Why is the momentum not conserved
  • Thread starter Thread starter Probie1
    Momentum
43 replies · 5K views · last reply
Probie1
Two vehicles collide one has a velocity of .0246 m/s the other a velocity of 4.374 m/s at impact. After impact one has a velocity of .49 m/s and the other a velocity of .91 m/s.
(p) = mv
(p)1 = 13158 * -0.0246
(p)1 = -323.68
(p)2 = 1726 * 4.374
(p)2 = 7549.52
at impact momentum = 7225.84 = (p)1 + (p)2
(p)3 = 13158 * -0.49
(p)3 = -6447.42
(p)4 = 1726 * 0.91
(p)4 = 1570.66
after impact momentum = -4876.76 = (p)3 + (p)4
So Iam missing 12102.6 kg*m/s. Why is this like this...am I missing something?
Your problem statement doesn't actually pose a question. It is literally just a statement.
It also doesn't give the mass of either vehicle. So we have no way of knowing if the masses you assumed are what was intended.
It also doesn't give any directions. Are the two vehicles initially traveling in the same direction or opposite directions?
Basically, we don't have the info we need to evaluate if your work is sensible or not.
Sorry about that
veh1
weight 13158kg
heading 0 deg
departure 179
impact velocity 0.0246 ms
departure velocity 0.49 ms
veh2
weight 1726 kg
heading 190
departure 245
impact velocity 4.374 ms
departure velocity 0.91 ms
Veh 2 is heading toward veh1 slightly off of 180 deg.
Momentum is a vector quantity. Compute the separate components of the momentum for each vehicle both before and after collision. What's the total momentum vector before? After?
Okay,
weight 13158kg
heading 0 deg
departure 179
Momentum-in Veh1
p = mv
p= 13158 * 0.0246
p = 323.68
Out
p = mv
p= 13158 * 0.49
p = 6447.42
veh2
weight 1726 kg
heading 190
departure 245
Momentum-in Veh2
p = mv
p= 1726 * 4.374
p = 7549.52
Out
p = mv
p= 1726 * 0.91
p = 1570.66
The total before is 7873.2 and after is 8018.08
okay, but I still see a difference in momentum. Am I to include the approach and departure anges in this as well?
Of course! Momentum is a vector: it has both magnitude and direction; it has components.
Compute the momentum vector components for the vehicles before and after. Find the total momentum vector components for before and after. Then compare them.
weight 13158kg
heading 0 deg
departure 179
Momentum-in Veh1
p = mv
p= 13158 * 0.0246 * (sin 0 = 0)
p = 0
Out
p = mv
p= 13158 * 0.49 * (sin 179 = .017)
p = 109.60
veh2
weight 1726 kg
heading 190
departure 245
Momentum-in Veh2
p = mv
p= 1726 * 4.374 * (sin 190 = -0.173)
p = -1306.06
Out
p = mv
p= 1726 * 0.91 * (sin 245 = -0.906)
p = -1423.01
Well... this is big time messed up.
Probie1 said:
weight 13158kg
heading 0 deg
departure 179
Momentum-in Veh1
p = mv
p = 0
That's the y-component. What happened to the x-component? Your collision is happening the the x-y plane, so vectors will have x and y components.
Out
p = mv
p= 13158 * 0.49 * (sin 49 = .754)
p = 4803.32
Again, there should be both x and y components. And where did this angle "49" come from?
I thought the "departure" angle was 179°?
So you still need to sort out the rest of the vector components...
weight 13158kg
heading 0 deg
departure 179
Momentum-in Veh1
p = mv
p = 0
Out
p = mv
p= 13158 * 0.49 * (cos 179 = -0.999)
p = -6446.43
veh2
weight 1726 kg
heading 190
departure 245
Momentum-in Veh2
p = mv
p = -1306.06
Out
p = mv
p= 1726 * 0.91 * (cos 245 = -0.422)
p = -662.81
The 49 was just a idiot mistake.
Still waiting to see ALL the components for ALL the momenta. For example, I see a calculation for the y-component of the momentum of the first vehicle for before the collision, but I don't see the corresponding x-component... and I see an x-component calculation for the first vehicle's momentum after the collision, but I don't see its y-component...
weight 13158kg
heading 0 deg
departure 179
Momentum-in Veh1
p = mv
p = 0
Out
p = mv
p= 13158 * 0.49 * (sin 179 = 0.017)
p = 112.52
veh2
weight 1726 kg
heading 190
departure 245
Momentum-in Veh2
p = mv
p= 1726 * 4.374 * (cos 190 = -0.98)
p = -7398.53
Out
p = mv
p = -662.81
Sorry this is taking so long to grasp.
Let's concentrate on one particular vector to begin with; How about the initial momentum of the first vehicle?
You've got the:
vehicle mass: m1 = 13158 kg
Speed: v1 = 0.0246 m/s (meters per second --- you had written ms, which is meter seconds)
direction: θ = 0°
The speed is not a velocity; Speed has magnitude but no direction. Velocity has both magnitude AND direction. You're given the direction angle for the velocity, so you can determine the TWO components (x and y) for the velocity, and hence the TWO components for the momentum.
What are the x and y components of the momentum for the vehicle?
weight 13158kg
heading 0 deg
departure 179
impact velocity 0.0246 m/s
departure velocity 0.49 m/s
P1x = m1v1 cos 0 = 13258kg * 0.0246 * 1 = 323.68 kg*m/s
P1y = m1v1 sin 179 = 13158kg * 0.49 * 0.017 = 109.60 kg*m/s
weight 1726 kg
heading 190
departure 245
impact velocity 4.374 m/s
departure velocity 0.91 m/s
P2x = m2v2 cos 190 = 1726kg * .91 * -0.984 = -1545.52 kg*m/s
P2y = m2v2 sin 245 = 1726kg * 4.374 * -.906 = 1731.28 kg*m/s
I am confused about the x and y ...is the approach of each vehicle on the x and then the seperations on the y or is one veh totally y and the othe totally x ?
Probie1 said:
weight 13158kg
heading 0 deg
departure 179
Er, no. The initial velocity has only one angle, namely 0°. The angle 179° pertains to a different velocity, the departing velocity. We're only concerned with the initial velocity here.
Use 0° for BOTH the x and y component calculations for the initial velocity.
A vector in the plane has two components: an x-direction component and a y-direction component. Every velocity in the plane thus has two components. There is ONE angle associated with a given velocity; it's generally the angle between the velocity vector and the positive x-axis. Use that ONE angle to determine BOTH components for that velocity.
If V is the speed and θ is the angle, then Vx = V cos(θ) and Vy = V sin(θ).
weight 13158kg
heading 0 deg
departure 179
Vx = .0246 * cos 0 = .0246
Vy = .49 * sin 179 = .0085
Probie1 said:
weight 13158kg
heading 0 deg
departure 179
No! The initial velocity HAS ONLY ONE ANGLE. Forget the 179° for now. That comes later, after the collision. Only the 0° angle exists at the moment. An object cannot be heading in two directions at the same instant in time!
The initial velocity of the first vehicle has one angle: zero degrees. That's the ONLY ANGLE!
The initial velocity vector is comprised of two components: One is its x-component, and one is its y-component. The ONE ANGLE along with the magnitude (speed) define the two components. There is the component that is parallel to the x-axis, and the component that is parallel to the y-axis. Use the trig functions cos and sin to extract those two components USING THE SAME ANGLE.
weight 13158kg
heading 0 deg
departure 179
Vy = .49 * cos 0 = .49
Probie1 said:
weight 13158kg
heading 0 deg
departure 179
Why are you using the speed from AFTER the collision? Why are you using the cosine function for both components? You want to find BOTH components of the INITIAL velocity (before the collision) for the first vehicle. The initial velocity has ONLY speed 0.0246 m/s at angle 0°. That's all. No other angles or speeds should enter into consideration here.
Perhaps you are unfamiliar with the use of vectors? In the following diagram a velocity vector V is shown on a set of Cartesian coordinate axes. The velocity vector has magnitude |V| which corresponds to the speed, angle θ with respect to the positive x-axis, and x and y components are depicted in red. Use the appropriate trig function of the angle to extract the individual x and y components of V.
Vector diagram on x-y axes: vector V from origin at angle θ to the positive x-axis, with dashed projections showing components Vx along x and Vy along y.
  • Diagram of a velocity vector V on x-y axes, with angle θ from the positive x-axis, and its x component Vx and y component Vy shown as red arrows.
weight 13158kg
heading 0 deg
departure 179
weight 1726 kg
heading 190
departure 245
Vx = 4.374 * cos 190 = -4.30
Vy = .49 * sin 179 =0.008
Vy = .91 * sin 245 = -0.824
Probie1 said:
weight 13158kg
heading 0 deg
departure 179
weight 1726 kg
heading 190
departure 245
Those would be the x-components of the initial velocities of vehicles 1 and 2. You should give them distinctive variable names in order to distinguish between them. Something like V1x and V2x.
Now, where are the initial y-components of those same velocities?
Those are the y-components of the final velocities of the of vehicles 1 and 2. You should give them distinctive variable names in order to distinguish between them. Something like U1y and U2y.
Now, where are the final x-components of these same velocities?
weight 13158kg
heading 0 deg
departure 179
weight 1726 kg
heading 190
departure 245
V1x = .0246 * cos 0 = .0246
V2x = 4.374 * cos 190 = -4.30
V3x = .49 * cos 179 = -0.489
V4x = .91 * cos 245 = -0.384
V1y = .0246 * sin 0 = 0
V2y = 4.374 * sin 190 = -0.759
V3y = .49 * sin 179 =0.008
V4y = .91 * sin 245 = -0.824
Probie1 said:
weight 13158kg
heading 0 deg
departure 179
weight 1726 kg
heading 190
departure 245
Okay, I suppose that sorts out all the components. NOTE: you should probably keep an extra decimal place or two in the values of intermediate results to minimize truncation and rounding errors in further calculations.
Now you should be in a position to write the components of the momenta by multiplying the velocity components by the appropriate masses (p = mv).
I hope you mean drop everything before the = sign then multiply the weight with everything after the = sign?
weight 13158kg
heading 0 deg
departure 179
weight 1726 kg
heading 190
departure 245
V1x = 13158 * .0246 = 323.6868
V2x = 1726 * -4.30 = -7421.8
V3x = 13158 * -0.489 = -6434.262
V4x = 1726 * -0.384= -662.784
V1y = 0
V2y = 1726 * -0.759 = -1310.034
V3y = 13158 * 0.008 = 105.264
V4y = 1726 * -0.824 = -1422.224
I have to pack it in for the night... thanks for now, will be here tomorrow.
You are the greatest...
Thanks A LOT :)
weight 13158kg
heading 0 deg
departure 179
weight 1726 kg
heading 190
departure 245
V1y = 0
After multiplying velocities by mass you get momenta, so you should change the names of the variables accordingly. So, P1y, P2y, P3y,... and so on.
Thanks A LOT :)
No worries. Pleasant dreams.
Okay... changed everything to momenta (P)
weight 13158kg
heading 0 deg
departure 179
weight 1726 kg
heading 190
departure 245
P1x = 13158 * .0246 = 323.6868
P2x = 1726 * -4.30 = -7421.8
P3x = 13158 * -0.489 = -6434.262
P4x = 1726 * -0.384= -662.784
P1y = 0
P2y = 1726 * -0.759 = -1310.034
P3y = 13158 * 0.008 = 105.264
P4y = 1726 * -0.824 = -1422.224
So now calculate the total momentum vectors (before and after). Sum the like-components.
Oh, Oh... I forget which is before and which is after. I have tried different combinations but nothis seems right. (I will say it for you ..."IDIOT".)
Wait... the light just came on... I got it figured out.
P1y = 0
(P)in = P1x+P2x+P1y+P2y
(P)in = -8408.1472 kg*m/s
(P)out = P3x+P4x+P3y+P4y
(P)out = 8414.006 kg*m/s
I do hope this is right.
Wow... I imagine that the difference is in rounding of the digits... because you can not gain momentum after a collision.
No, it's not correct. You cannot add (in that fashion) unlike components; they are vector components. Thus you cannot arithmetically add x components to y components in that fashion. They must be kept separate. You should end up with separate x and y components for the momentum vectors.
They can be combined into magnitude and angle form by employing a bit of Pythagoras:
##|P| = \sqrt{p_x^2 + p_y^2}~~~~~~~~~~~~~~\theta = tan^-1(y/x)##
Watch out for the quadrant of the angle... the arctan function only returns angles in the first and fourth quadrants, so use a bit of thought to place the quadrant using the signs of the individual x and y components. A better choice of function is the atan2(y,x) function which handles all of this automatically, and which you may or may not have on your calculator, or it may have a built in rectangular-to-polar mechanism.
x = -14195.1592
y = -2626.994
P=√(Px^2 + Py^2)
P = 14436.19209
I'm not sure about this other thing
θ=Tan-1(y/x)
θ= 10.48
