Why Is the Curl of a Conservative Force Field Zero?
The discussion revolves around the question of why the curl of a conservative force field is zero. Participants explore the relationship between conservative fields and their mathematical properties, including the implications of curl in physical contexts.
  • Meta-discussion
  • Some participants assert that a conservative field is equivalent to having zero curl, suggesting this is a standard derivation in vector analysis.
  • There are inquiries about whether a conservative force can be expressed as a gradient of a scalar field, with some affirming that it can.
  • One participant expresses a need for a physical understanding of the significance of curl in conservative fields, indicating that textbook explanations may not suffice.
  • Another participant provides a loose analogy involving whirlpools to illustrate the physical meaning of non-zero curl, emphasizing energy considerations in conservative fields.
  • There is a mention that the term "conservative force" may not be explicitly defined in mathematics, leading to confusion among participants.
  • Links to resources are shared in response to requests for further information on conservative vector fields.
Participants generally agree that a conservative field has zero curl, but there is disagreement regarding the clarity and sufficiency of textbook explanations. Some participants express frustration with the lack of physical meaning in the definitions provided.
Some participants note that the definitions and explanations found in textbooks may not adequately address the conceptual understanding of conservative forces, leading to confusion about their mathematical representation.
Mr Genius
Why the curl of a conservative force field is zero everywhere?
Because a field being conservative is equivalent to having zero curl. This should be derived in any basic text on vector analysis.
Can your conservative force be written as a gradient of a scalar field?
Yes
ummm this didn't help
Mr Genius said:
Yes
Now take the curl of that gradient.
Ummm I'm looking for the physical meaning and significant of this
I am saying you should find this explained in detail in any basic textbook. This makes me wonder what effort you spent on trying to find the answer before posting.
This is mentioned without any illustration in my physics book, and there is nothing called conservative force in mathematics to explain it in a math book
Perhaps not conservative force, but certainly conservative vector field. A conservative force field is just a conservative vector field describing a force.
Well, if u can find that then please send me a link
Loosely speaking, non-zero curl means that the vector field "goes in circles" somewhere, that you can follow the vector at one point to another and eventually get back where you started without ever going against the direction of the vector field at some point. For example, if the vector field were describing the current at the surface of a body of water, non-zero curl would mean that there was a whirlpool somewhere, so you could go around and around in circles without ever having to go against the current.
But a force field with that property cannot be conservative because you can return to your starting point with more or less energy than you started with, depending on whether you went with the current or against it.
That's the "loosely speaking" hand-waving picture that may help you visualize the physical significance of the math. However, the truth is in the math, so your next step is to go back to one of the many mathematical proofs that the curl of a gradient is zero, work through that proof now that you have a picture in your mind.
