Why Is the Power Series Automatically Centered at x=2?
The power series in question is automatically centered at x=2 due to its definition, which states that a power series takes the form f(x) = Σ a_n(x-c)^n, where c is the center. When deriving this series, the derivative f'(x) also remains centered at x=2, maintaining the same radius of convergence. The discussion emphasizes that the first four terms requested are indeed derived from the power series expansion around x=2, and the confusion regarding nonzero terms is clarified by the definition of the series itself.
  • Understanding of power series and their general form
  • Knowledge of derivatives and their application to power series
  • Familiarity with the concept of radius of convergence
  • Basic algebraic manipulation of series expansions
  • Study the properties of power series, focusing on their convergence and differentiation
  • Learn about Taylor series and their applications in approximating functions
  • Explore the relationship between power series and their derivatives in detail
  • Investigate examples of power series centered at different points for comparative analysis
Students studying calculus, particularly those focusing on series expansions and derivatives, as well as educators looking to clarify concepts related to power series.
nfcfox
http://imgur.com/12LbqWL
Part b
Since it says the first four terms, not nonzero, the first four terms would be 0-(1/3-0)+2/9(x-2)-1/9(x-2)^2
I'm confused when it says I need to find these for x=2... Do I just plug in x=2 now and those four terms are them? Those won't be terms they'll be numbers. I'm assuming that the series is already centered at x=2 as that's why is says (x-2)^n so if that's the case, finding f'(2) would be to use the equation for geometric series so A/(1-R) but the first term is 0. Did they mean to say the first four nonzero terms? If someone can confirm this that'd be great.
They want you do write out the derivative ##f'(x)## in the same way as the series you got in the problem, the first four terms and then the general term. After that you should plug in x=2.
First four nonzero terms?
That is what I would do.
So is the power series already centered about x=2 when I take the derivative??
Well, ##f(x)## is defined by the power series, which is expanded around ##x=2##. So taking the derivative of the power series would be to take the derivate of ##f(x)## and its derivative would indeed be a new power series that is indeed expanded around ##x=2## and have the same radius of convergence as ##f(x)## itself.
EDIT: If you look at what you write in your attempted solution I think you can see that the derivative takes to form of a power series.
Right but I guess my question is why is it automatically centered around x=2.
Because it follows from the definition of a power series, i'll show you a general case with a power series expanded around some point ##x=c## and its derivate
f(x)= \sum_{n=0}^{\infty} a_n(x-c)^n
let us now take the derivate of this, its a sum so the derivate of the whole thing is just the sum of the derivates of each term. We have that
f'(x) = \sum_{n=1}^{\infty} na_n(x-c)^{n-1}
We can now see that ##f(x)## and ##f'(x)## is indeed power series and they are both expanded around ##x=c##. I don't think that it could get any clearer than this.
  • · Replies 22 ·
