell-type experiments (including experimenters' choices) in the future. These initial conditions then evolve forward in time according to laws of physics, causing all these pre-determined outcomes to eventuate.
And the other way around, retro-causality does not mean total super-determinism.
Too bad, you are at least 25 years late. See http://www.npl.washington.edu/npl/int_rep/tiqm/TI_toc.html. Although I personally don't like it, or rather don't see a point. It does not clarify what measurement apparatus is, where does preferred basis come from and what happens to Shroedinger's cat. It keeps all these thorny questions swept under the carpet.
But then transactional interpretation does not hold a monopoly on advanced wave solutions. After all, MWI is sufficiently weird, those who accept it might as well go for broke and add retro-causality to the mix.
DrChinese said:
That is just NOT true in any meaningful sense. A particle has only a few observable elements: momentum, position, mass, charge, spin, color, etc. It would be instructive to state specifically how you would know ANY information about the past interactions by knowing these. Suppose the spin is +1. What does that tell you? Or momentum is 1.63 (units ignored) in direction XYZ? Not much history to be gained from that!
No, you need there to be a rich hidden internal structure. One that contains the entire initial conditions of the universe, like DNA. And this DNA would need to be in every particle so they know how to react during Bell tests.
conservation of information. finiteness of information. your quote "what does that tell you" is ambiguous. you are trying to say that information can not adequately explain the universes deterministic evolution? are you serious? do you believe in true randomeness? in order for an electrons position to be truly random, you would have to assume it is moving at infinite speed!
and your dna analogy is completely imcompatable. dna is replicated. information is not.
consider a rack of pool balls getting struck by the cue ball.
now remove all the balls besides the cue ball and the 8 ball. assume the cue ball is particle d and the 8 ball is particle a. without the other balls measured positions on the table, you will not be able to know how the cue ball transferred its info into the 8 ball resulting in the cue ball and 8balls new locations. it requires ALL!, ALL! how many times do i have to say it? of the information of all the other balls location, how much they spun, etc.. to figure out how cause led to effect via determinism in this situation. you keep throwing these things at me as if they are a way around the law of conservation of information. seriously?
Actually, there are QM interpretations in which time does not flow in the conventional sense. These are called "block world". I happen to be something of a fan of a particular one of these, called Relational Block World.
Relational Blockworld: A Path Integral Based Interpretation of Quantum Field Theory; W.M. Stuckey, Michael Silberstein, Timothy McDevitt (2009)
Although time does not flow, the future is a component in interactions and it is the total setup that is relevant. Although the authors do not call it a time symmetric model per se, I think it qualifies.
For those that are interested:
The above paper is advanced reading, but it is absolutely fascinating in this sense: It is a QM interpretation that makes predictions that are slightly DIFFERENT than standard QM. Incredibly, those predictions seem to account for experimental evidence in favor of an accelerating expansion of the universe WITHOUT adding otherwise new physics.
Easily the most ambitious program I have seen in the few years. So a tip of the hat to the authors, good luck! If anyone wants to discuss, we can start a new thread on that.
lugita15 said:
Again, I am not claiming that A and D could never have interacted. I am saying that the interaction of A and D would have to have occurred in just the right way so that they would demonstrate nonlocal correlations of just the right kind. And by similar arguments, you would have to conclude that at the beginning of the universe all the particles interacted with each other to set just the right initial states for each particle, so that all the Bell tests which would be performed in the entire history of the universe would get just the right results. That's what's called a conspiracy.
they don't have to interact in a special way, what makes you think that. we've already been through your abcd experiment and I've shown its irrellevant to universal causality leading to determinism without any special initial conditions. there is no conspiracy unless you NEGLECT the histories of the pool balls besides the cue ball and 8 ball as i described above
jadrian said:
conservation of information. finiteness of information... you keep throwing these things at me as if they are a way around the law of conservation of information. seriously?
Well, golly. Perhaps you can share this with us. What exactly is this law? Can you cite a reference? Does it have anything to do with entropy (which increases to the future, see 2nd law of thermodynamics)? :smile:
At any rate, you continue to throw out terms without understanding their meaning. At this point, I, lugita15. Delta Kilo and others have tried to help you with the physics involved. You seem to reject this in favor of speculation which lacks any basic background study or consideration. Your billiard ball example is typical, as it doesn't explain Bell test results and never will.
So good luck, and again I recommend you do some more study in the area.
