Why is the curl of a gradient of a scalar function zero?
7 replies · 24K views
chingcx
(Sorry, the title should read "...why curl of gradient of a scalar "function" is zero)
Of course I know how to compute curl, graident, divergence. Algebrically I know curl of gradient of a scalar function is zero.
But I want to know the reason behind this...and also the reason why gradient of divergence of a vector function is always zero.
This really makes me feeling bad for a long time. Thanks in advance.
The gradient of a scalar function would always give a conservative vector field. Now think carefully about what curl is. If you've done an E&M course with vector calculus, think back to the time when the textbook (or your course notes) derived [tex]\nabla \times \mathbf{H} = \mathbf{J}[/tex] using Ampere's circuital law. What is the closed path integral of a conservative field?
I'm wondering about your second question too...
Is this true? In Gauss's law, the divergence of the electric field is to equal an arbitrary charge density. I would be surprised if the gradient of an arbitrary charge density is zero.
[tex]\nabla(\nabla \cdot \vec F) = 0[/tex]
is certainly false. I think you mean
[tex]\nabla \cdot (\nabla \times \vec F) = 0[/tex]
which is true.
Hi chingcx! :smile:
(curl grad f)x = ∂/∂y(∂f/∂z) - ∂/∂z(∂A/∂y) = 0
Similarly, div curl A = 0
But (grad div A)x = ∂/∂x(∂Ax/∂x) + ∂/∂x(∂Ay/∂y) + ∂/∂x(∂Ax/∂z) ≠ 0 :smile:
Hey you're right. Wow I can't believe I didn't even bother thinking about whether it might be correct, as opposed to why it might be correct.
which is true.
ya, sorry, I mean divergence of curl of vector function is always zero. Why is that true?
