Why is there a 2 in this fraction problem?
  • Context: High School
  • Thread starter Thread starter jim1174
7 replies · 2K views
jim1174
I need some help with this fraction problem. 8 5/6 - 1 1/3 you Need to rewrite the problem as 8 5/6 - 1 2/3 where did the two come from ?
Discussion
Mathematics news on Phys.org
The problem is 8 5/6 - 1 1/3 the answer is 8 5/6 - 1 2/6 answer 7 1/2 I just want to know how they got the 2 in 2/6
jim1174 said:
The problem is 8 5/6 - 1 1/3 the answer is 8 5/6 - 1 2/3 answer 7 1/2
The expression is either 8 5/6 - 1 1/3 or 8 5/6 - 1 2/3. The two are not the same.
Since the answer is 7 1/2, the problem must have been 8 5/6 - 1 1/3. The only explanation for 8 5/6 - 1 2/3 is that it's a typo.
Edit: Jim, I didn't notice that you revised what you wrote in your later post. 1 1/3 is the same as 1 2/6.
The question is 8 5/6 - 1 1/3 you are supposed to re write the problem as 8 5/6 - 1 2/6 what I want to know is when they changed the 1/3 to 2/6 where did the two come from
You can multiply the top of a fraction by any number so long as you multiply the bottom of that fraction by the same AND THIS DOESN'T CHANGE THE VALUE of that fraction.
So 1/3 is equivalent to 2/6 in all regards.
QUESTION: Would you prefer 1 slice of a pie after the pie was cut up into 3 equal pieces, or
would you prefer 2 slices of the same pie after it had been cut into 6 pieces?
ANS: there is no difference!
The decision to convert the denominator into a 6 was so that it matched the denominator of the first fraction in the problem.
If I may propose a different way of seeing it: any number multiplied by 1 is the same number. Therefore, you can always multiply any fraction by ##n/n## (provided ##n## is not zero!):
\frac{1}{3} = \frac{1}{3} \times 1 = \frac{1}{3} \times \frac{2}{2} = \frac{2}{6}
