Why is the wavefunction an integral over k in Gasiorowicz?
  • Level: Undergrad
  • Thread starter Thread starter Arman777
    Terms Wavefunction
6 replies · 2K views · last reply
Arman777
Insights Author
I am reading a textbook quantum physics by stephen gasiorowicz. And he defines a wavefunction in this form,
$$Ψ(x,t)=\int_{-∞}^{∞}A(k)e^{i:(kx-ωt)}dk$$
I did not understand why its a function of ##k## or why even we are taking integral with respect to ##k## ? Is ##k## actually means momentum somehow ? Or what's the importance of ##k## since we the wavefunction is actually a function of ##x## and ##t##.
It's not a function of ##k##. ##k## is a dummy variable over which the integration is done.
The set of functions ##e^{i(kx - wt)}##, ##k \in \mathbb{R}##, is an uncountable (or continuous) basis for the space of wavefunctions.
Mathematically you integrate over a "density" function ##A(k)##, which essentially gives you the weighing for each eigenfunction in your expansion.
You should compare what you have with the discrete case:
$$\Psi(x, t) = \sum_{n = 1}^{\infty}A_n f_n(x, t)$$
Your equation is the continuous version of this.
The comparison is: sum over ##n## (discrete case) against integral over ##k## (continuous case).
##k## is not a wavenumber right ? I understand what you said I guess but its still confusing for me somehow
##k## represents the momentum for that particular eigenfunction. Whether you also want to call that a wavenumber? I would go with the terminology in your book.
I think it isn't that easy to grasp. The important thing is that physically you always have a range of ##k##, hence a wave-packet.
I agree that it is not easy. I am watching some MIT videos to understand it. And later on I ll get back to you
I guess I understand it. Its the adding the all possible wavefunctions in momentum space and getting some new wavefunction.
Yep, although it might be better to think of ##\Psi(x,t)## as the wavefunction of some physical system (not a "new" wavefunction) and the integral is a way of rewriting it in a more computationally tractable form, a sum of momentum eigenfunctions.
