Physic lover
- Messages
- 16
- Reaction score
- 0
In a recent thread, I posted a spacetime diagram that illustrates your point:robphy said:In a position-vs-time graph, if you ask a bunch of inertial observers standing at the origin-event to travel 1 sec (according to each observer's wristwatch) with all possible velocities [in agreement with experiment], their endpoints (their "my watch reads 1 sec" events) trace out a hyperbola (the "circle" in Minkowski-spacetime).
[tex](1\ \rm{sec})^2=(\Delta t)^2-(\Delta y/c)^2[/tex] [with my signature convention].
Please help me understand why there is a minus in the spacetime interval formula and not a plus.
Physic lover said:Hello everyone
Thanks in advance
Ken Natton said:However, to dismiss this question as one of aesthetics does not seem entirely fair to me.
Ken Natton said:the first problem is that the time dimension uses different units than the spatial dimensions, c in the time element is effectively a conversion constant to normalise the time value to the space values. That seemed a very insightful point to me.
Ken Natton said:...it relates to this point about the difference between the space and time dimensions and exactly how we measure them.
pervect said:The constancy of the speed of light implies that if the Lorentz interval is zero for one observer, it's zero for all. This works only because of the minus sign - it's basically a restatement of the principle of the constancy of the speed of light.
The stronger statement that the Lorentz interval is constant for all observers implies the above, for if it's constant and zero for one observer, it's zero for all. It turns out that the stronger formulation is true, but I'm not aware of any easy to explain reason why the stronger formulation turns out to be true.
Hopefully, this provides some insight into the motivation of why we need a minus sign, even if it doesn't totally explain it.
nitsuj said:Oh and I found your reply disappointing as well.pervect's reply was really clear specifically "it's basically a restatement of the principle of the constancy of the speed of light." & WannabeNewton's mentioning to look into lightcones & the Minkowski metric are great replies to the OP.
nitsuj said:The idea that time and space have different units and c is a "conversion" for natural units is insightful as to why there is a negative sign in the spacetime interval equation?
nitsuj said:I have not "explored" it but suspect c is a requirement of causality. And causality is a very simple logic.
In this specific context id call them synonymous.
there has been thread topics around this idea.
DimReg said:That's not quite true: There are spacetimes in general relativity that have closed timelike curves, despite the fact that the speed of light in GR is still constant. These curves essentially are the signature of time travel: you can meet up with an earlier version of yourself. Also consider that time travel is completely impossible in Newtonian mechanics, yet there is no maximum speed there (causality holds trivially in Newtonian mechanics).
I prefer to leave the constancy of the speed of light as an experimental/theoretical observation: either you have the michelson-morley experiment, or you have electrodynamics. Either (or both) of those can convince you to try to make a theory in which the speed of light is constant. I tried to give a good motivation for why you would consider a geometric theory in which the spacetime interval has a minus sign. Causal structure is built into the geometric structure of spacetime, so you still need to only consider the spacetime interval.
Chestermiller said:This is precisely what I was trying to say, although you articulated it in a much better way than I did.
Chet
Man UChicago must really have some brilliant lecturers. I have also heard that Wald is a brilliant lecturer (and his writing is about as clear, concise, and accurate as I have ever seen in the realm of GR textbooks).DimReg said:I assume his writing is approximately as good as his lecturing skills.
The kind of causality you are thinking of always holds locally in GR but globally you can have all kinds of weird things happen with regards to causality; DimReg gave the example of closed time-like curves.nitsuj said:I am completely unaware of what GR has to say about spacetime, only a bit about SR.
That part is what I haven't "explored", I only suspected the connection...less so now.![]()
Ken Natton said:Yes, I wasn’t commenting on the contributions of others, only on the contributions of those whose posts have a badge that carries with it certain expectations. I would again stress, I too am familiar with many posts by ZapperZ, and understand that his expertise is not just in this subject but as an educator. And any good educator knows that simply supplying answers is not a very effective way of educating. It is generally more effective to stimulate the questioner to think for themselves. I suppose his post may have been intended to do something of that kind, but I suppose I found myself stimulated to stand up for the OP in the face of what I found to be less than entirely valid criticism.
Ken Natton said:No I didn’t mean insightful in that way. I suppose I was just highlighting some of the insights that had helped me to decode this particular formula, and suggesting that the insight that the OP needed was of a similar type and character, and doubtless one that both Vanadium 50 and ZapperZ would be perfectly capable of supplying, if they chose to.
