Homework Helper
- 13,438
- 8,114
Yes, that sounds reasonably accurate.Frank Castle said:So is the point that once we have chosen our origin (which we identify with the real number ##0.0##), then the length of the interval between the origin and the point that we identify with the first integer, ##1##, defines a length scale, which we refer to as being of "unit" length. Our metric is then defined in terms of this unit length such that the distance, ##d(x,y)## between any two real numbers is given by $$d(x,y)=\lvert x-y\rvert =\lvert y-x\rvert$$ which, in words, means that "the distance between ##x## and ##y## is ##d(x,y)=\lvert x-y\rvert## units", or, "there are ##\lvert x-y\rvert## intervals of unit length between ##x## and ##y##".
The "there are n intervals of unit length" justification that you give seems to makes an implicit assumption that you can move intervals around and compare or add up their lengths. That is an appealing assumption, but is not the only possibility. Non-linear metrics can be defined.
